99 Civic Si - lots of slop in my shifter..
Old 07-28-2009, 03:19 PM
Diversion's Avatar
Default 99 Civic Si - lots of slop in my shifter..
What's recommended to get rid of all the slop in my shifter? No problems shifting, but when the car is in gear, for example, 5th gear.. you can move the shifter side to side quite a bit.. I like a firm, feeling to my shifter.. So if someone can direct me to what I need to fix it all! Thanks!
-Div
Old 07-28-2009, 03:30 PM
Crazy Honda Guy
Deetz's Avatar
Default Re: 99 Civic Si - lots of slop in my shifter..
Easy fix, just worn shifter bushings. You can get upgraded parts from Energy Suspension if you don't want oem again. Cost like $15
Old 07-28-2009, 03:31 PM
thi3v3z's Avatar
Shifter bushings, you can buy new ones from honda, or you could go and buy some energy suspension shifter bushings. Either ones are good, and very easy to replace.
HondaGuy951's Avatar
^^^^YUP! Problem Solved!
Old 07-28-2009, 04:32 PM
Diversion's Avatar
Nice! Thanks, sounds easy.. but is it easy? Are the bushings under the car?
Old 07-29-2009, 11:24 AM
Diversion's Avatar
Bump, estimated time for the job? Bushings underneath the car?
Old 07-29-2009, 12:07 PM
b16a1eg6's Avatar
I bet its not:
#16-#30
but instead its these ones:
#23-#5-#4
Old 07-29-2009, 12:11 PM
Crazy Honda Guy
Deetz's Avatar
^^ #14 & 16 Are what make up the shifter bushing kit if bought after market. The majority of what you feel as being slop, comes from #14
Old 07-29-2009, 01:35 PM
Diversion's Avatar
Thanks guys i'm going to order in a Energy Suspension kit and see what happens!
Old 07-29-2009, 03:25 PM
braeden's Avatar
i am curious about this as well. my 2000 si has a b&m short shifter, and has a good amount of side to side slop, but feels fine forward and backward. the car came with the short shifter when i bought it so i bet the previous owner screwed up and forgot the bushings. i'm thinking it's #23,5,4 that are missing/worn out.
Old 07-29-2009, 04:50 PM
Malfa's Avatar
my si's shifter feels HORRIBLE too
ordered energy suspension bushings last week
haven't installed yet
Old 08-09-2009, 07:18 PM
b16_swap's Avatar
nah all you guys are lunchin.. thats just how the em1 shifter is made to be.. it has alot of play in the shifter.. it might suck but its no big deealio silly ho
Old 08-10-2009, 04:02 AM
tercel95's Avatar
Yeah its how it is until you replace the bushings...
"lunchin" seriously what are you like 12?
Old 08-10-2009, 12:10 PM
Diversion's Avatar
Yeah, I have a serious time believing the car had this much slop from the factory. Haven't replaced the bushings yet, probably this thurs/fri and will report back.
Old 08-10-2009, 12:31 PM
b16_swap's Avatar
okay dont believe me, i have an em1 and im not 12 bro. people that have em1's will tell you .. but go ahead and let me know if it actually works and was it worth themoney?
Old 08-10-2009, 12:45 PM
Sambo_Eddo's Avatar
Not that there the same car but I had a gsr with the same issue. Side to side was horrible but front to back was pretty solid. I put in new Energy Suspension bushings (#16 and #30) and it didn't fix the side to side. It tightened up the front to back a little more wich felt great but not side to side play. If I did it over I'd try the #23 #5 and #4. I looked cloder into it after putting in the ES bushings and it definitely looked more like 23-5-4. I currently have an 00 em1 and it has side to side slop. I too higly doubt that it was that way from the factory. Keep in mind a heavy *** shift **** can make this feel alot worse too. Circuit Hero and Skunk2 ***** are what I mean by heavy.
Old 08-10-2009, 12:57 PM
tercel95's Avatar
I have an EM1 and yes the shifter was terrible when I bought it... The bushings make all the difference and were absolutely worth the money... They aren't even expensive...
BTW I'm sure you aren't actually 12 just don't expect anyone on a "technical" forum to take you seriously when you talk like that...
Dougall
08-27-2012 05:48 PM
DOUBLExDEUCEx22
07-08-2009 02:12 PM
x_tuh_sy
12-08-2007 12:03 PM
civic_coupe_585
13
11-09-2007 02:03 PM
MrSmith
08-07-2001 07:39 AM
Quick Reply: 99 Civic Si - lots of slop in my shifter..
