Alternator Fuse keeps blowing 97 EX coupe
Old 09-14-2009, 04:11 PM
RedneckRicer's Avatar
Default Alternator Fuse keeps blowing 97 EX coupe
so the civic keeps popping the 7.5 amp fuse #15. I read the service bulletin about the fix. i pulled the wiring harness all apart and the wires look fine. alternator wire looks fine. no breaks or cracks in any of the wires.
Took out alternator and battery to get tested they both tested out just fine.
So i retaped everything back up popped in a new fuse and still pops
Any other ideas?
Old 09-14-2009, 05:24 PM
Former User's Avatar
Default Re: Alternator Fuse keeps blowing 97 EX coupe
Along with fuse 15 popping, are you also getting any of the accompanying CEL codes (VSS, O2 sensor, or ELD) mentioned in the TSB?
Old 09-14-2009, 05:32 PM
Nope Not a single CEL
Old 09-14-2009, 05:38 PM
Is turning the key to ON(II) sufficient to blow fuse 15? Or do you have to start the engine and drive the car? Does it blow quickly or does it take some time?
Old 09-14-2009, 05:42 PM
just turn the key on and the fuse blows
Old 09-14-2009, 05:48 PM
Unplug the connectors for the alternator, VSS, and both O2 sensors (see below). Does this prevent fuse 15 from blowing?
Old 09-14-2009, 05:51 PM
i will have to check that one out. i did not try that. so i will try that and report back.
Old 09-14-2009, 05:52 PM
mvtck's Avatar
the wire rubs on the top of the bracket from intake to the block. should be right at the connector
Old 09-14-2009, 05:54 PM
which wire are you referring to that rubs? cause i didnt see any rubbing on the wires.
Old 09-14-2009, 06:06 PM
He's talking about the wires discussed in the TSB.
Old 09-14-2009, 06:07 PM
ooo ok.. well i seen the word WIRE..lol thought there was a specific wire
Old 09-14-2009, 06:28 PM
mvtck's Avatar
have you see the tsb
Old 09-14-2009, 06:40 PM
yes i have.. did you not see my first sentance?
Old 09-20-2009, 10:24 AM
craigers2k's Avatar
I am also having the same fuse 15 problem, I also took a look at all my wires, look good. Good battery and alternator. But I am getting an O2 sensor cel. I must drive the car to blow the fuse and it usually blows within a quarter mile. Any ideas?
Old 10-29-2009, 03:25 PM
pvt.horta's Avatar
im having the same problem someone help!!!!!!!!
Old 10-29-2009, 04:09 PM
Read this TSB.
Old 10-29-2009, 05:35 PM
pvt.horta's Avatar
it takes a while to blow .... my computer is chipped and tune so i dont got the o2 sensor deleted
Old 04-09-2014, 05:57 PM
motocrossracer9's Avatar
Mine is doing the same thing it takes a couple mins to blow I stepped up to a 15 amp it blew that too any ideas ?
Old 04-09-2014, 06:00 PM
Bad idea - fire hazard and risk of frying the wires.
Did you read the thread? Click the Fuse 15 link in my signature.
Old 04-09-2014, 08:16 PM
Oh ok the link wouldn't work the first time for me it did then . So this is a common thing huh ? Is there any particular spot where it rubs ?
Old 04-09-2014, 08:19 PM
Read the TSB and then go from there.
AjHawk
68
10-14-2019 11:29 AM
mtownsi
09-23-2012 03:48 PM
Civic Racer X 7
13
06-01-2011 04:56 AM
w0ng_sta
11-08-2006 05:29 PM
Quick Reply: Alternator Fuse keeps blowing 97 EX coupe
