Clock Light not working!
Old 10-24-2014, 02:57 PM
Canucksfan101's Avatar
Default Clock Light not working!
My clock light stopped working I think the day I took apart my dashboard. I'm not sure if I broke the something but I purchased new t3 led bulbs. I put them in and it did not work. I'm not sure what else to do. Do I have the bulb in the wrong way?
Old 10-24-2014, 03:21 PM
MIDNIGHTTUNER's Avatar
Default Re: Clock Light not working!
May sound way too simple, did you plug it in? Check the fuse for it too. I think it's wired with the radio(?). Might be wrong.
Old 10-24-2014, 06:36 PM
How would I check the fuse? I plugged everything back in. The hazard light doesn't light up anymore either.
Old 10-25-2014, 06:06 PM
To be sure, what model do you have? Year whatever... Umm, do the hazards work? The actual function I mean. You would check the fuse by pulling it out to see if it is corroded or broken. Look up a fuse diagram on here..
Old 10-25-2014, 06:49 PM
300K Honda's Avatar
My clock light also does not work. I replaced the bulb and that did not fix the problem. I would not think it is a fuse since the clock still works.
Old 10-26-2014, 01:59 AM
There's a small chance that the clock actually broke or the connections need to be cleaned. try that.?
Old 10-26-2014, 09:57 PM
Yes the hazard lights perform perfectly and the clock shows the time fine. But neither light up. I have 2002 SE accord 4dr
Old 10-26-2014, 10:10 PM
Retry the connections for the light. I'm not familiar with the clocks on the 02 Accords since I have been in one for 10 years. But if it worked before then something got knocked loose inside it. the alternative way is to just replace it with one on ebay since they generally aren't pricey. At least for my 97.
Old 10-27-2014, 12:08 AM
Okay, thanks for the reply. Could you help me find the clock part on eBay or other websites because I can only find previous generation clocks. I can't find the 02 accord clocks
Old 10-27-2014, 05:54 AM
speedfreek09's Avatar
Led bulbs can only go in 1 way. They are a diode which means if they are hooked up backwards they will not work.
Old 10-27-2014, 07:56 AM
Try what Speedfreek09 said first. But here is a clock for a 1999-'02 Accord. http://www.ebay.com/itm/1999-2002-Honda-Accord-Digital-Clock-Switch-Dash-Hazard-Switch-OEM-/261619256829?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ce9b90dfd&vxp=mtr
sky9
05-26-2010 12:36 PM
SLOAZZ95
10-06-2003 11:55 AM
E dwinbon G
05-27-2003 09:41 AM
gechalx
Audio / Security / Video
03-28-2002 09:05 AM
Quick Reply: Clock Light not working!
