Go Back   Honda-Tech > Honda and Acura Technical Forums > Engine Management and Tuning
Old 07-20-2009, 04:51 PM   #1
ATLTSX
ATLTSX's Avatar
Send a message via AIM to ATLTSX
Default P0685 Code Need Help!!!
I have a 2004 Acura TSX. I just recently went turbo. I'm running Hondata Kpro (Consides of Reflashed TSX ECU and RSX Type S ECU). Everything was running fine. A couple days ago when I was going into boost i got a CEL. The code that came up was P0685. This is ECM/PCM Power Relay Control Circuit/Open. Kpro is not showing any CEL so it has to be in the TSX ECU. I took the TSX ECU out to make sure that the Board wasn't burnt. Plugged everything back in and i got 1 run where it ran fine. Came up to the next light and it did it again.
Any thoughts? I'm trying to get this fixed to make it to IA.
Thanks.
04 TSX
ATLTSX is offline   Reply With Quote
2004, accord, acura, circuit, code, control, ecmpcm, engine, honda, light, op0685, open, p0685, power, relay
