CEL Code P1456
Old 10-29-2009, 08:20 AM
TonyRomo's Avatar
Default CEL Code P1456
So the code P1456 Evaporative Emission Control System Leak Detected (Fuel Tank System) just popped up on my 2000 Integra GSR.
It does smell like gas a little bit when I first start the car every morning.
How do I approach fixing this?
I need to get my car inspected by the end of the month too, dammit perfect timing. Deleted the code so hopefully it doesn't pop back up anytime soon.
Old 10-29-2009, 08:22 AM
Foreign Symbols
juevi's Avatar
Default Re: CEL Code P1456
You have a fuel vapors leaking from somewhere, as in gas cap, fuel tank, evap cannister purge sol, pump, or hoses connecting to the cannister purge. What I would do is replace fuel cap first (cheap), if comes back on, find a GOOD shop with a smoke machine, pay them to smoke it and find leak, repair leak, done.
You can also do a visual first, it could be an obvious cracked hose, but if nothing visual, get it smoked.
Old 10-29-2009, 08:24 AM
It Wasn't Me!
someone else's Avatar
If it comes back the first thing I would try is a new gas cap from the dealer and cleaning the filler neck where the cap seals to it. If it comes back after that it is usually either a Fuel Tank Pressure sensor or a filler neck issue. That's just based on what I've seen in the last 6 years.
Old 10-29-2009, 08:27 AM
grammer nawzi
sicky's Avatar
THIS IS NOT THE TECH SECTION!!!!!!!!!!!!!!
Old 10-29-2009, 08:28 AM
Hookers and blow
dipsy's Avatar
wow....never thought I would see the day when people get tech help in GDD.
anyways how many miles you got on your GSRRRR?
NVM:
HELLOOOOO SICKKY!!!
Old 10-29-2009, 08:31 AM
im hench irl
skateboard_ej8's Avatar
Ah, yes. GDD helping one another. Lets bask in this for a moment now..
Old 10-29-2009, 08:35 AM
Hookers and blow
dipsy's Avatar
TSOI TSOI TSOI TSOI TSOI TSOI TSOI TSOI TSOI TSOI TSOI TSOI
TSOI
Old 10-29-2009, 08:39 AM
TonyRomo's Avatar
This probably would have taken awhile to get answered in the Integra forum thats why I posted it here. I got 2 answers within minutes, amazing.
The car just hit 100k.
Thanks to the people with helpful responses.
Old 10-29-2009, 08:46 AM
eMpAtHy's Avatar
use a lighter around your gas tank to check for gas leaks.
GDD Member
slomofo's Avatar
Burn some baby oil through it and find the leak. Why post this in GDD?
EDWINV00SI
04-27-2011 06:52 PM
Kowalske
Honda Civic (2001 - 2005)
02-03-2009 07:21 AM
Eddie99
Honda S2000
11-07-2007 09:31 PM
93CharcoalHatch
10-22-2005 01:37 PM
AamirCWITR
06-25-2003 04:10 PM
Quick Reply: CEL Code P1456
