forgot..whats the size of the oil drain plug on a 97 civic again??
Old 08-26-2002, 06:56 PM
sleeepy's Avatar
Default forgot..whats the size of the oil drain plug on a 97 civic again??
13?
[Modified by sleeepy, 3:57 AM 8/27/2002]
Old 08-26-2002, 07:03 PM
Bleed Black's Avatar
Default Re: forgot..whats the size of the oil drain plug on a 97 civic again?? (sleeepy)
head or thread? the head is a 17mm I believe.
Old 08-26-2002, 07:18 PM
sleeepy's Avatar
Default Re: forgot..whats the size of the oil drain plug on a 97 civic again?? (slowasshatch)
whatever the size that gets that thing off.
piscorpio's Avatar
yup
Old 08-27-2002, 12:51 PM
sleeepy's Avatar
Default Re: forgot..whats the size of the oil drain plug on a 97 civic again?? (piscorpio)
dammit..its not right anyone know how to get that thing off with..trying to do my first oil change. thank youuu
Old 08-27-2002, 12:55 PM
Get a few sockets (13-17mm) and put them on until one works.
Old 08-27-2002, 05:43 PM
jweller's Avatar
you can get 90% of every bolt on a honda with 8,10,12,14,17,19 mm sockets/wrenches. If it's not 17, try 19, that would be the same size as your lug wrench in the trunk, at least on my accord it is. if it's not 14, 17 or 19, somebody changed it for a non honda part.
Old 08-27-2002, 10:29 PM
Dudz's Avatar
Default Re: forgot..whats the size of the oil drain plug on a 97 civic again?? (jweller)
It's 17mm on my 99 civic
Old 08-27-2002, 10:37 PM
Youre trying to loosen the large bolt directly in the middle of the oil pan correct? If you cant do that then I would recomend you hold off on doing your first oil change. I can just see you unbolting all the little bolts that hold the oilpan to the block
elmalouno
04-26-2009 07:08 AM
n-line4
04-14-2008 07:02 PM
Clairvoyant
15
06-21-2006 09:42 AM
Mt3c
10-15-2003 01:52 PM
Quick Reply: forgot..whats the size of the oil drain plug on a 97 civic again??
