> Honda Accord (1990 - 2002)
Old 11-02-2009, 09:09 PM   #1
dubedone
1990 Honda Accord
dubedone's Avatar
Default B tranny on F block?!
ok so i was reading super street and they said someone has made a plate that allows you to bolt a B-series tranny to an H-block now ive also heard that the H-series tranny can bolt on to an F-block so with this new plate do you think we can put B-series trans in our F powered accords also would this work with the H-heads bolted to the F. now thats one hell of a frankenstien.
did you ever wish the circle was a square so that when land sharks start circling you could just cut them off at the corners
dubedone is offline Report Post   Reply With Quote
Old 11-02-2009, 11:01 PM   #2
jDracer
Default Re: B tranny on F block?!
Yup, H to B also know as K20 killa. It would probably bolt up to the F with that plate, but I don't know how your gonna mount it into the accord. The last time I checked my accord had a cable tranny and I'm sure yours dose too. But hey anything is possible.
jDracer is offline Report Post   Reply With Quote
Old 11-02-2009, 11:13 PM   #3
philadd
philadd's Avatar
Send a message via AIM to philadd
That kit was made to be fitted into Civics and Integras It solved the axle problems people were having due to the axles being aligned horribly. Use an H2B kit in an Accord (and custom fab mounts to fit it) and you're likely to have axle problems, but that's speculation as of now.
'99 Accord EX
'04 Corvette Z06
philadd is offline Report Post   Reply With Quote
Old 11-03-2009, 06:25 AM   #4
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
add to that fitting the shifter and shift linkage
TouringAccord is offline Report Post   Reply With Quote
Old 11-03-2009, 07:18 AM   #5
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
Yeah, Bisi don't make H2B for Accords; Not that I know of. That would be sweet though if they make a plate for us Accords to be able to use the B-Series transaxle.
Now, you can use a H-Series trans on a F-Series engine. It's been done and of course shorter gear ratios. Same with head freinkenstein; G22/G23 swaps.
1994 Honda Accord EX
- JDM H22A: Wrinkle Red Valve Cover; NGK Plugs; SS Header; AEM SRI; Exedy Stage 1 Clutch; Fidanza 8lbs Flywheel; Apexi WS2 muffler; & 2.5" custom piping.
nus_dogg is offline Report Post   Reply With Quote
Old 11-03-2009, 07:35 AM   #6
twkdCD595
twkdCD595's Avatar
You can do a B series trans on an H or F as stated above but not in our accord chassis yet, well at least a production ready kit that is. If you wanted to do it with some money and someone with some know how, anything is possible.
Dont know why you would need to go to a B series other than more gearing choices though. H/F series transmissions seem to be holding up pretty well unless your pushing some bigger power running slicked up routinely putting it through its paces.
-try not, do or do not... there is no try.
God bless the men and women of the U.S. armed forces.
T1 Race Development
Laskey Racing
PortFlow Design
Bisimoto Engineering
twkdCD595 is offline Report Post   Reply With Quote
Old 11-03-2009, 01:35 PM   #7
CarsAddict
yeh thats true. dont have a clue whered youd get it from though sorry.
Cars Route
CarsAddict is offline Report Post   Reply With Quote
Old 11-03-2009, 01:48 PM   #8
Turbo-LS
Turbo-LS's Avatar
Send a message via AIM to Turbo-LS
Get an H tranny and change the final drive to get even lower gearing, should make it somewhat comperable to a b transaxle
Hondata, Crome Pro Tuning, Socketing
Originally Posted by Turbo-charged
My Weldon 2015 started working about 50% in the middle of a pass. 40lbs of boost, 3rd gear, and about a 16.5 AFR left my radiator looking like a taco.
Turbo-LS is offline Report Post   Reply With Quote
Old 11-03-2009, 01:57 PM   #9
accord_raffi
1996 Honda Accord
accord_raffi's Avatar
Send a message via AIM to accord_raffi
I thought we had hydraulic trannies, hence the hydraulic/brake fluid reservoir.
**Dent Sport Garage**
http://i56.photobucket.com/albums/g1...785/sig2-1.jpg
CD Squad Member #196
accord_raffi is offline Report Post   Reply With Quote
Old 11-03-2009, 02:29 PM   #10
tamadrummer1120
1995 Honda Accord
tamadrummer1120's Avatar
yeah....i thought so too......all of the hondas i have ever worked on had a hydraulic trans........
and the 5th gen accord and the corresponding civics do.
CD Squad Member #220
tamadrummer1120 is offline Report Post   Reply With Quote
Old 11-03-2009, 04:14 PM   #11
Turbo-LS
Turbo-LS's Avatar
they are refering to the shifter style boys. b transaxle is two bars and h series has two cables that shift the trans. the hydro is just the clutch depression and release mechanism
Old 11-03-2009, 04:18 PM   #12
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
Yup. Shift rods and shift cables.
Old 11-03-2009, 04:21 PM   #13
tamadrummer1120
1995 Honda Accord
oh ok.
i stand corrected. thought he was saying the clutch type.
i always thought the G23 with a b series trans in an accord would make a fun drag car.
Old 11-04-2009, 12:53 AM   #14
extralargenog
extralargenog's Avatar
B series tranny on a H/F is good for one thing and one thing only... H swap in a civic/ Integra to compensate for axle angle... I have blown up more H trannys than most have SEEN with my setup in the CD5.
The B trannys are dimensionally smaller and the gears Weaker than the H trannys. TRUST ME... The ONLY advantage would be the readily available gearset components available...
Although PPG offers a really nice dogbox for the H... H syncro straightcut forged sets are not readily available... I have been in touch with Eric at Bullhead (PPG distributor in the US) as hes local to me about putting together a Syncroed H set.... Just need people to step up....
I already have a straightcut syncro box now anyways so at over 650 WHP I beat the shiiiit out of the car and its proven reliable
If the B series tranny was worth it Id have oner in the car trust me. Its just not worth it... Also nnoteworthy is that Ive been running OEM H series prelude axles ion my car (full interiuor EX) for over a year and a half without any issues... The car makes 520 on pump and has M and H 235/60-15 DOTS on it and it HOOKS.
Havent broken one yet. LMK if youd like more info on whats neeeded to run the Lude axles... Ittl save yuou about 800 on some DSS shit or the gators...
Heres a site for a 5the gear cuff for OEM style gearsets
http://www.turbooptions.com/cncdesig...od&productId=3
LEED tuned 660 WHP 4 do' panty soiler
GFI:WE build FAST!!!
REALHOMEMADETURBO.COM, KAIZENSPEED.COM, LSD Motorsports
extralargenog is offline Report Post   Reply With Quote
Old 11-04-2009, 09:23 AM   #15
accord_raffi
1996 Honda Accord
You didn't state it directly, but accords do have cable transmissions then too? like the h?
Old 11-04-2009, 09:35 PM   #16
98-hondaaccord
why not just get a f20b tranny which is similiar to b series and comes with Lsd...
98-hondaaccord is offline Report Post   Reply With Quote
Old 11-04-2009, 09:38 PM   #17
extralargenog
Wrong. LSD has nothing to do with shredding gears. Ive broken more than one ring gear too. Nor is the F20B tranny "more like a B". Its cable shifted and internally like an H not a B (even closer to an F than a B)
Nevertheless you still miss the point the B trannys are NOT stronger than the H. Do the math... The H made a good bit more power from the factory. The trannys (H) are engineered to take more power. The reason the B series tranny is advantageous is listed above and not one has to do with being stronger than the H).
Hertes some proN
Broken forged starightcut stuff:
Broken Case:
Old 11-05-2009, 12:29 AM   #18
accord_raffi
1996 Honda Accord
How is it that even forged, straight cut gears are being torn apart? I understand the B trannies are weaker from the factory, but I would assume using forged/cryo-treated parts would solve the issue. Since those are straight cut gears, I'm assuming that tranny was just meant for abuse and it had finally taken too much of it, even for its design.
Old 11-05-2009, 12:44 AM   #19
extralargenog
POWER POWER POWER.... They arent breaking on shifts (I also have a Tilton FCV on it). Its always been after the shift and the turbo hits. My shit hits HARD too... LOL Obviously.
Heat treated OEM stuff fails too.... Buddys trying some Cryo stuff locally thats at around 610WHP in a 3rd gen lude.. He was just starting to regularly break OEM stuiff (most always its 2nd and fourth gear as did I)
The forged gear breakage was due in part to the fact that I got a prototype gearset from them... The ratios (read tooth count) of the gears had changed (for fewer teeth, allowing MORE material)
Enough power will break anything!!!!!
Add a twin disk
ALOT of Tq for a honda
A heavy ass car
I bought my set used.. I blame fatigue. Since upgrading the 2-3-4 sets I have beaten the shit out of it and had no issues since. All season at >650 WHP and the car hooks pretty damn good.
Old 11-05-2009, 06:16 AM   #20
TouringAccord
H-T Order of Merit
yep
Old 11-06-2009, 09:00 AM   #21
tamadrummer1120
1995 Honda Accord
extralognog,
thats a sick setup....minus the broken teeth deal haha. how much louder is the straight cut gears as compared to the oem's? GL getting the trans to hold up dude!
Old 11-06-2009, 10:44 AM   #22
j3wman
j3wman's Avatar
a B tranny wouldnt handle the f's torque well since it was made for a car that had about as much torque as a gerbal in one of those little rolly ball things, thats just speculation tho.
j3wman is offline Report Post   Reply With Quote
Old 11-06-2009, 01:26 PM   #23
Brad_and_the_acc
Brad_and_the_acc's Avatar
Depending on what engine and trans your refering to.. The Bseries engines arnt very far behing in torqe #s compared to the F.. In stock form that is..
The reason its not a very good option for most is the gear issue.. They are weak.
Originally Posted by P_Adams View Post
but who knows - they may be made up of compressed Ramen Noodles for all we know.
Brad_and_the_acc is offline Report Post   Reply With Quote
Old 11-06-2009, 02:26 PM   #24
extralargenog
Originally Posted by tamadrummer1120 View Post
extralognog,
The straightcuts are ALOT louder... They sound SOOOO sexy :O)
http://www.youtube.com/user/bigdaddy.../9/SbCR4_LuWsI
Its holding up well now with the uipdated 3 and 4 gearsets.... Ive been beating the shit out of it all summer with no issue.
Old 11-06-2009, 02:40 PM   #25
Brad_and_the_acc
Originally Posted by extralargenog View Post
OT...
Lots of hate in the comments on that channel..
No Honda luvs..
The only thing that Talon will be walkin is the crank.
Bookmarks
block, honda, kits, math, series, tranny
