Old 07-02-2009, 05:15 PM   #1
90gs
90gs's Avatar
Send a message via AIM to 90gs
Default Stuttering under low rpm acceleration, what's wrong?
I first noticed it in 5th gear going 45 or so, almost felt like REALLY light wheel hop but no steering wheel vibration or anything, just stuttering acceleration.
Then I started noticing it going up this really steep/big hill before my house, power would drop off towards the top of the hill sooner than normal.
Clogged cat? Distributor coil? The spark plugs and air filter are less than 1000 miles old. I might be biased in thinking that it's the coil, my old 95 LS went through 3-4 of those in the less than a year that I had it.
1993 Integra RS
90gs is offline   Reply With Quote
Old 07-02-2009, 07:21 PM   #2
ek-g6
ek-g6's Avatar
Send a message via AIM to ek-g6
Default Re: Stuttering under low rpm acceleration, what's wrong?
hows your fuel filter? Possible that your coil could be going bad, and also when is the last time the car had a tune up?
92' Gsr B1.9b beast
Join the Brute force.
ek-g6 is offline   Reply With Quote
Old 07-03-2009, 03:26 PM   #3
90gs
90gs's Avatar
Dunno about the fuel filter or the extent of what you define a "tune up" as but it's had oil, spark plugs, transmission flushed, and air filter within the last couple thousand miles.
I was thinking of changing the plug wires, cap, and rotor and going from there.
Old 07-04-2009, 09:19 AM   #4
90gs
90gs's Avatar
So now I noticed that it's pretty much any time there is excessive load on the engine. Low RPM acceleration in top gear, mid RPM acceleration on an incline... downshifting usually makes it go away but that's a temporary solution.
Old 07-04-2009, 10:42 AM   #5
95 integra
95 integra's Avatar
iTrader Rating: (1)
Slipping clutch? Any rpm studder with that "wheel hop"?
- After 8 years I have an Integra that isnt making that damn buzzing sound from the abs pump.
- 2003 Berlina Black S2000 w/ OEM Hardtop and some other OEM goodies.
95 integra is offline   Reply With Quote
Old 07-04-2009, 11:40 AM   #6
90gs
90gs's Avatar
It's not wheel hop, just kinda feels like that kind of stuttering but an extremely light version of it.
Usually happens 2-3k on a flat surface in 5th gear, 3-4k on an incline in 4th or 5th... haven't felt it in any other gear yet, probably isn't enough load in a lower gear to replicate the issue.
Old 07-06-2009, 11:34 AM   #7
90gs
90gs's Avatar
bump
Old 07-06-2009, 01:39 PM   #8
SoTexDC2
SoTexDC2's Avatar
Send a message via AIM to SoTexDC2
Check your ignition timing first, because it doesn't cost anything to adjust.
Fuel filter, plugs, wires, cap, rotor could all cause this.
Who did the "transmission flush" ?
̿' ̿'\̵͇̿̿\з=(̪●)=ε/̵͇̿̿/'̿'̿ ̿
SoTexDC2 is offline   Reply With Quote
Old 07-06-2009, 01:46 PM   #9
90gs
90gs's Avatar
Shit, I knew I forgot something at the dealership... just went and bought cap, rotor, wires, and coil. Plugs and air filter were changed recently enough (less than 1k miles).
Dealership did the transmission oil change.
It didn't do any stuttering on the drive home. I hate problems that are intermittent, so hard to diagnose.
Old 07-06-2009, 02:52 PM   #10
bfatdaintegra
1988 Honda CRX
bfatdaintegra's Avatar
maybe a lil moisture got into somewhere that u couldnt see and it was fouling out that happened to me and i replaced a 250 dolar dizzy for nothing but it looked fresh
bfatdaintegra is offline   Reply With Quote
Old 07-06-2009, 10:40 PM   #11
90gs
90gs's Avatar
Any way that it could have been clogged air filter and it took a bit for the ECU to adjust? It seems to have gone away after replacing the air filter but it didn't right away.
(first post says that spark plugs and air filter had <1k miles... I replaced the spark plugs a month ago but didn't do the air filter until the first day this started happening but the problem didn't go away right away)
Old 07-07-2009, 09:47 AM   #12
abusedvtec
abusedvtec's Avatar
Send a message via AIM to abusedvtec
check fuel pump
built lsvtec swapped 94 gsr
.50 trim turbo kit on 4lbs of boost
lsvtec+turbo= 1 bad addiction
abusedvtec is offline   Reply With Quote
Old 07-07-2009, 05:56 PM   #13
90gs
90gs's Avatar
Originally Posted by abusedvtec View Post
check fuel pump
It went away, just wondering what caused it for future reference now. Refer to the post I made before this one.
93, accelerating, acceleration, accord, fuel, honda, ignition, integra, load, low, rpm, s2000, stutter, stuttering, stutters
