HELP!!!! Turn signals light up when i step on the brake!!!
Old 07-31-2009, 02:25 PM
jdm.I.am's Avatar
Icon3 HELP!!!! Turn signals light up when i step on the brake!!!
Ok so i bought a 97 civic a few days ago and this is the problem i am having right now..
I had my girlfriend get in the car well i check the lights and when she would step on the brake the front/rear turn lights would light up along with the brake lights in the back... and when you turn the turn signal lights on without the brake pressed they work fine, but if you press the brake well they are blinking they will stay on solid and bolth turn lights in the cluster light up also... WTF?????
bump if view, thanks.
Old 07-31-2009, 02:32 PM
raidacaipo's Avatar
Default Re: HELP!!!! Turn signals light up when i step on the brake!!!
thats pretty cool... lol jk.. check your wiring my friend..
Old 07-31-2009, 02:34 PM
Former User's Avatar
Bad ground connection.
Old 07-31-2009, 02:35 PM
97ej6dx's Avatar
Check the wireing. im guessing some one before you tamperd with the wiering.. does it have JDM fender signals? those are supposed to be attatched to the signal not the running lights.. some people attatch them to both signal and running lights only they wire them backward and for somereason that messes with the ciruts
Old 07-31-2009, 02:37 PM
jdm.I.am's Avatar
the car has a 99/00 front end and 99/00 tail lights but all the wires look to be factory and not cut in anyway at all =(
Old 07-31-2009, 02:39 PM
dookie_707's Avatar
Old but this thread reminded me of this prank:
http://www.youtube.com/watch?v=fvumA8PWY3Y
Old 07-31-2009, 02:41 PM
The brake and tail/signal lights share a common ground wire in the rear. This ground connection has come loose, so the brake lights have lost ground and are now grounding out through the signal light circuit.
Old 07-31-2009, 02:42 PM
97ej6dx's Avatar
hmmm To bad your not closer That would be something i would have to investigate myself..
Old 07-31-2009, 02:44 PM
jdm.I.am's Avatar
thanks RonJ you are the honda master! this is not the first time you have helped me out, im going to check that out and see if that works.
Old 07-31-2009, 02:45 PM
97ej6dx's Avatar
i like that answer!
Old 07-31-2009, 02:49 PM
jdm.I.am's Avatar
where is this ground located? i looked at all the wires in the trunk and they just go into the panel where the rear speakers are and i did not see any grounds...
Old 07-31-2009, 02:57 PM
Weird electrical problems are almost always caused by a bad ground wire. Do you have a sedan or coupe?
Old 07-31-2009, 02:59 PM
jdm.I.am's Avatar
coupe. 97 with 99/00 civic front and 99/00 civic tail lights...
Old 07-31-2009, 03:07 PM
Check whether G601 (exploded view) is disconnected, loose, or corroded:
Old 07-31-2009, 03:21 PM
jdm.I.am's Avatar
nope ripped the speeker panel off and the ground is fine, pulled it off and took a wire brush to it and then bolted it back down and my lights are still fu*ked up.. =(
Old 07-31-2009, 03:28 PM
slow96lude's Avatar
could it be that someone has put the wrong plug in the wrong place. Just crossed my mind.
Old 07-31-2009, 03:30 PM
Maybe an additional ground was installed during the conversion. The ground wires for the brake lights are black. For each brake light bulb receptacle, trace the black wires back to a common convergent site where they are attached. Also look for any damaged or broken black wires. Do the same for the turn signal lights in an attempt to find where all the ground wires converge and are attached to the frame.
Old 07-31-2009, 03:42 PM
jdm.I.am's Avatar
from looking at the wires.. there are 2 ground points in the front, one on each side behind the headlights and the one in the rear that you told me to check.. they look fine and nothing looks to be messed with. i checked all the bulbs and they are the right bulbs and sockets with no cut wires.. checked the wire harness under the dash and there was one black/white line wire that went into the steering column and was cut then taped back together but i redid it and nothing has changed.. gerrr!!!! =(
Old 07-31-2009, 03:48 PM
Focus all of your attention on the rear black ground wires for the brakes, starting at the bulb receptacle and running to their point of grounding to the rear frame. This is surely where the problem will be found.
Old 07-31-2009, 03:56 PM
jdm.I.am's Avatar
would it be better to just cut the ground and ground all the wires to the car again? i mean more grounds could not make it worse right?
Old 07-31-2009, 04:02 PM
I would spend some more time wire tracing and trying to locate the bad ground before resorting to cutting and running new ground wires.
Old 07-31-2009, 04:06 PM
jdm.I.am's Avatar
ok, thanks RonJ for all your help, too bad your not in socal, i would buy you a 12pack.
Old 07-31-2009, 04:08 PM
Thanks. I grew up in the Anaheim/Garden Grove area but I live in Houston now.
Old 07-31-2009, 04:21 PM
jdm.I.am's Avatar
Ok so i was looking the wires in the tail lights over again and i noticed this..
Car harness wires are not color matched from each end of the plug.. the black/white one that is on the tail lights that is going to the brake light and the turn light i assume is the ground.. but on the car harness it is not going to the black wire???? here is a picture...
Old 07-31-2009, 05:57 PM
Seagull Management
94EG8's Avatar
The car isn't wired for a trailer by any chance? I've seen those little black conversion boxes cause all sorts of similar funky issues.
Quick Reply: HELP!!!! Turn signals light up when i step on the brake!!!
