Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Location of Blower Motor Resistor?
Old 08-05-2009, 07:22 AM
tien285's Avatar
Default Location of Blower Motor Resistor?
Hey guys,
My a/c & heater no longer blows out air on my 2002 tl. I'm going to try and change out the blower motor resistor but don't know where it's located at. I will first try this then (through research) will see if the harness/ connection points are melted to see if I need a new one. Any other ideas. Thanks
Old 08-06-2009, 10:01 AM
bryse68's Avatar
Default Re: Location of Blower Motor Resistor?
does the blower operate on the highest setting?
Old 08-06-2009, 10:38 AM
tien285's Avatar
I don't think so, but I will give it a try. I know no air comes out when the a/c or heater is on though. I thought maybe it would be the blower resistor since this is a common problem on TLs.
Old 08-06-2009, 02:00 PM
bryse68's Avatar
well you should be able to access the blower resistor underneath the glove box area. how ever there is a service bulletin 06-006 which states due to poor connection need to replace blower sub harness
Old 08-12-2009, 04:39 AM
1bad-eg's Avatar
yeah, the connector to the blower motor overheats and melts causing the blower motor to quit working....ive done sooooooo many at work. I replace the blower motor, transistor and replace the connector and both wires as well.
Old 08-25-2009, 05:34 PM
HondaJave's Avatar
Is the Blower Motor Resistor the same as the Blower transistor? I have a 2004 Honda CRV and they replaced it once. The AC just blew hot air. Both fans have been replaced, the blower motor has been replaced and compressor tested fine. If the same, where is it located? Javier
Old 08-29-2009, 05:52 PM
1bad-eg's Avatar
yes they're the same thing...ummm on ur crv? It should be close by to the blower motor....i think...not familiar...lmk what u find.
Old 02-08-2011, 01:52 PM
PhilB107's Avatar
Hi Guys
I am a new user
Figured I may well ask a dumb question.
Is the blower resister accessable without having to remover the blower motor?
It seems that I can access it under the glove box??
Mine (1 2002 Accord SE 4 Cyl) is working on speeds 3 and 4.
It is so friggin cold out that I don't want to lose that and have no heat!! :-)
Old 04-24-2011, 10:08 PM
chaught02's Avatar
2004 accord, seemingly having the same issue... i tested my blower motor, works just fine independently, but when in place, does not run on any setting. however, my air suddenly worked for about an hour or so, until i turned the car off. how do i test my blower resistor? havent had a/c for 6 months, living in florida it gets pretty bad. finally time to do something about it. im hoping this isnt a short, if so, itll be a b* to figure out... please help!!!
Old 10-22-2012, 04:13 PM
gentleadegoke's Avatar
yes my blower works only on the highest number...i have got an honda accord vtec 2000 model...what can be the cause please?
holmesnmanny
Honda Civic (2006 - 2015)
02-18-2016 01:42 AM
Jericho574
Honda Civic (2001 - 2005)
06-15-2013 05:24 AM
wteebo
01-12-2013 03:27 PM
730_Si
12-28-2007 09:07 AM
Quick Reply: Location of Blower Motor Resistor?
