CEL P1359 Crankshaft Position
Old 10-10-2009, 07:33 PM
Dchild's Avatar
Default CEL P1359 Crankshaft Position
i have a 97 gsr with a check engine light on. code reads P1359 Crankshaft Position/TDC/Cylinder Position Sensor Connector Disconnection.
what does that actually mean, and how do i fix the problem? any help would be great!
Old 10-10-2009, 09:38 PM
kchungb17a's Avatar
Default Re: CEL P1359 Crankshaft Position
Did you have a T-belt/H2O pump replaced recently? If so it can be:
Coolant trapped between the crank sensor gear and sensor (behind the lower timing cover). This should have cleared out with a some driving so try resetting the light.
OR the wiring harness for the sensor was not tucked back into its holder on the lower t-cover and the alternator belt sawed through it and cut the wiring. You can look down between the alt belt and t-cover to see if the wiring is loose. This can be repaired by reconnecting the wiring but make sure you keep the ground shielding in tact.
OR your sensor may have just gone bad so replace it.
GL
Old 10-10-2009, 10:18 PM
Dchild's Avatar
not sure when the timing belt / water pump has been changed. im guessing it never has been but i recently purchased the car, so ima have to look through the paperwork and see. it has 130k miles..
i will check, thanks for the help.
Old 10-11-2009, 02:04 PM
Dchild's Avatar
so if the crank sensor was bad, wouldn't the car not start right?
another thing, seems like when i get on it or even at idle the car tends to shake.. i was thinking that the shaking of the engine could possibly be missing a engine mount cause the guy i bought it from said he had new engine mounts put in. maybe he missed one? so i'll check for that.
also, would the shaking of the engine cause the CEL to come on for P1359 Crankshaft Position/TDC/Cylinder Position Sensor Connector Disconnection?
Old 10-13-2009, 08:25 AM
SlAmmmmmed-DB8's Avatar
replace sensor its cheap.
Urbina1994
10-31-2017 04:19 PM
Mustang72
Honda Civic (2001 - 2005)
12-01-2014 08:04 PM
06 Pilot 1
11-23-2013 12:17 AM
vegasEGcoopy
06-13-2007 08:28 PM
padraf
07-14-2004 02:49 PM
Quick Reply: CEL P1359 Crankshaft Position
