Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic (2006 - Current)
Old 10-17-2009, 06:25 PM   #1
skyseanie
Default 2006 honda civic trunk lock switch
The trunk on my civic will not close anymore. I noticed that the tension spring in the switch/latch assembly was disconnected so I removed the cover and put the spring back on. With the spring back on the lock responds to the key or trunk lever by switching open. However, when I try to close the trunk it does not engage the switch when making contact with the striker. I moved the u-bar striking up as much as I could get it and it is still not making enough contact to engage the latch. When I push up on the latch with a pencil it does engage on the pencil.
Anyone ever ran into this and find a solution? Does the whole switch need to be pulled out and replaced?
skyseanie is offline   Reply With Quote
1990, 2002, 2006, 2009, accord, assembly, civic, honda, key, latch, lock, locked, open, spring, trunk
