November FS Sticky
#101
Re: November FS Sticky
JG Engine Dynamics Intake Manifold D-Series $150
M&H Slicks 24.5x8.5x15 Decent Condition $200 plus shipping for pair
Technomagnesio 15x6.5 40mm ET Wheels Fair Condition $350 plus shipping
Skunk2 68mm Billet Throttle Body $125 plus shipping
Rywire OBD0-OBD2 Complete Engine Harness with Jumper $250 plus shipping
Innovative Polished Mount Kit B or D Series 92-95 Civic 94-01 Integra 85A Durometer
Dropzone shocks and coilovers w/custom Eibach rear springs 450lb front / 1000lb rear - Great dragrace setup 92-95 Civic/94-01 Integra $250 plus shipping
Apexi PowerFC with Commander for OBD2A Honda/Acura $400 plus shipping
#102
I have a set of Bosch 1600cc injectors and a 4 channel FJO injector driver. $400 as a package deal.
I also have a Autometer Pro Comp tachometer 11k duel band. $200
All items are a little over a year old and currently installed in my car and in perfect working order. I would perfer pick up but will ship. NOVA area.
#104
***TESTING the Waters***
Seriously thinking about parting out my race car. PM me with interest and dibs, so when I make up my mind you get what you called dibs on. Thanks
Head & valve train:
-H22 Cylinder Head. Ferrea dual valve springs, Ferrea titanium retainers, Ferrea valves, Head has a stage 5 race port & has been polished. 3 angle valve job, New OEM valve and cam seals, vented -10a/n valve cover. $1000 shipped
-Custom TopEndUSA H22 Turbo Cams AEM adjustable Cam gears $550 shipped
Block:
-H22A1 with Darton Sleeves, Crower rods, Arias pistons, High flow oil pump, Kaizen Speed balance shaft elimination kit, New Honda bearings and seals, ARP Head head studs $1800 shipped
Intake system:
-Venom intake manifold $375 shipped
-STR 70mm billet throttle body $125 shipped
Turbo system:
-Stainless steel tubular T4 turbo manifold faces compressor forward $500 shipped
-4 inch custom downpipe $300 shipped
-Borg Warner S372 turbo with small cover 1.10 exhaust made 745whp at 35psi $1250 shipped
-greddy 46mm wastegate $400 shipped
-Custom PWR Water to Air intercooler with Ice Box, water pump and lines $700 shipped
-Synapse BOV with Custom mandrel bent down pipe $150 shipped
Fuel system:
-Aeromotive 1,000hp -10AN fuel pump, $250 shipped
-Aeromotive Fuel pressure regulator, $120 shipped
-STR fuel rail $110 shipped
-Precision 1600cc injectors $220 shipped
-Custom fuel sump DA tank $250 shipped
Engine Management:
-P28 with s300 installed $480shipped
-Custom OBD1 race wiring harness one piece design $420 shipped
-MSD Digital 6 $275 shipped
-MSD HVC Coil $100 shipped
-AEM Injector Driver $125 shipped
Cooling system:
-Fluidyne 3 core radiator $80 shipped
-Summit catch can $25 shipped
-Spal high flow fan $45 shipped
-Innovative mounts alternator relocation kit $60 shipped
-New Optima redtop battery $140 shipped
Transmission & driveline:
-H22 transmission, Circuitworx Drag spool, New syncros and input shaft bearings, $575 shipped
-F22 transmission, OBX LSD, comes with carbon coated syncros not installed, needs new bellhousing $550 shipped
-Competition Clutch twindisk clutch $820 shipped
-Drive shaft Shop Stage 3.9 axles $650 shipped
-explicitspeedperformance mounts $ 275 shipped
-Chassis & Suspension:
Custom Ground Control coilovers with Koni yellow adjustable shocks
Full Energy Suspension bushing kit including the trailing arms, Place Racing
cross member, 6 point roll cage, all around deadening material has been removed.
factory red paint with color matched moldings, JDM 90-91 Integra tail lights,
Clear front corner and bumper lenses, Custom 12lb single layer carbon fiber lift
off race hood with Dzus fasteners. If I sale you will need steelies $1200 picked up or shipped at your expense
Wheels & brakes:
-Konig Heliums 15x7 black 12lbs with Azenis 205/50-15 tires for the street $600 picked up or shipped at your expense
-New 15x8 spinwerkes with 26x9 toyo slicks with only 2 1/8th mile passes on them $775shipped
-RCI drivers side 5 point harness $65 shipped
-Corbeau passenger side 4 point harness, $80 shipped
-Corbeau red Forza seats (pair) $600 (each) $300 picked up or shipped at your expense
PM me or email at charles@topendusa.com
Head & valve train:
Block:
Intake system:
Turbo system:
Fuel system:
Engine Management:
Cooling system:
Wheels & brakes:
#105
Brand new Spec H&F series Triple Disc Clutch SH14MT3 never used only bolted up for mock up. $900.00
H22 Venom Intake manifold this was on my race car that went 9.50's. It has been re-welded a few times but still work great! $200.00
#106
precision t68 $700
gt4088 $500
cf48 mugen rims $600
high compression JDM B20B bottom end $500
complete gsr head dual valve spring ferrea valves crane cams $600
jdm type r valve cover w/ skunk2 billet plug cover $200
running fully built gsr made 661 on only 24 psi and it will make more.284 comp cams jg valves crower springs and retainers cicuitworks oil pump 85mm bore cp 9:8 to 1 pistons oliver rods eagle crank benson sleeved and o ringed block $2500
gt4088 $500
#107
h2b and bseries parts
Any ???? call zakura @ 978-944-3095
H22 Peackboost t3 turbo manifold 44mm b-vand flange $600
H2b tilton twin disk from exospeed use only to tune my car $700
B series custon intake manifold from dosky fab with fuel rail and fitting $700
Aluminun radiator with fan $125
1995 ex accord tranny with obx LSD will fit h22 $450
#108
b18a1 block
devcon filled
81.5mm
hot tank,bore,and resurface done @ tabors machine vancouver,wa
eagle rods
wiseco 8.5
arp headstuds
cometic headgasket
new oil pump and water pump
greddy sandwich
0 miles since rebuild!!! i ran it for 12 seconds and that was it
99 pr3 head
itr cams
skunk pro series intake manny w ls tb
jdm custom cut vc
trans
00 si
quaife lsd
shifts like butter no grinds or any problems
i can brake up and sell long block for 2500
trans 1500 firm
#109
SRP Pistons 75.25 for a D series there just sitting in my closet and IM not using them. Help me finish my car someone needs them and there prices to move quick. Paypal is johnjr259@yahoo.com. The only trades I will entertain if for some suspension stuff. I have tons of vouches from D-series.org
Price is 216 shipped within the continental US of course
#110
Aeromotive a1000 fuel pump
used but in great shape
$200 obo
Used cp k24 pistons
only 15 dyno runs
12 to 1 comp
$200 obo
b16 hondata gasket brand new
$40
$200 obo
Used cp k24 pistons
only 15 dyno runs
12 to 1 comp
$200 obo
$40
