> Forced Induction
Old 07-07-2009, 09:32 PM   #1
jasoncrashtech
jasoncrashtech's Avatar
Default my daily
i've had honda's w/swaps and what not, but i never really went all out before. i might have with my 92 hatch but it got stolen right after i finished it.
but through out the whole time i had daily driver 98 ex. swapped out the upper tie bar and headlight baffles, fenders, hood, grille, bumper to a 99-00
a year ago i dropped my motor in.
b18c (p72) w/lsd from hmotors (great place to buy from *thumb up*)
motor is in, ran like a champ but i switched the intake manifold to skank2. (fullrace manifold was a lil too much, ran weird on stock ecu)
i wanted everything to run good before boosting. not chasing problems or making it more difficult then it should be. so i pieced everything together for my turbo setup and enjoyed my new motor in the meantime.
got bored of the yellow vcover also
it took me six weeks to get my peakboost manifold, but it was really worth it.
i made my own dump and down pipe. you don't haft to buy a 350 or 400 dollar down pipe. i test fit everything needed on my spare block, made cuts were i needed. i takes time but it's cheaper and i prefer to do things myself for the most part.
38mm flange i can clock the dump pipe were i want it.
obd1-obd2 adapter clips tied up so they are not laying around. i don't like sloppy wiring.
i took a y8 throttle cable bracket, sectioned it and welded it up (painted black) so the throttle felt better. gsr bracket sucked
i took the reinforcement bar off the car so i could hollow it out. i didn't want to because it's an important part for the intrusion factor if in an accident but it wasn't happening. so i chopped it up and painted it. i removed ac and power steering also. installed manual rack and spline fitting from a cx (thanks whitey's wrecking!)
i test fitted the bumper cover a few times before final welding. i see alot of people cutting out their bumper covers for the intercooler piping. if you weld brackets to keep the intercooler close to the radiator core support you won't haft to chop up your bumper. if you have fogs and want to keep them you probably need a backdoor intercooler i think.
i bought a 3in flex section, two bungs for my senors (wideband , o2) and a port for a egt. i also bought a section of 3in from autozone to finish my dp. but all this was fitted on the car. if you want to save cash or do it your self, test fitting is the way to go especially with the sensors, if you put them in the wrong spot they could hit your shift linkage or mid shaft (if you have one). if you do make a dp and dump , make your dp first then your dump so they don't conflict. the front part of the down pipe was metal finished , self etch primed and blacked out with engine paint, scuff the paint in between coats if you want to do this your self.
after trimming the front bumper out on the inside were the intercooler piping goes, it was prepped for paint. while my bumper was in the paint shop i was pulling the tranny out to replace the stock clutch. (it didn't take long for that to go) i installed a competition stage 4.
if this helps anyone out, cool. even any input, cool.
my set up is
peakboost ramhorn mani
tial bov, tial waste gate 9lbs spring
t3/t4 57 trim
hondata intake manifold gasket and s2 im
rc 750's, walbro pump
itr cams
no times, no dyno ....... yet
ej8 squad member #346
valve cover how to http://honda-tech.com/zerothread/2188046
my daily http://honda-tech.com/showthread.php?t=2603420
jasoncrashtech is offline Report Post   Reply With Quote
Old 07-07-2009, 10:12 PM   #2
Turbo_TONY
Turbo_TONY's Avatar
Send a message via AIM to Turbo_TONY
Default Re: my daily
very clean! peakboost ftw
Peakboost ,Full-Race , Fusion Works
84mm Ls/V finally done..now break-in begins
Turbo_TONY is offline Report Post   Reply With Quote
Old 07-07-2009, 10:17 PM   #3
jasoncrashtech
thanks man
Old 07-07-2009, 11:53 PM   #4
mephology
mephology's Avatar
Send a message via ICQ to mephology Send a message via AIM to mephology
This is so awesome. Thanks for putting in the extra time with pics and sharing your expertise.
mephology is offline Report Post   Reply With Quote
Old 07-08-2009, 07:48 AM   #5
EARLdaSQUIRREL
official honda whore
1994 Acura Integra
EARLdaSQUIRREL's Avatar
Send a message via AIM to EARLdaSQUIRREL
good job
IMW:speed-theory:j-k-tuning:thmotorsports.com
my "h-t" build thread 09/10
http://hondamarketplace.com/showthread.php?t=2612869
EARLdaSQUIRREL is offline Report Post   Reply With Quote
Old 07-08-2009, 08:39 AM   #6
Slink2000
Slink2000's Avatar
Looks superclean!
Slink2000 is offline Report Post   Reply With Quote
Old 07-08-2009, 11:11 AM   #7
jdm inc
1993 Honda Civic
jdm inc's Avatar
Looks Good! Keep us updated.
jdm inc is offline Report Post   Reply With Quote
Old 07-08-2009, 11:17 AM   #8
tegman23
tegman23's Avatar
Send a message via ICQ to tegman23 Send a message via AIM to tegman23
Looks clean, and should be a fun reliable daily nice work ...
92 DA 11.70@124mph
2.0-T power
IMW/JK Tuning
tegman23 is offline Report Post   Reply With Quote
Old 07-08-2009, 12:04 PM   #9
SPOON_BeIgHtEeNsEe
SPOON_BeIgHtEeNsEe's Avatar
looks great... u selling the y8 swap?
garage sale <<<==== CLICK HERE!
SPOON_BeIgHtEeNsEe is offline Report Post   Reply With Quote
Old 07-08-2009, 12:13 PM   #10
Teglove2
Teglove2's Avatar
Send a message via ICQ to Teglove2 Send a message via AIM to Teglove2
Repin' ht.com on the valve cover....very cool
RMSfabrications@yahoo.com
Teglove2 is offline Report Post   Reply With Quote
Old 07-08-2009, 12:43 PM   #11
jflory4947
looks good man
jflory4947 is offline Report Post   Reply With Quote
Old 07-08-2009, 01:10 PM   #12
twkdCD595
twkdCD595's Avatar
looks good, btw whats the color on the valvecover?
-try not, do or do not... there is no try.
God bless the men and women of the U.S. armed forces.
T1 Race Development
Laskey Racing
PortFlow Design
Bisimoto Engineering
twkdCD595 is online now Report Post   Reply With Quote
Old 07-08-2009, 01:47 PM   #13
AJxr
AJxr's Avatar
Send a message via AIM to AJxr
if this is your daily i want to see your racer!!
I have way too many toys.
90 DX-race car - stock b18b1, holset-14psi-11.75@114.75, GONE
AJxr is offline Report Post   Reply With Quote
Old 07-08-2009, 05:49 PM   #14
jasoncrashtech
i sold it a while back. sorry
Old 07-08-2009, 05:50 PM   #15
jasoncrashtech
late modal honda element color . kiwi pearl.
Old 07-08-2009, 05:55 PM   #16
jasoncrashtech
thanks to all you guys for the comments. i will be adding more and updating. things got sloppy for a minute. soon i'll be adding pic's on how i metal finished it and some more stuff.
Old 07-20-2009, 12:32 PM   #17
jasoncrashtech
r.i.p. oem clutch
Old 07-20-2009, 01:10 PM   #18
omiehomie
omiehomie's Avatar
Send a message via AIM to omiehomie
Originally Posted by jasoncrashtech View Post
r.i.p. oem clutch
lol need story stat
"experience is that marvelous thing that enables you to recognize a mistake when you make it again"
00 ITR #567 (theft recovery) UP AND RUNNING STRONG. http://images.honda-tech.com/set1/smile/emsmilep.gif
99 SSBP GSR (DD waiting for boOost) http://images.honda-tech.com/set1/smile/emsmileo.gif
omiehomie is offline Report Post   Reply With Quote
Old 07-20-2009, 06:25 PM   #19
jasoncrashtech
i took it to the track, no biggie but it's not holding up. lol. it is trying though. i ordered a 6 puck yesterday
Old 08-04-2009, 09:07 PM   #20
numba1
numba1's Avatar
LOOKS awesome!
better to be a open sinner than a false prophet.
live fast die young have a GOOD looking corpse! http://images.honda-tech.com/set1/smile/emwink.gif http://images.honda-tech.com/set1/smile/emthup.gif
numba1 is offline Report Post   Reply With Quote
Old 08-04-2009, 09:23 PM   #21
slowmanEK
slowmanEK's Avatar
Send a message via AIM to slowmanEK
Excellent. Would be nice to see some dyno numbers and quarter mile ET!
IA10
slowmanEK is offline Report Post   Reply With Quote
Old 08-04-2009, 10:43 PM   #22
turbohatch96y7
turbohatch96y7's Avatar
how much power do u need for that welder is it a 240 ac or 110 ac
http://www.hondamarketplace.com/show....php?t=2651487
willing to buy this or bump it
turbohatch96y7 is offline Report Post   Reply With Quote
Old 08-04-2009, 11:16 PM   #23
JDMFreak
JDMFreak's Avatar
Send a message via AIM to JDMFreak
mad props! coupe looks good!
- 00 Honda Civic HB (Flamenco Black)
- 05 Honda S2000 (Silverstone Metallic)
JDMFreak is offline Report Post   Reply With Quote
Old 08-04-2009, 11:44 PM   #24
JDM MOST WANTED
JDM MOST WANTED's Avatar
Send a message via AIM to JDM MOST WANTED
super clean bumpp
JDM MOST WANTED is offline Report Post   Reply With Quote
Old 08-08-2009, 09:41 PM   #25
jasoncrashtech
i'm using a 110 at home, almost all the welding i do is sheet metal. any heavy metal i do is at work
Bookmarks
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Honda-Tech.com content, comments, or iPad advertising. Honda-Tech.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Honda-Tech.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
