rear disc brakes
Old 08-11-2009, 08:50 PM
whyS0serious's Avatar
Default rear disc brakes
ok since i don't want to use the 90-93 teg rear disc brakes i want to use the 90-91 crx si one onto my 90-91 civic si...
everything will bolt on correct?
all i need is the 4040 prop from the crx?
Also, do i need the 90-91 crx si ebrake line also? or the 90-91 civic si is the same?
I've did the search bar but everyone did the 90-93 integra
If I'm missing anything please inform me thanks in advance!
p.s... I'm doing the crx si rear dis brakes because i want to keep it EF all the way don't want to put a DA part onto a EF car
Old 08-11-2009, 08:57 PM
Canadian_EF's Avatar
Default Re: rear disc brakes
Also, do i need the crx si ebrake line also? or the civic si is the same?
these rear brake things are so unclear... i guess the basic rule of thumb is... whatever you get the brakes from, be sure to get all the matching lines, cables, and prop valve?
Old 08-11-2009, 08:59 PM
Vietnamese!
ALLxMOTOR EG's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
lunalink's Avatar
well good luck finding yourself those si's i used 96 GSR rear disc, they bolt right up and yes you need the si cables the tegs are too long, and you also need a 40/40 valve you can get that off any non-abs DA thats what i just put on my car today..
Old 08-11-2009, 09:04 PM
Vietnamese!
You know EF and DA are like brothers most of the parts are compatible with each other.
Old 08-11-2009, 09:36 PM
frank_el_tanke's Avatar
I believe the rotors and calipers from the 90-91 crx si and DA are the same, the only noticeable difference is the rear trailing arm bushing. DA's have a larger diameter bushing.
You would need to use DA e-brake cables because the ones from the crx are too short, and the 4040 prop valve comes from the 90-93 integras.
You can keep your upper and lower control arms, and solid brake fluid lines... i think i'm missing some info
Old 08-11-2009, 09:44 PM
enigma2446's Avatar
OK.....Yes im new to all this but can someone please list all the parts i need to do the rear disk conversion........and the cars they come off of please!!!!..........HELP
Old 08-11-2009, 09:58 PM
lunalink's Avatar
search.. they have a how-to guide..
Old 08-12-2009, 06:18 AM
THANK YOU frank_el_tanke FOR THE ONLY ONE RESPONDING TO THE QUESTION AND GIVING AN ANSWER
Old 08-12-2009, 06:21 AM
kaiba's Avatar
You can use any rear disc from the integra 89-01 and civic 88-00. DA does have the larger trailarm bushing.
Used the CR-X Si parking cable and brake line.
Old 08-12-2009, 07:02 AM
liquidrider's Avatar
I have a pair of Koni Yellow struts with skunk2 coils from a car I bought at a salvage auction, they were off an EK coupe. Which rear disc conversion should I do that will allow me to use these on the rear? From the looks of it, the EF bushing for the strut mount is wider than the EK.
freak86
04-12-2008 11:55 AM
mxler8
21
10-17-2004 07:46 AM
Jamison182
04-07-2003 07:11 PM
VisualEcstasy
03-21-2003 09:57 PM
happyclown_69
03-12-2002 08:21 AM
Quick Reply: rear disc brakes
