Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Ridgeline : MDX : Odyssey : Pilot : RDX
Old 08-10-2009, 09:54 AM   #1
jeddy0120
jeddy0120's Avatar
Send a message via AIM to jeddy0120
Default Timing marks on CRV
I was wondering if anyone knows which of the timing marks on the cam gears to use when doing a head gasket on the K24 in the CRV.
Any help would be appreciated.
Thanks
03 SSM EP3
jeddy0120 is offline   Reply With Quote
Old 08-14-2009, 01:33 AM   #2
civic95hbvtec
civic95hbvtec's Avatar
Send a message via AIM to civic95hbvtec
Default Re: Timing marks on CRV
Might check the rsx/tsx forums, motor is a little diffrent in size but
the timing marks will be the same.
Hondata79 ---> NWSR --- Englishracing.net
civic95hbvtec is offline   Reply With Quote
Old 08-14-2009, 06:05 AM   #3
90sedan
90sedan's Avatar
Send a message via AIM to 90sedan
Probably found it by now, but here it is anyways.
2002 CR-V - Cam Chain Installation
NOTE: Keep the cam chain away from magnetic fields.
  1. Set the crankshaft to top dead center (TDC). Align the TDC mark (A) on the crankshaft sprocket with the pointer (B) on the cylinder block.
  1. Set the camshafts to TDC. The punch mark (A) on the variable valve timing control (VTC) actuator and the punch mark (B) on the exhaust camshaft sprocket should be at the top. Align the TDC marks (C) on the VTC actuator and exhaust camshaft sprocket.
  1. Install the cam chain on the crankshaft sprocket with the colored piece (A) aligned with the punch mark (B) on the crankshaft sprocket.
  1. Install the cam chain on the VTC actuator and the exhaust camshaft sprocket with the punch marks (A) aligned with the center of the two colored pieces (B).
SpeedFactory Tuning and Race Fabrication
90 Ef Sedan
vitara d16
90sedan is offline   Reply With Quote
Old 08-24-2009, 02:50 PM   #4
lemmyb
Good stuff bro. Thanks
lemmyb is offline   Reply With Quote
2001, 98, camshaft, center, crv, dead, forum, honda, mark, marks, position, set, tdc, timing, top
