Old 08-09-2009, 10:51 AM   #1
clair
Default Radiator fan not working while driving
The radiator fan in my 94 accord seems not working during drive. I have to make frequent stops to cool down the engine. I am puzzled that everytime when I turn off the engine, the radiator fans starts to work. How can I fix that? Thanks a lot!
clair is offline   Reply With Quote
Old 08-10-2009, 09:30 PM   #2
Bullies4u2
Default Re: Radiator fan not working while driving
my 96 accord ex with f22b1 vtec does not seem to run the fan either, but it does not run above half way on the temp reeding. so ill watch what help you get & maybe ill learn something myself
Bullies4u2 is offline   Reply With Quote
Old 08-10-2009, 11:01 PM   #3
alkoholikwun
alkoholikwun's Avatar
check the fan switch and/or thermostat
alkoholikwun is offline   Reply With Quote
Old 08-11-2009, 01:06 AM   #4
YeuEmMaiMai
the fan will not run when the car reaches between 38-42mph below those speeds it should run as needed
YeuEmMaiMai is offline   Reply With Quote
Old 08-12-2009, 05:23 AM   #5
96redexcivic
check your fan for a quick check may be it's sticking, turn the a/c switch on and check if both fan comes on, also turn it with your hands to see if it's free wheeling good not sticking, and i will check your cooling temp. sensor for the fan and or relay might be sticking. good luck.
96redexcivic is offline   Reply With Quote
Old 08-12-2009, 06:16 AM   #6
7520
I have a 1992 accord, my fans both come on with the a/c, and both even work sometimes when the a/c is off. Neither fan works when I turn the car off. Is that a sensor? If so, where is it located?? tks
7520 is offline   Reply With Quote
Old 08-12-2009, 07:37 AM   #7
96redexcivic
Icon6 Re: Radiator fan not working while driving
Fan coming on after you turn off vehicle is normal for alots vehicle, the cooling temp. sensor is located near the thermostate should have two wires connector, but, I think I will check the thermostate maybe is bad (sometime sticking) change it, it's only couple bucks.
Old 08-12-2009, 09:24 AM   #8
SFWD 1934
SFWD 1934's Avatar
Check the relay that is in the engine compartment fuse box. It is either number 20 or 21 in the diagram here:
http://www.hondapartsnow.com/Page_Pr...(Engine%20Room)
Jason
9.86 @ 152
JRL Tuning 510-459-7229
fluidampr.com
jgenginedynamics.com
full-race.com
turboxs.com
hondata.com
deist.com
dragsport.com
http://images.honda-tech.com/set1/smile/emthup.gif
SFWD 1934 is offline   Reply With Quote
1994, 2000, accord, acura, civic, del, fan, fans, honda, radiator, run, sol, tl, turning, working
