Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic (2006 - Current)
Old 10-27-2009, 03:10 AM   #1
Jordanasm
2006 Honda Civic
Default Honda Fluids vs others
hey guys, I'm about to do a brake fluid change, change my mtf, and top off my other fluids. Do you think that Honda fluids are really "better" then lets say some other companies?
Jordanasm is offline   Reply With Quote
Old 10-27-2009, 05:16 AM   #2
honda.lioness
Default Re: Honda Fluids vs others
Here is my view based on years of owning Hondas:
Brake fluid -- any high quality aftermarket brake fluid is fine.
Hydraulic clutch fluid -- see brake fluid above.
Manual transmission fluid -- Honda OEM bought from dealer. I would not rule out some of the recommendations for other MTFs here, though. I would never use motor oil in the transmission; use of motor oil is outdated due to industry changes in motor oil additives.
Power steering fluid -- aftermarket stores like Autozone, Pep Boys and Napa sell a Honda specific PS fluid that is fine. Just make sure the aftermarket fluid container says it is for Hondas. Failing to get the Honda specific fluid can destroy the seals on the PS system.
Coolant -- either Honda OEM or orange Havoline Dexcool. The Dexcool says it is specifically designed for aluminum yada engines requiring yada. I have been using the Dexcool since 2002. I buy the undiluted version and then add distilled water. Do not use tap water.
Engine oil -- any good motor oil appropriate to the age of the engine is fine.
Elle
91 Civic LX, 93 Civic DX, 03 Civic LX
honda.lioness is offline   Reply With Quote
Old 10-27-2009, 07:05 AM   #3
Jordanasm
2006 Honda Civic
^ thank you.
Old 10-27-2009, 07:54 AM   #4
CerealKiller
CerealKiller's Avatar
Very well put.
CerealKiller is offline   Reply With Quote
Old 10-27-2009, 10:31 AM   #5
djblive
I'll always use Catrol 5 30 or 5 30 highmileage
djblive is offline   Reply With Quote
Old 10-27-2009, 03:41 PM   #6
ajpturbopittsburgh
I believe amsoil fluids are much better than OEM fluids. Go to their site and look at the specifications for the fluids. The temperature thresholds and most of the results from the tests prove them to be better.
Honda is not a fluid company, Amsoil, Royal Purple, Castrol, etc. are
The test results that AMSOIL displays are by third party I believe.
ajpturbopittsburgh is offline   Reply With Quote
Old 10-29-2009, 04:37 AM   #7
Retribution
Retribution's Avatar
Honda doesn't make their own fluids, the fluids are made by fluid companies and put in a bottle that says honda.
Retribution is offline   Reply With Quote
Old 10-29-2009, 06:53 AM   #8
Alex_G
Occupy GDD
Alex_G's Avatar
For most drivers off the shelf fluids will allow your vehicle to last a long time. If you plan to drag/auto-x/boost your vehicle AMSOIL fluids would be an excellent choice.
Originally Posted by R.a.w. View Post
I know a dude who let me do number 2 on his wife
Alex_G is offline   Reply With Quote
Old 10-29-2009, 03:34 PM   #9
ChargedSI
2006 Honda Civic
ChargedSI's Avatar
I would agree. If your not slamming the motor for gross performance, OEM fluid would be just fine and save you a ton of money.
ChargedSI is offline   Reply With Quote
1993, accord, acura, brake, buy, dexcool, fluid, fluids, honda, mtf, oem, others, recommendation, rsx, tech
