3" exhaust on gsr with bolt ons?
Old 10-29-2009, 03:53 PM
blackccoupe's Avatar
Default 3" exhaust on gsr with bolt ons?
got a gsr with all bolts on skunk 2 mani, type r header ,etc. will 3" exhaust hurt me ? buddy has one for real cheap, car will be tuned also
any info is appreciated
Old 10-29-2009, 03:57 PM
mar778c's Avatar
Default Re: 3" exhaust on gsr with bolt ons?
No, a 3" exhaust will not "hurt" anything. A good tune and you will be ahead of most.
BTW, I run 3" exhaust.
Here's a link to the latest dyno. https://honda-tech.com/forums/all-motor-naturally-aspirated-44/blox-c-versus-blox-2645256/
Old 10-29-2009, 04:32 PM
i'm running stock internals cams etc.
Old 10-29-2009, 04:51 PM
ThA5oLuTiOn's Avatar
Here's a link to the latest dyno. https://honda-tech.com/forums/showthread.php?t=2645256
X2... Wouldnt "hurt" anything, But I think It would be kind of loud If you was concern on sound.
P.s. Mar I just saw your thread and Much props to you. Also did those "Blox C's" wer slap in cam or had to degreed them aswell?
Old 10-29-2009, 05:05 PM
mar778c's Avatar
Yeah, you are right about the sound being a bit loud but if you are looking for the power then that is the way to go.
Thanks. The C's have the same centerlines as stock cams.
Old 10-29-2009, 05:26 PM
thundernoodle's Avatar
Same centerline? Does that mean they could run with a stock ecu below ~3k? Pass emissions OBD2?
Old 10-29-2009, 05:36 PM
mar778c's Avatar
Centerlines yes, primaries and secondaries lift and duration, no.
Old 10-29-2009, 05:57 PM
All Motor Mentor
00Red_SiR's Avatar
All it means is that you can install them at 0-0 and they'd be oriented like a stock cam, no real need to degree them. After that you can play with them on the dyno to see what makes best power.
Old 10-30-2009, 03:36 AM
OH_1fstgsr's Avatar
Have you had your current set-up tuned? 10:1 with GSR cams you'll be hard pressed to break 170whp.
Do you currently have an after market exhaust on it?
Old 10-30-2009, 06:56 PM
True statement, "Gotta do what you gotta do to make power"... You think you could of made the same or more power with "JUN3'S"? Same centerlines right?
Old 10-31-2009, 03:43 AM
kulo's Avatar
2.5" would be nice
Old 10-31-2009, 03:55 AM
All Motor Mentor
00Red_SiR's Avatar
The power would have been exactly the same since the Jun 3's and the Blox C's are the exact same cam.
Old 10-31-2009, 07:18 AM
unusual71's Avatar
3" exhaust wont hurt you in any way. Everything past the collector is nothing but a restriction. It will be loud though, i have a b20 with a 3" exhaust and everybody says it sounds great but its loud enough to set off car alarms.
Old 10-31-2009, 07:51 AM
00MRSi's Avatar
Go for it. I have 3 inch KTellering piping with 2 SMSP resonators and a 3inch vibrant muffler..
Old 10-31-2009, 08:27 AM
Thanx man, I knew I was right I just couldnt rem. I found "Blox C's" alot more expensive then "JUN3'S" Thats the only diff I see.
Old 10-31-2009, 09:06 AM
komat's Avatar
wtf really?
bloxc used 200 or less or 400 shipped new
jun3 used 350-400$ or new is like 600+
if you want a cheap 3"
you can go to ebay get the 3" exhaust for $140 shipped
if you want to spend a little more cut the muffler off and put the one you want on it for $100 or so more
Old 10-31-2009, 09:08 AM
mar778c's Avatar
Exactly.
lmike6453
11-05-2010 04:45 AM
92 CiViC gsR
Honda S2000
35
04-05-2003 08:46 PM
justininhifi
08-12-2002 09:05 AM
ITR#203
09-03-2001 05:26 PM
Quick Reply: 3" exhaust on gsr with bolt ons?
