2004 Accord EX Shudder on Acceleration
Old 08-17-2009, 07:39 PM
srquinton's Avatar
Default 2004 Accord EX Shudder on Acceleration
I have a 2004 Honda EX with auto transmission. My issue is a shudder that occurs when accelerating (even gently) between 50-60 miles an hour (roughly 2k – 3K RPM). The shudder stops if I take my foot off the gas. It also stops when the car shifts into the next gear at about 60 mph. It does not occur when ‘coasting’ (not accelerating) in that speed range. The shudder does not occur in that RPM range at other speeds or in other gears. It does not feel like the engine is stumbling or losing power, but it is a bit disconcerting. The Honda mechanics drove the car and experienced the problem but don’t have an answer. Per the mechanics, the transmission checked out okay and there were no suspect diagnostic codes. Tires were balanced and rotated – several times—without resolving the problem.
I’ve seen similar issues discussed with older Accord models, with suggestions of O2 sensors, throttle position sensor, clogged EGR ports, CV joints and axles. Not sure if any of the above apply here or how to check. Ideas?
Thanks
Old 08-18-2009, 12:03 AM
FishyMan's Avatar
Default Re: 2004 Accord EX Shudder on Acceleration
Fuel injectors?
Has it had a tuneup?
It seems like a spark/gas/combustion issue. Find another mechanic. Any CEL? It could be oil in the plug tubs. Is it misfiring?
Old 08-18-2009, 08:10 AM
srquinton's Avatar
Thanks for the reply. The car is current with all scheduled maintenance (by the dealer) and runs well other than this specific event under these specific conditions. No CEL or other diagnostic errors noted.
Old 08-24-2009, 10:37 AM
phootbag's Avatar
You will likely find galling on the inner cv joint in one or both axles. Based on your symptom description and my experience...
Chris Mason13
06-18-2017 05:49 PM
JDM_Mugen_CD6
10-02-2016 12:35 PM
hwright
05-15-2013 03:50 PM
NSL727
08-06-2008 05:03 AM
Quick Reply: 2004 Accord EX Shudder on Acceleration
