ej2 complete rebuild on the cheap first project
bought this car from a junkyard for $200 everything was in the car except main relay and battery. i started selling parts on ebay before i decided to build it, sold the dash for $200 and made my money back, and sold the rest of the interior, headlights, quarter extensions, one seat, guage cluster, so i started out with +$600 or so...im afraid this will be slow due to money but here we go
Re: ej2 complete rebuild on the cheap first project
the motor in the passenger side floor was an extra d15 i had, from my red civic that i swapped a b16a into. first thing, i need to replace my wifes head gasket on her 4-door civic so im going to pull the head off this car, warranty out all the gaskets for free, and send this head to the shop to have it machined and new valve seals put in.
how do you text under each individual picture?.....picked up the cherry picker for pretty cheap and got my nitto neo gens 205-50-15 and ordered my wheels today, and some other parts. the car is an automatic, and its going manual, so i ordered the new manual tranny mount bracket today from honda.
so far, my plans are:
car is going black
enginebay shaved, tucked,painted black
switch from power steer, to manual steer
brake line tuck
find factory spoiler
replace lower control arm bushings and trailing arm bushings
replace wheel bearings
replace all brakes
replace tie rod ends
replace all ball joints
im going to paint all suspension parts with red caliper paint main reason so i could tell if something ever leaks and it'll be easy to clean
all body work and paint will be done by me as well as all fabricating and mechanical work
going to redo entire car wiring harness my own custom way, go through every wire and depin and remove every wire i wont need fuse boxes are going under the dash so ill need to shorten and lengthen some wires
jdm b16a is going in
adding lsd to my tranny
going with mfactory gears with low ratios
car is going black
brake line tuck
replace all brakes
thanks man, im probably going to need all of the advise and yes criticism that i can get, but its going to be fun and give me some experience for when i go to build the car i want to actually keep...eg hatch
yah ill probably drive this car for a while but im going to sell it
testing to see if my pics work
text under pic
text under pic
got the motor pulled tonight, tomorrow i am going to pressure wash the bay, and drop the fuel tank to start redoing it. the bumper support bar, or whatever its called, was smashed up, so i started looking for more signs of body damage, i started stripping the pass side fender and it was full of body filler, and so was the pass side door. so i am going to replace both
motor was nasty and full of rust
always have to take silly pics of you in the bay
greasy!
greasy!
more pics
shows how the auto bracket points upward, manual goes straight out
nasty firewall
i also ordered new hoses for the fuel tank hopefully ill get them and the new bracket tomorrow
nasty firewall
more shots
these are the wheels i ordered
on my way to work but ill have updates tonight, excited because i finally get to spray the 69 camaro ive been working so hard on, but next week i get another restoration job
okay, today i got the bay washed and dropped the fuel tank, stripped the nasty tank, primered it with shopline epoxy, and then applied truck bed coating
tank out
in epoxy
in truck bed coating
this is what i used
all clean
i called the dealership today, my parts will be here tomorrow
tank out
in epoxy
this is what i used
all clean
picked up the new parts today from honda
also stopped by work and picked up spot weld drill bit to get the old bracket off
nice and easy with the right tools, if you ever do this, its a good rule of thumb to use alot of lube wd40 or something to keep your bit cool, they are expensive so you want to take care of it
some updates from the weekend, got interior cleaned out and some new parts
exhaust out
sound deadner coming out
NEW PARTS
wheels and lugs
back brakes
front brakes
wheel bearings
brakeline bender
more stuff
exhaust out
NEW PARTS
wheels and lugs
back brakes
front brakes
wheel bearings
brakeline bender
more stuff
thanks for the replys i was starting to think i wouldnt get any lol
next order of buisiness, im going to remove the front suspension, steering, and subframe to replace all the bushings, ball joints, tie rods, bearings, and clean and paint...i wish i could afford some coilovers, but i think im going to cut one full coil off all 4 springs to lower a lil bit, i wonder how much this will lower and how poor the ride will be? anyone have any input on that?
well, i have another one this color, and i really liked these wheels, so its gonna be black and look like a stock civic from the outside, and black is also cheap lol, the car has 4 paintjobs on it, so im definitely going to strip it
yah i would, but im going to check the local yards first and see what i can find, how much would you want for it
if your doing this much work to the car please do not run cut stock springs. your better off getting the dropzone sleeve over coils and shocks for cheap or even just a set of cheaper priced lowering springs. anything is better than cut stocks the ride is going to be awful. trust me my friend had them on his car wayyyyy back in the day and i hated riding in that bucket
