cost of installing cams, valve springs and retainers???
Old 07-18-2009, 11:34 AM
  #26
American.Graffiti's Avatar
Default Re: cost of installing cams, valve springs and retainers???
Originally Posted by mar778c
Nylon rope, threaded thru the sparkplug hole. Make sure you swap the springs and retainers one cylinder at a time. I made the mistake of pulling all of the VT off at once and dropped 4 valves. I had to remove the head to get everything done.
Now there's a thought. Im about to change my valve springs, retainers and seals and thought that by just putting each cylinder at TDC as I worked through it would be good enough but the nylon would help to add some insurance. Thanks for the info.
Old 07-18-2009, 03:12 PM
  #27
sde780's Avatar
You can rent a valve spring compressor for a $60 deposit from advanced auto
Old 07-18-2009, 07:50 PM
  #28
rhymeshark916's Avatar
Originally Posted by mynameizstitch
ok today i went to a local tuner shop to get a quote on how much it will cost to install my itr cams, itr dual valve springs and itr retainers. what the guy quoted me was $350 and to me that seems high. anyone here ever paid anyone to install their valvetrian and for how much or how much should i be paying for them to install it? i know it's pretty straight forward but i just dont got the tools and if i had someone who can guide me through it im pretty sure i can do it but i rather get it professionally installed.
I had cascar do my head work. First quote was 250 or 300 I couldn't remember but it was for refresh head and installing springs and retainers. Second quote bumped up to 500 because I need new intake valves and valve guides includes parts and labor. So yeah just an idea.
Old 07-18-2009, 10:00 PM
  #29
ruffrhyder's Avatar
Those won't work on B-series heads
Old 07-19-2009, 01:13 AM
  #30
ef92b's Avatar
yep, the nylon rope trick is good enough. although i've been pulling valve springs without it really. simply work at ease and take your time. just do the 4 valves at a time while piston's at TDC. meanwhile, plug the oil galleys with a small piece of rolled paper just in case the valve locks slips. use a magnetic piece to hold and pull the locks while pushing the springs down.
mynameizstitch
Northern California
10
07-16-2009 07:36 PM
00civicsimobstyle
08-07-2002 06:43 PM
Quick Reply: cost of installing cams, valve springs and retainers???
