how do you move the ignition from the column to the dash in a 1996 acura integra
iv tried to find posts for this and i didnt come up with anything if someone knows how to do it can you let me know because i really want to see how its done before i rip everything apart.
all i am trying to do is move the ignition from the column to the dash where the dimming **** is for the cluster...
Re: how do you move the ignition from the column to the dash in a 1996 acura integra
Sooo... You want to move the ignition switch (the part the key goes into) from the column and mount it to the dash? It is uncommon to do this unless you are eliminating the steering wheel bezel as the absence of the ignition switch will leave an unsightly hole. Anyway, here are some tips.
First, rip it all apart. The biggest challenge is persuading the shear bolts away from the bracket. To do this drill a small dent into then and then tap them loose with a small screwdriver and hammer. Separate the ignition wires from the combination switches. Once the ignition is apart then you will likely need to make a snazzy bracket or something to mount it to behind the dash.
I did something sort of similar in my racecar. Because I had to build a custom steering column in order to fit my steering quickener I chose to eliminate the ignition switch. Essentially I rewired it to a main battery cutoff switch, an accessory switch, and a push-button start. Its pretty slick. The start button is in a sneaky spot in order to deter thieves.
Also, like the last guy posted. Get a manual if you are serious about this. PRICELESS!!!!
it doesnt say anything in the manual about moving the ignition switch to the dash. it only tells me how to change the oil. thanks though
and thank you mdhimes ill take a look at it but you described exactly what i need to do so hopefully it works thanks again
Good luck.
jdmjosh1
03-31-2010 03:32 PM
