Go Back   Honda-Tech > Honda and Acura Technical Forums > Welding/Fabrication
Old 07-17-2009, 02:57 PM   #1
garados
garados's Avatar
Send a message via AIM to garados
Default welding aluminum wheel crack?
I have an aluminum wheel that cracked at the outer lip, probably a half inch into the wheel from the lip. Would it be possible to have a standard tig weld done to fix this, or would it have to be re-heat treated to keep the integrity of the wheel?
1993 Miata: stripped out, getting ready for a renovation
2003 IS300: Stance coilovers, Blitz 01 wheels
garados is offline   Reply With Quote
Old 07-17-2009, 03:07 PM   #2
boost_aholic97
boost_aholic97's Avatar
Default Re: welding aluminum wheel crack?
i have seen people just preheat and weld and they hold up just fine, but then again many people have come to me to weld stuff like this and i dont touch it, cause of liability issues....but it can be done.
'92 Hatch- turbo B16>10 sec beast/ '90 Sedan-stock DPFI> gas saving non-beast
'00 Tacoma-Rock Crawling Taxi/ '03 Cobra-490hp Street Sweeper/1999 Softail Chop'd up
'04 Sequoia- Family Wagon/ 51 GMC Pickup- Bagged, Laying Frame with a SBC
boost_aholic97 is offline   Reply With Quote
Old 07-17-2009, 03:28 PM   #3
srmofo
srmofo's Avatar
Ive seen it done. just make sure the person is competent enough to do it....also the wheel is usually pretty bent if it was hit hard enough to crack it
Originally Posted by lambo123
yeah once again, didn't listen to h-t's advice and fixed it when it should've been fixed. my car caught on fire yesterday. i have now confirmed one should never use tin foil as a fuse.
srmofo is offline   Reply With Quote
Old 07-17-2009, 04:06 PM   #4
Kevin
Kevin's Avatar
Try to find a local wheel repair shop and let them work their magic. I've seen OEM style wheels repaired and were perfectly fine.
90 Integra K20 turbo
Custom Marine Sales
Kevin is offline   Reply With Quote
Old 07-18-2009, 02:29 AM   #5
RickyLee53
RickyLee53's Avatar
The wheel repair shops I've seen either send their wheels to a "welder" to be repaired, they do the finishing off etc but don't actually do the welding.
Most specialist welders IMO would do a better job as they do this type of thing day in day out. Rather than repairing wheels and the odd 2" of weld here and there.
Obviously keep a close eye on it afterwards.
UK's fastest D series on road tyres.
UK's fastest B series on stock engine.
UK's fastest B16 on slicks.
RickyLee53 is offline   Reply With Quote
Old 07-18-2009, 08:08 AM   #6
d16sandrail
2010 Honda Civic Hybrid
d16sandrail's Avatar
I've welded three cracked/broken aluminum wheels. Depending on where the cracked area is, it may or may not need pre heated (depends on the thickness). I don't really buy into all that liability crap, I won't take the job if I am not 110% confident in my ability, and that the customer will not have any future headaches with the results. Long story short, Yes it can be done, I would take it to a reputable welder (not a rim repair shop) the price will be a lot more at the rim repair shop because it is a specialty shop and they gotta make they're money somehow.
Honda-Tech. Where the rudest **** talkers of the world unite.
[url]http://www.allinfab.com
Custom fabrication and machine work. Oregon Based.
d16sandrail is offline   Reply With Quote
Old 07-18-2009, 08:24 AM   #7
jlude90
jlude90's Avatar
Send a message via AIM to jlude90
yeah, i had an fn01-r with a good 2 inch crack in it, took it to my friend who TIGs for a living and i got it back with what looked like all the paint ground off of a perfect wheel. not distortion, not bent, nothing. threw some paint on it and i can't tell which wheel was fixed, this was about 3 years ago now.
wll wheels balance out well too, so i can't tell there either
jlude90 is offline   Reply With Quote
Old 07-18-2009, 09:42 AM   #8
Wopsicle69
Wopsicle69's Avatar
I had this problem with an Enkei RP01 rim. I removed maybe an 1/8" of material around the crack, drilled a hole at the end of the crack so it would not continue to crack, used a small propane torch to warm the aluminum up, hit it with the tig, used some filler to replace the material I grinded away, grinded the weld flat, threw on some silver paint, and havent had a problem with it since 2 years ago.
1990 EF9 ....... 1.8L Roller Rocker LS/Vtec ....... S372 ....... Synchro Shifted 4 Speed ........ 9.68 @ 157mph
Wopsicle69 is offline   Reply With Quote
Old 07-19-2009, 05:34 PM   #9
garados
garados's Avatar
Cool, thanks for the info guys!
Old 07-20-2009, 05:43 AM   #10
chrisbmx68
chrisbmx68's Avatar
Send a message via AIM to chrisbmx68
I would agree that it can be done, just make sure you preheat it well, and let it cool slowly, and vee out the crack for maximum penetration. Drilling the ends of the crack is a good idea as well or it will probably just continue to crack after its welded.
chrisbmx68 is offline   Reply With Quote
Old 07-20-2009, 12:00 PM   #11
CVC9216
CVC9216's Avatar
Send a message via AIM to CVC9216
I've welded probably 100+ wheels. The only ones that re-cracked (maybe a handfull) usually were well abused and re-bent (or cheap *** walmart chrome wheels). Aftermarket/US made wheels seem like they are more likely to be cracked without being bent due to I guess being more brittle. There isn't much liability concern, if it cracks again, weld it again. The wheel isn't going to explode and cause a wreck. As long as the customer understands there is a chance it may crack again.
CVC9216 is offline   Reply With Quote
aluminum, california, ccracking, crack, cracked, cracking, hawaii, integra, northern, repair, rim, weld, welding, wheel, wheels
