Old 03-25-2015, 10:58 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
***Resetting SRS Light**
Old 11-23-2002, 01:16 PM
  #26
Audio28's Avatar
Default Re: ***Resetting SRS Light** (DevinW)
i tried going to to best buy to buy the scs service connector, but everyone there had no clue of what it is. What dept has this item? Thanks
Old 11-23-2002, 01:28 PM
  #27
vladd's Avatar
Default Re: ***Resetting SRS Light** (iam7head)
got it on my third try! thank dude...excellent step by step answers.
Just have to remember not to listen to the radio while taking out the seat
next time...lol <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/embeer.gif" BORDER="0">
why would taking the seat out make the srs light go on?
Old 11-23-2002, 01:36 PM
  #28
vladd's Avatar
Default Re: ***Resetting SRS Light** (dogpile5)
if you are concerned about removing your air bags, this will only work if you have already safely removed the airbags. once you have unplugged and removed them you will need to reset the SRS light. or so i heard, i haven't removed my airbags.
[Modified by dogpile5, 12:20 AM 9/4/2002]
you can't reset the srs light if you're missing airbags. either you have to put the airbags in or get a certain kind of resistor for each airbag to fool the control module into thinking you have airbags.
Old 11-23-2002, 02:29 PM
  #29
HT White Ops
BlackDeuceCoupe's Avatar
STICKY Candidate IMHO!
Modified by BlackDeuceCoupe at 5:38 PM 12/4/2003
Old 11-23-2002, 04:43 PM
  #30
dcsports's Avatar
nice dude my mom had that **** on her oddesey but we took out the light bulb
Old 11-23-2002, 06:38 PM
  #31
jovial111's Avatar
Default Re: ***Resetting SRS Light** (VTeC SIR)
ok, my airbag is blown thanks to a slow crash... i'm going to get a jdm non srs airbag sometime soon so what kind of resistors should i get and where do i install them to kill my bright red light?
Old 11-23-2002, 06:58 PM
  #32
Patron's Avatar
Default Re: ***Resetting SRS Light** (jovial111)
You could always just pull the bulb
Old 01-03-2003, 09:46 AM
  #33
gatorbill's Avatar
Dogpile5 RULES !!!
Just purchased a 96 Honda Civic with this problem and fixed it following these instructions in a few minutes.
Old 01-03-2003, 10:34 AM
  #34
ransack's Avatar
Default Re: ***Resetting SRS Light** (dcsports)
wOoT
thanks man, mines been on since I bought the car. I hope this works!
Old 01-03-2003, 01:30 PM
  #35
gatorbill's Avatar
Default Re: ***Resetting SRS Light** (ransack)
BTW: I did not go out and buy or make the SCS Service Connector. I just took a "Jumbo" paperclip and bent it into a U shape that had the open end prongs spaced the same distance as that of the MES connector sockets. The "Jumbo" paperclip is ideal for this because its thicker and stiffer than the normal paperclips thereby making a perfect tool for this application.
Old 01-03-2003, 01:36 PM
  #36
gatorbill's Avatar
Default Re: ***Resetting SRS Light** (Audio28)
Audio28: You do not have to buy or make the SCS Service Connector. I just took a "Jumbo" paperclip and bent it into a U shape that had the open end prongs spaced the same distance as that of the MES connector sockets. The "Jumbo" paperclip is ideal for this because its thicker and stiffer than the normal paperclips thereby making a perfect tool for this application.
Old 03-12-2003, 08:26 AM
  #37
dogpile5's Avatar
Default Re: ***Resetting SRS Light** (gatorbill)
bump. hope it helps a new batch of honda owners..
Old 04-01-2003, 12:19 PM
  #38
Brewer's Avatar
AAAAGGGHHHH! My light has been on forever, and I want to reset it, but the plug won't come out of the fuse box! What can I do? I push in the little release button and pull and wiggle it all I can but it won't budge!
Old 04-02-2003, 11:18 AM
  #39
Brewer's Avatar
Default Re: ***Resetting SRS Light** (BrewerHatch)
what if you pull the MES plug, plug in the SCS, turn the key to on and the SRS light never goes off?
[Modified by BrewerHatch, 2:21 PM 4/2/2003]
Old 04-02-2003, 11:22 AM
  #40
j_ambrose's Avatar
Good read!
Old 04-02-2003, 12:45 PM
  #41
igone916's Avatar
hey the pix does not show...how can i see the pix...
Old 04-02-2003, 12:49 PM
  #42
dogpile5's Avatar
Default Re: ***Resetting SRS Light** (igone916)
the original post pictures were linked from another site back in september.. pics probably got moved or deleted. the directions should be suffice w/o pics.
Old 04-02-2003, 08:17 PM
  #43
Brewer's Avatar
No help for me?
Old 04-03-2003, 10:40 AM
  #44
Brewer's Avatar
Can someone post a pic of the yellow plug (MES)? I think I may have the wrong one. It's supposed to be on the fuse box under the dash on the driver's side correct? I have a '93 Civic and the picture I saw looked nothing like mine...
Old 04-03-2003, 11:03 AM
  #45
Brewer's Avatar
This is the only yellow plug I see:
Old 04-03-2003, 11:04 AM
  #46
Brewer's Avatar
Somebody tell me that's the wrong plug so I can find the right one!
Old 04-03-2003, 11:29 AM
  #47
94cxhybrid-T's Avatar
that one in your hand is linked to the airbag itself dont test that one. i just looked on my hatch and on the lower right side of the fuse block inside the car there is a yellow plug that is plugged into a dummy connector. I think that is the one. it has two gray wires comming out of it. HTH
[Modified by 94cxhybrid-T, 12:36 PM 4/3/2003]
[Modified by 94cxhybrid-T, 12:39 PM 4/3/2003]
Old 04-04-2003, 02:10 PM
  #48
TheOne's Avatar
Default Re: ***Resetting SRS Light** (94cxhybrid-T)
how the $%#@ do you get the yellow plug off, I am soooooooo pissed I am going to break it, I dont see a tab to push or anything.
Old 09-16-2003, 08:59 AM
  #49
xbladr's Avatar
Default Re: ***Resetting SRS Light** (TheOne)
I am gonna try it this weekend thanks guys
Old 09-16-2003, 01:05 PM
  #50
feriocious's Avatar
Default Re: ***Resetting SRS Light** (xbladr)
hey quick q for you guys: i just got a JDM cluster and it has no SRS plugs. will my airbags still deploy? the yellow plugs are just for the indicators right?
Quick Reply: ***Resetting SRS Light**
