Is this good enough for 450??
My About to drop my motor in im wondering if i pull the number im hoping for my setup is going to be on these injectors. I know the SC61 take me there but will i max out injectors beforehand? Thinking about picking up new injectors before my tuning date whick is the 19th Mods are
B18B Block stock sleeve 81.55mm
Polished and Balanced LS Crank
Clevite Bearings
Eagle Rods
CP 9:1 Pistons
Type R oil pump
GSR Water Pump
GSR Timing Belt
GSR Headgasket
LS Thermostat
GSR HEAD
GSR Cams
Skunk 2 Cam Gears
Supertech Valvetrain and Valves
Stock dizzy with new coil and rotor
ARP Headstuds
Rc 750cc injectors
Pfab Ramhorn
Turbosmart 38mm wastegate
Greddy Type s bov
Precision SC61
Greddy ic piping
3inch downpipe
Omnipower 4bar map
Clevite Bearings
Eagle Rods
CP 9:1 Pistons
Type R oil pump
GSR Water Pump
GSR Timing Belt
GSR Headgasket
LS Thermostat
GSR HEAD
GSR Cams
Skunk 2 Cam Gears
ARP Headstuds
Rc 750cc injectors
Pfab Ramhorn
Greddy Type s bov
Precision SC61
Greddy ic piping
3inch downpipe
Omnipower 4bar map
93B18
12-26-2001 11:04 PM
