car kind of feels like it's jerking on highway driving
Old 08-19-2009, 10:23 PM
mynameizstitch's Avatar
Default car kind of feels like it's jerking on highway driving
ok got a b16a3 with itr cams, dc header, aem cai just tuned on crome with a p28 ecu. when i drive on the freeway sometimes i feel like the car is jerking a little. it's not a lot at all but it's enough to just notice it. with my stock ecu everything runs fine and smooth. after the tune is when it now sometimes feels a lil wierd (hard to explain) but all i know is that it feels kind of like a "jerk" on the car when accelerating at a steady speed. i will check my spark plugs soon to see if they are fouled out since it seems like the car is running a lil rich after the tune.
***car is not throwing any engine check light codes and stuff like that. to me it seems like the car is running a lil rich.
Old 08-19-2009, 11:37 PM
Sleeperzzz95's Avatar
Default Re: car kind of feels like it's jerking on highway driving
Tire may need air/too much air. Alignment. Wheel balanced. Camber. I dont think the motor or tune has to do with anything with your car jerking. But i could be wrong lol
Old 08-20-2009, 01:48 AM
.hawaii's Avatar
alot of the times its the simplest thing. check your throttle cable/cable bracket to see if its stuck. :p
Old 08-20-2009, 01:58 AM
92slowcivic's Avatar
i *think* he means the engine is not pulling smoothly, not that the car jerking from one side to another (such as needing an alignment.) then again, i could be wrong.
Old 08-20-2009, 05:50 AM
Crossbreeder's Avatar
Im taking it as suspension issue. SHake your front end down.. If you know what I mean. You could need a wheel bearing.. inner and or outer tir rod. It could be a bumber of things. But im not taking it as a motor issue.
Old 08-20-2009, 06:18 AM
andoxviii's Avatar
A bad TPS will cause the car to jerk a little bit on constant throttle...I'm having this issue right now with my Y7.
Old 08-20-2009, 07:30 AM
car just got an alignment 3 months ago. i will check my tire pressure.
Old 08-20-2009, 08:36 AM
Gunmetal_B20_Hatch's Avatar
get a wideband & verify AFRs
Old 08-20-2009, 08:44 AM
Hmmm after i reread your post..Now it sounds Like the Car is hesitant. Buckin so to speak. What gas is your car tuned on an what gas do you have in car? Bad gas mixure?
Old 08-20-2009, 04:14 PM
always using 91 octane gas and im pretty sure it was tuned on that since cali dont have anything higher.
Old 08-20-2009, 04:15 PM
here is my graph of the dyno tune bottom parts read air fuel which i dont know howt o read it haha
Old 08-20-2009, 05:28 PM
would need to know AFRs @ cruising speed.
Old 08-20-2009, 06:13 PM
Christopherian1982's Avatar
Im also having the same problem..
Old 08-20-2009, 08:23 PM
Thizzed Out's Avatar
I'm also having this problem, it seems like the engine is jerking a tiny bit just enough to notice. How would I go about testing the TPS?
Old 08-23-2009, 04:29 AM
so you're saying it's the engine not pulling smoothly and not a suspension or alignment issue? there still seems to be some confusion.
i had a problem with my tps on my gsr swap a couple times and i didn't even need to replace it, it just needed to be cleaned.
Old 08-27-2009, 06:16 PM
How do you clean it where do you spray and what do you use to clean it with?
sean2000gt
05-22-2014 06:35 AM
d16sandrail
07-12-2009 07:13 AM
Kr4nG
05-08-2008 02:17 PM
beatsperdream
10-18-2006 01:14 AM
friedsqrl
03-13-2003 10:56 PM
Quick Reply: car kind of feels like it's jerking on highway driving
