> Honda Prelude
Old 10-13-2009, 10:13 AM   #1
black94lude
Default Steering wheel shake when stepping on the brake???
Oh okay guys, the problem Im having with my 4th gen lude is that whenever I step on the brake my steering wheel shake dramatically. So I decided to replaced my two front rotors with the new one and also new brake pads as well and I still have the same problem when stepping on the brake????? Oh forgot to mention but I have also replaced the driver side axle as well although I haven't replace the passenger side axle.........Anyone have any suggestion or advice to solving this problem????? I would appreciate it.....thanks....
black94lude is offline Report Post   Reply With Quote
Old 10-13-2009, 11:17 AM   #2
oneludesol
oneludesol's Avatar
Send a message via AIM to oneludesol
Default Re: Steering wheel shake when stepping on the brake???
pull the rotors back off and have them machined... sometimes (especially shitty china parts) come warped right out of the box.
EH6, Fully built, stroked 89mm H22A, SC6162SP, Equal Length Kiwi Ramhorn, Gearspeed M2A4 W/Quaife LSD, 500whp 93 octane daily driver NOW WITH AIR CONDITIONING WOOOOOOT! http://www.youtube.com/watch?v=GX_fa8rM4VU
oneludesol is offline Report Post   Reply With Quote
Old 10-13-2009, 02:28 PM   #3
sup3rd
sup3rd's Avatar
Send a message via AIM to sup3rd
Is that the only time it shakes? Does it ever shake while you drive on the highway?
If not then oneludesol is probably right and you got gayed
HID retrofit club
member #0045
sup3rd is offline Report Post   Reply With Quote
Old 10-13-2009, 03:04 PM   #4
mattsnooz
mattsnooz's Avatar
Tires perhaps. Pull them off and roll them. See if they don't roll striaght. Cheap way to single out and often issue with shaking/vibration in steering.
h23, the stroke is long, and strong, and she wants to get the friction on.
http://www.comfortcurtains.totalwarehouse.com
mattsnooz is offline Report Post   Reply With Quote
Old 10-13-2009, 03:32 PM   #5
black94lude
In responding to Sup3rd....Yes when Im driving on the highway going 70mph the steering wheel does shake but not dramatically and the steering wheel really vibrate (but you can feel and see that the steering wheel does shake back and forth).......In responding to Mattnooz....I have not try rolling the tires yet....or swapping the tires from back to front or front to back yet.....I will try it as soon as we get some sun light.....it start raining today and for tomorrow as well so as soon as there a break in sun light I try to roll the tire to see if they roll straight or not......
Old 10-13-2009, 05:16 PM   #6
coolharry
1993 Honda Prelude
coolharry's Avatar
x2 on the tires.
could be out of balance or irregularly worn.
coolharry is offline Report Post   Reply With Quote
Old 10-13-2009, 06:55 PM   #7
sup3rd
sup3rd's Avatar
Okay cool, that's another problem I thought you'd might have. When was the last time you bought new tires or balanced them? It's not your rotors because your problem is already there without you having to step on the brakes. It seems that your wheels are improperly balanced.
HID retrofit club
member #0045
Old 10-13-2009, 06:59 PM   #8
jshaw23
jshaw23's Avatar
If you changed the rotors and pad and it is still shaking bad, you need new wheel bearings. Make sure if you do them your self to use the proper method to press them in or just let some one that has the proper equipment to do it.
jshaw23 is offline Report Post   Reply With Quote
Old 10-13-2009, 07:54 PM   #9
JDM-h22a
JDM-h22a's Avatar
alignmentttt
exquisitedreams
JDM-h22a is offline Report Post   Reply With Quote
Old 10-13-2009, 08:09 PM   #10
mkazm83
mkazm83's Avatar
Send a message via AIM to mkazm83
Wheel balance.
mkazm83 is offline Report Post   Reply With Quote
Old 10-13-2009, 11:18 PM   #11
black94lude
In responding to Sup3rd again, I haven't bought new tires in a while now.....I usually buy used tires that are in "like new condition" from a tire shop call "Used Quality Tires" here in town and during that time when I bought the tires they also balanced both of the front tires as well......So do you guys think maybe my tires are wearing unevenlly that why it causing the shaking problem or vibration on the steering wheel...???? And do I need to wheel balance my tires again....????? In responding to Jshaw23, I have replaced my two front wheel bearings last summer already.....do these wheel bearings need to be replace every year....????? J/W.......Thanks you guys so far for the information, advice and sugesstion......Im taking all these information into consideration.......
Old 10-13-2009, 11:21 PM   #12
JDM-h22a
JDM-h22a's Avatar
let us know what the problem is when u figure it out
exquisitedreams
Old 10-14-2009, 08:45 AM   #13
black94lude
Yes, I will sure let all you guys know when I figure it out what was the cause........
Old 10-14-2009, 09:12 AM   #14
xhondaaccord92x
1992 Honda Civic
My Garage
Send a message via AIM to xhondaaccord92x
u should check the wheel bearing by gripping the top and bottom of the tires and pull bottom while pushing top and vice versa to c if its sloppy...then take the sides of the tire and do the same to check tie rod ends...i no that my civic has a really bad inner pass rod and it shakes quite a bit.
xhondaaccord92x is offline Report Post   Reply With Quote
Old 10-14-2009, 09:36 AM   #15
Acidcrakker
Acidcrakker's Avatar
Well I didnt read everyones post but Im going to post this anyway.
This happens with my trucks at work, not on the prelude(mabey its the case) but the ball joints and all the rubber joints that connect the front suspension together become weakened over time.
When you apply pressure to the brake pedal it cause the steering wheel to shake, as well as the truck.
That is something to check into as well. But it only happens when you step on the brake.
Jim- 14.85 @ 97 mph
Speaking Out Against Authority Figures Since 4/23/1983
Acidcrakker is offline Report Post   Reply With Quote
Old 10-14-2009, 09:43 AM   #16
black94lude
I changed both of my front wheel bearing last summer. I don't know how often do you change these wheel bearing???? J/W.....I also change my inner and outer tie rod ends maybe two year ago as well.......I remembered the last time I changed my motor oil. I have check to see if there any fault play in the wheel bearing by holding the top and bottom tire by pushing and pulling back and forth....but there wasn't any fault play as far as I know......I haven't check the side of the tire to see if there any fault play in my tie rod ends yet....Thanks
Old 10-14-2009, 09:47 AM   #17
black94lude
Thanks Acidcrakker, I will look into it as soon as we get some sun light...its been raining for two days now.....so im just waiting for the rain to stop......
Old 10-14-2009, 03:45 PM   #18
2cams
pull the rotors off and make sure theres a clean surface(no rust) behind the rotor. It could cause the rotor not to sit flush and seem as if the rotors are still warped. Try removing the wheels and spin the motor up a little and watch the rotors for movement.
2cams is offline Report Post   Reply With Quote
Old 10-17-2009, 08:32 PM   #19
black94lude
Oh okay guys update....On friday I went and have my wheel balance done.....the shop say my tires are still running pretty straight....after having my wheel balance it seem like the steering wheel vibration went away....but I still got the problem of whenever I put press on my brake my steering wheel still shake dramatically.....now I don't really know what is the problem that is causing this issue......like I mention early I have replaced my front rotor and new brake pads.........already.......any advices or suggestions for this problem......??????????????
Old 10-17-2009, 09:22 PM   #20
JDM-h22a
JDM-h22a's Avatar
do u have drum brakes on the back or disks
and did u replace them???
exquisitedreams
Old 10-17-2009, 09:56 PM   #21
tommy1387
tommy1387's Avatar
Send a message via AIM to tommy1387
check the rear brakes.. the rear need replaced more often then the front
tommy1387 is offline Report Post   Reply With Quote
Old 10-17-2009, 10:07 PM   #22
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
There's certain thickness on those rotors. It may be due to the rotor being too thin so thats why it can't withstand heat which results a warp rotor. You'll need to get it measured out to see if its machine-able; otherwise, just get new rotors.
I don't think so, because more stopping powers are at the front resulting front end dip. The proportioning valve only allows a small certain amount of percentage to the rear calipers.
1994 Honda Accord EX
- JDM H22A: Wrinkle Red Valve Cover; NGK Plugs; SS Header; AEM SRI; Exedy Stage 1 Clutch; Fidanza 8lbs Flywheel; Apexi WS2 muffler; & 2.5" custom piping.
nus_dogg is offline Report Post   Reply With Quote
Old 10-18-2009, 12:06 AM   #23
JDM-h22a
JDM-h22a's Avatar
still being if he didnt replace back they are still old and not good so it still will make that a difference
exquisitedreams
Old 10-18-2009, 12:22 AM   #24
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
True. I'd go ahead and do all four new rotors and pads.
Old 10-18-2009, 08:54 AM   #25
Apex1972
x2
Apex1972 is offline Report Post   Reply With Quote
Bookmarks
1992, 94, 99, accord, brake, braking, civic, driving, honda, odyssey, prelude, shake, shakes, steering, step, vibration, wheel
