> All Motor/ Naturally Aspirated
Old 09-16-2009, 12:51 AM   #1
itr1244
itr1244's Avatar
Default B20 VTEC oil leak !!!! HELP
i'm using GE 84mm headgasket made for b20 vtec. . but the oil seems to be tranny oil because i didnt lose noticeable mount of engine oil. but the tranny oil did get lower.. so i replaced the driver axle seal myself.. and it had leak so i took it to honda dealer to get it replaced. they told me if it still leaks my half shaft could be bad.. so sure enough there was leak still. so i replaced my half shaft and my axles as well. and now it is STILL leaking. i'm about to go insane. any input would be helpful. thanks guys.
car doesn't smoke. and i closed off the oil gallery as well and got the head decked.
itr1244 is offline   Reply With Quote
Old 09-16-2009, 12:45 PM   #2
itr1244
itr1244's Avatar
Default Re: B20 VTEC oil leak !!!! HELP
and i found oil infront of the block too where it says HM
Old 09-22-2009, 01:33 PM   #3
itr1244
itr1244's Avatar
took my oil sandwich adapter and took the o ring out and used gasket maker and i still see the oil leak. wtf
Old 09-22-2009, 04:55 PM   #4
itr1244
itr1244's Avatar
it seems like the oil leak started at the front passenger side conrner of the headgasket, it's the corner where you can see the headgasket itself.
if it's head gasket i am thinking the problem would be worse. apparently i had oil leak from everywhere. i fixed my tranny oil leak. and the oil sandwich adaptor.. now i still have this leak. it's probably cam seal..
Old 09-22-2009, 05:54 PM   #5
PyroProblem
1998 Honda Civic
My Garage
PyroProblem's Avatar
Facebook = too much drama and a waste of time
Sounds like you have a mess of oil leaking from several different spots...
Id suggest cleaning everything really really well and rediagnose the true source of the leak...
Did you have the block and/or head decked? If so the dowel pins may be keeping the headgasket from sealing properly...Did you use the correct headgasket?
98 Civic B16b. (92x85 build in progress)
07 Trailblazer SS (stock 400 hp LS2)
97 Eclipse GST (bolt-ons. Evo 3 16G upgrade coming soon)
PyroProblem is offline   Reply With Quote
Old 09-23-2009, 11:32 PM   #6
RED_90TEG
RED_90TEG's Avatar
Location: where i stunt SAND CANYON in Southern California
cam seal... and make sure all ur dizzy bolts are tight.. and ur valve cover gasket is new with silicone around the corners.. u must be new to hondas.. good luck
RED_90TEG is offline   Reply With Quote
Old 09-24-2009, 11:33 AM   #7
whitaker_1991
Did you use dowel pins when install you b20vtec? If you had the block decked or honed it is neceesarry to use a thicker head gasket because that has happen to me before. Judging from the location of the oil leak, it sounds like dowel pins to me as my friends b20vtec does that because he did not use dowel pins.
whitaker_1991 is offline   Reply With Quote
Old 09-24-2009, 11:34 AM   #8
whitaker_1991
Oh, if you did use dowel pins sometimes the dowel pins will not seat right and it will leak oil as well.
Old 09-27-2009, 09:45 PM   #9
itr1244
itr1244's Avatar
no.. not really new to hondas.. had my itr since 2001 and this is my 2nd rebuild ...
just new to b20..vtec i didn't have oil leak issue on my last itr build. but this b20 is just oil leak everywhere.
i am using GE 84mm H/G..
head has been decked. and block was checked for straightness.
i'm pretty sure the dowel pins were in place.
just replaced the dizzy O ring and all new gaskets for the valve cover. and cam seal.
so i replaced the cam seal and noticed i didnt use liquid gasket around the corner (passenger side under cam plate) so i applied it and it seems like its leaking even more. going to have to try re doing the liquid gasket...
Old 09-28-2009, 06:20 AM   #10
gutted-dx
gutted-dx's Avatar
sogybacon@hotmail.com sogybacon@hotmail.com
Did you install the plug into the head properly?
SHOPS I`VE DEALT WITH AND HAD GOOD EXPERIENCES!!!!!!!
*Phearable.net*Do It Dyno*Thmotorsports.com*KStuned*VIP Performance*
gutted-dx is offline   Reply With Quote
Old 09-28-2009, 10:31 AM   #11
itr1244
itr1244's Avatar
yes i had the machineshop guy to install that plug for me with Teflon tape.
and my compression ratio is 220 psi on all 4.
Old 10-01-2009, 08:12 PM   #12
gutted-dx
gutted-dx's Avatar
Any progress?
Old 10-01-2009, 11:49 PM   #13
RED_90TEG
RED_90TEG's Avatar
there is something that u can put all around the oil that will dry it up... like compleatly dry then u can c where the new oil is comeing from.. there are a few sensors near the dizzy and cam seal area.. im not sure if there is oil running behind them check those maybe its loose and oils comeing out?
Old 06-07-2010, 08:40 PM   #14
itr1244
itr1244's Avatar
i gave up on my car for a while.
i finally i took my car apart today. come to think of it now.. i think i know why my car was leaking!.
its the arp head stud. i blame myself for this cuz i was lacking knowledge about this.
i "hand tighten" it as it said on the instruction that came with arp bolt. and it said dont torque the stud down. so it got me confused.
you're supposed to tighten the stud all the way and back it up 1/4 turn so they are all even height.
when i hand tightened them they were NOT the same height.
so i am in a progress of fixing it. i'll let you guys know how it goes for sure.
Old 06-11-2010, 04:36 PM   #15
itr1244
itr1244's Avatar
i changed the head gasket. I am pretty sure i fixed the problem
now one problem lead to more problems for me.
i had to take off the vtec oil line and now i have leak from the oil line to the head.
and more from oil adaptor sandwich
Old 06-23-2010, 01:55 PM   #16
itr1244
itr1244's Avatar
Icon7 Re: B20 VTEC oil leak !!!! HELP
ok i FIXED the problem.
it was for sure the head stud being not installed correctly.
i just ran my car for the first time. i just put around 20 km. and no leak so far.
Old 06-23-2010, 02:00 PM   #17
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
Glad you got it fixed.
1994 Honda Accord EX - JDM H22A
- 204whp/157wtq
Originally Posted by toycar View Post
Breaking the bank, maybe. Feeling like a boss, likely.
nus_dogg is offline   Reply With Quote
Old 06-28-2010, 07:32 PM   #18
itr1244
itr1244's Avatar
ok
i lied.
my car is STILL bleeding.
someone just kill me
Old 06-28-2010, 08:50 PM   #19
Jimmy
Global Moderator
1994 Acura Integra
Jimmy's Avatar
iTrader Rating: (2)
dangjimmy
ok
i lied.
Shit man, that sucks.. Hope you get your issues worked out. I feel the same damn way.. My car has been a real headache these past few days
2004 Acura TL - Daily
1994 Integra RS - Track car
instagram: @jimmydudley
My build thread: 94 Integra RS sloow build-up
Originally Posted by Danza
The Man can't hold you down when you're flossing the bright green belts dawg
Jimmy is offline   Reply With Quote
Old 06-29-2010, 06:25 AM   #20
slowcrx954
slowcrx954's Avatar
Send a message via AIM to slowcrx954
I bet its your dizzy,take the cap off and I bet there will be oil.get a new dizzy.
slowcrx954 is offline   Reply With Quote
Old 06-29-2010, 11:10 AM   #21
itr1244
itr1244's Avatar
hrmm i'm pretty sure it's ok at the dizzy i have replaced the o ring on that too but i'll check again.
any input would be appreciated thanks guys
Old 07-01-2010, 12:09 PM   #22
itr1244
itr1244's Avatar
your bet is wrong.
my dizzy is completely dry
here's my update
http://honda-tech.com/showthread.php?t=2270330
Old 07-05-2010, 02:10 PM   #23
FMN716
FMN716's Avatar
have you tried changing your head gasket to the oemversion for your block, forgot to ask are you running a breather kit
FMN716 is offline   Reply With Quote
Old 07-05-2010, 05:46 PM   #24
xzodiackillerx
xzodiackillerx's Avatar
could be this! I have seen many people blow oil out of everywhere because of the no OEM breather on the B20vtec
xzodiackillerx is offline   Reply With Quote
Old 07-05-2010, 10:03 PM   #25
FMN716
FMN716's Avatar
Yes my suggestion read over the Reliable guide to building a ls/vtec
you might get some other answers there but I think its also a good Idea to do the following
*Check that the block and head is not warped
*Use the GE dowel pins and get the OEM Gasket for your block which you will have to modify slightly, GE uses the vtec gaskets which are incorrect as you have the ls/crv block
*You need an oil catch tank/breather tank as the ls/crv head had its own kind of breather kit and the vtec head does not use this system in the head, your motor needs to breathe so give it lungs lol
96, accord, b20, b20vtec, civic, dowel, headgasket, honda, leak, leaking, ls, motor, oil, pins, type, vtec
