Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 09-23-2009, 04:41 PM   #1
michael-crxsi
Icon6 How tight to tighten lug nuts on wheels??
I've heard if you over tighten it can mess up you brakes. How tight should I tighten my wheels?
michael-crxsi is offline   Reply With Quote
Old 09-23-2009, 04:44 PM   #2
90RENOsedan
1990 Honda Civic
90RENOsedan's Avatar
Default Re: How tight to tighten lug nuts on wheels??
you heard wrong. tighten them til you can't tighten them anymore by hand. if you're using air, tighten them til the gun stops.
japanese build EE4 http://nolimitimports.com/http://efcivicsedan.myfreeforum.org/
!!!---(775 SQUAD)---!!! #3 HELLA sunk squad #24
90RENOsedan is offline   Reply With Quote
Old 09-23-2009, 04:57 PM   #3
seanbev24
seanbev24's Avatar
Huh? It's like 80-85 foot pounds.
seanbev24 is offline   Reply With Quote
Old 09-23-2009, 04:59 PM   #4
gator88
I have a gun that you wont ever stop, it will spin away with a snapped off stud in your socket.
85 lb/ft
and yes it can warp your rotors by over torquing. You heard right
If you make a post asking what Honda-Tech thinks of your car, expect answers you dont always like. Dont whine when we tell you our opinions if we say it is ugly or nothing special. You asked, we told you. Just hope YOU like YOUR car!
gator88 is offline   Reply With Quote
Old 09-23-2009, 05:03 PM   #5
grog
grog's Avatar
80 lb-ft, and thats from the helm manual so thats the "official" spec.
Originally Posted by xerowatts
I HAVE A 1990 CRX HF AND THE ENGINE BLOWED UP.
Originally Posted by mackadocious
its prolly piece of rust that fell inside the rotor causing it to be cricket and make the car shake ..when stoping or ...or prolly motor over flooded with oil leaks
grog is offline   Reply With Quote
Old 09-23-2009, 05:06 PM   #6
Ass$nyper
Pirate General...YARRRR
Ass$nyper's Avatar
Send a message via AIM to Ass$nyper
It's 80-85, you may or may not need to adapt a few ft lbs for aftermarket wheels.
Yes lugs can be over torqued.
I'm a bit of a retentive man when it comes to this and I will not use a gun it's hand then torque wrench.
-Max
Es gibt keinen Schaden beim Verzichten auf Dinge. Es dürfte sogar gut für Sie sein, sich an ein weiches Leben nicht zu gewöhnen.
Ass$nyper is offline   Reply With Quote
Old 09-23-2009, 05:09 PM   #7
.Manny.
Touching My Member
1990 Honda Civic
.Manny.'s Avatar
I use a 3/8" impact gun at the lowest setting just to snug them. then the trusty torque wrench at 80lb-ft
Originally Posted by doctorake View Post
This thread is worse than sucking ten dicks at once.
.Manny. is offline   Reply With Quote
Old 09-23-2009, 05:11 PM   #8
D16SiHatch
D16SiHatch's Avatar
Send a message via AIM to D16SiHatch
they should be tight, (80-85 ft/lbs ^), but i dont think i would say till you cant do it anymore by hand. if you're using a 1/2" ratchet then that might be about right. if you're using a 4-way however you could very well break off one of the studs. also, not all air guns are the same. setting the impact gun to its highest setting might not be advisable.
00 BMW 323i, black int, sport pkg, 5 speed
95 ej1, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, t3/t4 10psi
D16SiHatch is offline   Reply With Quote
Old 09-23-2009, 05:22 PM   #9
grog
grog's Avatar
is that for softer material or what? or is that just what those manufactures recommend?
Old 09-23-2009, 05:49 PM   #10
HackeN
HackeN's Avatar
Send a message via ICQ to HackeN
I use whatever. Sometimes a 3/8 socketwrench, sometimes a 1/2 impact. It's not like I sit there and hammer it down on the impact, only takes a split second or so.
But I never tighten mine too much, there's no reason to. I hate taking others off that are torqued down like crazy. Never had a problem w/ mine comming lose from the cheapest lug nuts available, to expensive ones, from stock steelies to aftermarket aluminum wheels.
People tent to over torque things thinking that it's going to fall off if they don't. It's like hearing about people snapping or stripping bolts/threads on their valve covers when they can be tightened down with your fingers basically. I personally use a screwdriver w/ 10mm socket on it to do mine just so i never do that ;x
HackeN is offline   Reply With Quote
Old 09-23-2009, 07:42 PM   #11
mother ef-er
mother ef-er's Avatar
^ w3rd. you can overtighten your lugnuts, but you gotta be a real "musle man". with the right tools you dont have to worry. use an eletric impact and let it max for a couple seconds. really, its not that big of a deal when using good tools.
or if youre tightening lug nuts with a torque wrench, just use standard specs. its kind of a simple theory..
mother ef-er is offline   Reply With Quote
Old 09-23-2009, 08:58 PM   #12
Ass$nyper
Ass$nyper's Avatar
To be honest I'm not sure but I've seen a few cars that aftermarket wheels ask for a few more ft lbs.
I've heard a few theories but I'll read up and try to figure it out.
-Max
Old 09-23-2009, 09:48 PM   #13
EL Vap133
EL Vap133's Avatar
Send a message via AIM to EL Vap133
Cross tighten them.
EL Vap133 is offline   Reply With Quote
Old 09-23-2009, 09:53 PM   #14
Ass$nyper
Ass$nyper's Avatar
Cross tightening or star pattern should be assumed.. least I hope
-Max
Old 09-23-2009, 09:59 PM   #15
apekd
Send a message via AIM to apekd
SLAP! your dumb
yeah thats the spec most people go by. Honda does about 100 ft lbs. Gray torque stick
seen it MANY times. it sucks!
yup. lol if people have rotas then yes, they NEED to me over torqued haha
apekd is offline   Reply With Quote
Old 09-23-2009, 10:01 PM   #16
Ass$nyper
Ass$nyper's Avatar
over torqued why?
I torque both my SW388s and Slips to the same 85 ft lbs.
-Max
Old 09-23-2009, 10:07 PM   #17
apekd
^It was a joke lol I dont like rota's very much. When I was in high school 2 years ago every kid and their moms had rotas. I thought the 17's and 18's where annoying till this stage. lol
Old 09-23-2009, 10:11 PM   #18
Ass$nyper
Ass$nyper's Avatar
Oh.
I had hoped you'd be able to solve the mystery of why some aftermarket wheels request a different torquing.
-Max
Old 09-23-2009, 10:15 PM   #19
apekd
Oh.
well the torque value depends on the stud and nuts strength mainly. but when the wheel is a different material (IE Aluminum) it tends to need less as when the rotor heats up the heat passes into the wheel. heat will soften the rim meaning you can actually warp the wheel if the studs are too tight. I know there is more info on this than my $.02 worth
Old 09-23-2009, 10:17 PM   #20
Ass$nyper
Ass$nyper's Avatar
That's what I assumed but a few cars I've had the aftermarket rims made sure to note using MORE ft lbs then OEM.
That's what I'm rather perplexed about.
-Max
Old 09-23-2009, 10:19 PM   #21
apekd
hmmm...i never really see MORE than OEM. maybe its so the weakling thiefs out there cant steal the rims?
Old 09-23-2009, 10:23 PM   #22
Ass$nyper
Ass$nyper's Avatar
LMFAO
-Max
Old 09-23-2009, 10:27 PM   #23
apekd
lol
I know that Blox extended studs need less from what I remember. Not sure if its just cause they are POS studs and break fast, or something else
Old 09-24-2009, 12:55 AM   #24
theft24
theft24's Avatar
Send a message via Yahoo to theft24
tighten till it bottoms out then 4-6 hits after that
theft24 is offline   Reply With Quote
Old 09-24-2009, 06:43 AM   #25
dacrxguy
dacrxguy's Avatar
wow i would never let you work on my car the spec is 80ftlb ii hope you never use a 500ftlb gun
some manufactures recommend cheking the tourque after 20 miles on aluminom wheels
ps3 name= dacrxguy
dacrxguy is offline   Reply With Quote
80, 99, accord, aluminum, car, lbft, lbs, lug, lugs, nuts, tight, tighten, tightening, torque, wheels
