Old 07-08-2009, 12:57 AM   #1
dth0ng69
dth0ng69's Avatar
Send a message via AIM to dth0ng69
Default what Type of Coolant should I use?
I have a 1998 Honda civic CX,and I want to do a radiator flush, what coolant should I use? Honda?
would prestone 50/50 coolant work? what should the label say?
96 Ek island coral 4dr traded, 98 Sir'd hatch Ek. totaled by someone.
97 Black ek ls-Turbo Tuned on Hondata s300 traded
97 Integra LS
dth0ng69 is offline   Reply With Quote
Old 07-08-2009, 01:16 AM   #2
Ruben19
Ruben19's Avatar
Send a message via ICQ to Ruben19 Send a message via AIM to Ruben19
Default Re: what Type of Coolant should I use?
prestone is fine
Middle finger to All Thieves here in WA and over the world, they deserve to die now
Em1 crew Peyton Manning #18 Best QB in the NFL. I <3 HATERS
Ruben19 is offline   Reply With Quote
Old 07-08-2009, 01:36 AM   #3
MHDesigns
1999 Honda Civic
MHDesigns's Avatar
I live in arizona. The only reason I don't use water for coolant is because coolant has corrosion resistance to internals lol. The coolant you use does not really matter..as long as its actual coolant and properly mixed.
MHDesigns is offline   Reply With Quote
Old 07-08-2009, 03:13 AM   #4
geneeunit
geneeunit's Avatar
Send a message via AIM to geneeunit
i use honda type 2 coolant. i think with coolant it's more of a preference thing, i think they're all GENERALLY the same.
geneeunit is offline   Reply With Quote
Old 07-08-2009, 03:39 AM   #5
hondamark35
2000 Honda Civic
hondamark35's Avatar
green type... avoid anything orange. blue is ok, but it costs more. i like to mix it myself 50/50, mostly to avoid buying a half gallon of water from autozone
(yes, this was oversimplified to make the point that it doesn't matter as long as you avoid dexcool-orange stuff)
I still work on cars sometimes
"Leave me alone, I know what I'm doing." Kimi Raikkonen
"cowards never start, the weak never finish, winners never quit."
hondamark35 is offline   Reply With Quote
Old 07-08-2009, 03:44 AM   #6
MHDesigns
1999 Honda Civic
MHDesigns's Avatar
is there really blue coolant? or was that a joke..damn the internet and its lack of a sense of sarcasm lol. But for real that would be jdm as **** lmao!
Old 07-08-2009, 03:49 AM   #7
hondamark35
2000 Honda Civic
haha, there was a small amount of sarcasm.. but the Honda Type 2 i think is blue..
i've also seen red in some toyotas... but i figured it's close enough to orange and far enough from green to be avoided.
Old 07-08-2009, 04:00 AM   #8
thi3v3z
thi3v3z's Avatar
Well i see you live in seattle, so you should actually mix more coolant and less water because of the harsher winter weather. You should consider 60% coolant and 40% water so you should mix it yourself.
thi3v3z is offline   Reply With Quote
Old 07-08-2009, 06:12 AM   #9
koa
1996 Acura Integra
facebook.com/kekoamurayama
I like to use 80% water and 20% coolant and a bottle of water wetter. The summer is pretty hot in TX. In october i flush it again and use prestone 50/50. I have about twenty cases of that **** sitting in my shop. Along with other brands of coolant.
koa is offline   Reply With Quote
Old 07-08-2009, 06:56 AM   #10
honda.lioness
The water pump bearings of older (and newer?) Hondas are known to be vulnerable to non-OEM coolants, with some exceptions. I have been using the orange Havoline Dexcool in my Honda for almost seven years (changing every 2 years or so, which is probably too often) and have had no problems. I have had problems with early water pump failure before when using the green Prestone. I know other Honda veterans who swear by the orange Havoline Dexcool as well.
The only coolants I would use are OEM or the orange Havoline Dexcool. I buy the Dexcool undiluted, since this saves money, picking up a gallon of distilled water at the grocery for mixing.
Elle
91 Civic LX, 93 Civic DX, 03 Civic LX
honda.lioness is offline   Reply With Quote
Old 07-08-2009, 07:49 AM   #11
vtechjunkie
vtechjunkie's Avatar
iTrader Rating: (2)
I like to use the water wetter as well. It can drop the temp in the radiator a few degrees all by itself. But yes; as "koa", said I would use more coolant than water in the winter. I change mine out every spring with the Prestone and Water Wetter to help with the heat.
My vouches
http://www.hondamarketplace.com/show....php?t=2669009
HID retrofit club member #0059
vtechjunkie is offline   Reply With Quote
1998, 2000, 2006, 50, 91, 98, antifreeze, civic, coolant, honda, kind, lx, prelude, prestone, type, use
