Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic (2001 - 2005)
Old 09-12-2009, 09:50 AM   #1
Shaynepolevault
Shaynepolevault's Avatar
Default 2001 civic power door lock fuses?
i have a 2001 civic lx, my power door locks do not work. When ever I click the button I here a click that comes from under neath the dash, im assuming thats the relay. So where are all the fuses and relays associated with the power door locks? I want to check those before i go and buy a new switch. So please help thanks.
EJ6 Team #137
Shaynepolevault is offline   Reply With Quote
Old 09-12-2009, 09:53 AM   #2
It Wasn't Me
Default Re: 2001 civic power door lock fuses?
Read the FAQs for Fuse Info
It Wasn't Me is offline   Reply With Quote
Old 09-12-2009, 10:17 AM   #3
Shaynepolevault
I did read that it dosnt have any related to power door locks on it. I looked through it twice and there was nothing. So if you know where the fuses or relays for the power door locks are let me know? thanks
EJ6 Team #137
Old 09-12-2009, 12:22 PM   #4
Shaynepolevault
no body knows what fuses and relays go to the door locks
EJ6 Team #137
Old 09-12-2009, 03:25 PM   #5
It Wasn't Me
Originally Posted by Fuse Info from the FAQs
Old 09-12-2009, 08:30 PM   #6
Shaynepolevault
WOW im sorry I was looking at the fuse diagram in the car, not under the hood. feel like an idiot. Ok so my door lock fuse is good, and when I push the door lock button in my car the relay under the dash makes 2 clinking noises, but my locks dont move. So does this mean I need a knew actuator, or new door lock switch? I want to get these working let me know thanks.
EJ6 Team #137
Old 09-13-2009, 09:28 AM   #7
Shaynepolevault
also to go along with i wrote above. What is a good way that I could test the actuators on my doors to see if they are good? Because bothe passenger and driver dont work so it makes me think that its not the actuators but I want to test them to make sure.
EJ6 Team #137
Old 09-13-2009, 05:15 PM   #8
Shaynepolevault
Icon2 test 2001 civic door lock actuator
How could i test my door lock actuator? When i click the lock button it makes a click sound under the dash but nothing happens, all fuses and relays are good. so i wanted to know if i could test the actuator? let me know thanks.
EJ6 Team #137
Old 09-14-2009, 02:15 PM   #9
90sedan
90sedan's Avatar
Send a message via AIM to 90sedan
To test the actuator, hook direct power to it. Do this by disconnecting the 2-pin connector and applying leads to the pins, reverse polarity to change direction of the actuator. If no movement of the power door lock occurs than it will need to be replaced.
I would also test to make sure power is getting to the actuator. Test for voltage at the 2-pin connector on the harness when the switch is pressed.
9/10 times the actuator's are faulty and need to be replaced.
SpeedFactory Tuning and Race Fabrication
90 Ef Sedan
vitara d16
90sedan is offline   Reply With Quote
Old 08-20-2013, 01:08 PM   #10
astateofmind
Did you fix it after all? What was the problem?
astateofmind is offline   Reply With Quote
2001, 2003, 2005, actuator, civic, door, fuse, honda, location, lock, locks, power, relay, test, tsx
Similar Threads
95 civic ex sedan - Power locks not working jordy478 Honda Civic/Del Sol (1992 - 2000) 6 02-23-2014 07:00 AM
Door Lock Issues. Loy Tech/Misc 0 02-03-2014 08:25 AM
92 95 civic hatch power door conversion help!! crazyLemons4.20 Honda Civic/Del Sol (1992 - 2000) 5 06-06-2013 10:53 AM
Power door lock issues 1slo22cl Acura Integra 6 04-30-2013 06:26 PM
Power door locks and 3 power windows do not work, 1 power window does work though... jermo Honda Civic/Del Sol (1992 - 2000) 7 09-25-2012 09:27 PM
