Spak Plug Gap size?
Spak Plug Gap size?
I wanted to make sure.
I bought some spark plugs at autozone they are gapped at .40
Is this the right size for a 1990 honda civic 4 cycl 1.5L?
I checked around and didn't find a definte answer.
I don't have the owner's manual, and nothing under the hood to check as some one stated in google.
Re: Spak Plug Gap size?
Ah i tried sir.
I could not find a definite answer found one for a 91 saying .44
I had a manual for it a long time ago.
And a little strapped for cash currently sir.
if you would have just bought some ngk spark plugs you wouldn't have to worry to much since they already come pre gaped at .044. but even in the book, it says anywhere between .040-.044 for gaping.
*edit* just set it at .044
H-T White Ops
Almost all Hondas use a .044 gap. This includes all US '88-'91 Civics and CRXes.
I'm not a 4th gen person, but I think I might have gotten this all right (engines are matched correctly to the part numbers and gap).
I figured I might as well just list all the gaps and NGK part numbers that are covered in this section.
D15B1 - 1.5L SOHC
(1988-1991 Civic STD)
- BCPR6ES-11 / 6779 (NGK Standard Copper - Copper Core)
- BCPR6E-11 / 5632 (NGK V-Power - V-Cut Electrode)#
- BCPR6GP / 7088 (NGK G-Power Platinum - Single Platinum)
- BCPR6EIX-11 / 4919 (NGK Iridium IX - Single Iridium)
- BCPR6EP-11 / 3350 (NGK Laser Series - Platinum & Iridium)*
GAP : 0.044
D15B2 - 1.5L SOHC
(1988-1991 CRX DX)
(1988-1991 Civic DX/LX)
(1988-1991 Civic Wagon 1.5 2WD)
GAP : 0.044
D15B6 - 1.5 SOHC
(1988-1991 CRX HF)
- BCPR5ES-11 / 6696 (NGK Standard Copper - Copper Core)#
- BCPR5E-11 / 1273 (NGK V-Power - V-Cut Electrode)#
- BCPR5EGP / 7086 (NGK G-Power Platinum - Single Platinum)
- BCPR5EIX-11 / 3306 (NGK Iridium IX - Single Iridium)
- BCPR5EP-11 / 2097 (NGK Laser Series - Platinum & Iridium)*
GAP : 0.044
D16A6 - 1.6L SOHC
(1988-1991 CRX Si)
(1988-1991 Civic EX/Si)
(1988-1991 Civic Wagon 1.6 4WD)
GAP : 0.044
D15B1 - 1.5L SOHC
GAP : 0.044
D15B2 - 1.5L SOHC
(1988-1991 CRX DX)
GAP : 0.044
D15B6 - 1.5 SOHC
(1988-1991 CRX HF)
GAP : 0.044
D16A6 - 1.6L SOHC
(1988-1991 CRX Si)
GAP : 0.044
projected3
10-02-2010 09:50 AM
