Old 06-26-2009, 08:24 PM   #1
1337knub
1337knub's Avatar
Default Honda accord 1999 wont start
I was driving it just fine all day and i turn it off and when i go back to turn it on it wont start. There is no fire, to turn not even a single noise accept for the buzz of the check engine light although I've never heard of a car doing it before. I can hear the ignition switch engaging so it is not that. Also i tested the starter and the starter solenoid and those are fine as far as i can tell and the battery is fine. From my other reading seems some people have had similar problems and it happened to be the alternator but I'm not sure thats my case. Any ideas on what it could be. Its my only car and i don;t have any way to get anywhere else.
1337knub is offline   Reply With Quote
Old 06-26-2009, 09:01 PM   #2
Targa250R
be professional
Targa250R's Avatar
Default Re: Honda accord 1999 wont start
Evaluate, because based on what you've described thus far, it sounds like the starter is bad or the battery is dead.
1996 Accord | 1998 CB750 | 2001 Integra | 2012 Giant Anthem X29
Targa250R is offline   Reply With Quote
Old 06-26-2009, 09:10 PM   #3
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
Either those mentioned or your starter power wire is loose. Mine tends to come off while I'm driving and next thing I go and start it, it wont even crank over or nothing. So check that starter wire coming out from the engine harness.
1994 Honda Accord EX - JDM H22A
- 204whp/157wtq
Originally Posted by toycar View Post
Breaking the bank, maybe. Feeling like a boss, likely.
nus_dogg is offline   Reply With Quote
Old 06-27-2009, 12:52 AM   #4
kiddo286
Send a message via AIM to kiddo286
da same thing hppen to my accord that is currently in the shop I would say is the distributor or the main relay I have to guess on my car bcuz is a 94 but since urs is a 99 try to hook a computer in to read the problem I know a guy that would try his comp in like for 20 bucks in LA. Juss trying to hlp...
kiddo286 is offline   Reply With Quote
Old 06-27-2009, 05:20 AM   #5
accord99power
1999 Honda Accord
My Garage
accord99power's Avatar
Send a message via AIM to accord99power
are any belts turning when you turn the key over? If not try to jump start your car. Still nothing? Try hammering on your starter not the wires while someone else is trying to crank the car over repeatedly. Let us know the results.
99 ACCORD COUPE 5SPEED F23A1 BOOSTED! 13.83 @102.83 mph
236WHP/255TQ@10 PSI :.63TRIM T04E, AEM Tuned w/ 550CCs Inj.
2010 HONDA 1300cc FURY: 2001 V8 TUNDRA
accord99power is offline   Reply With Quote
Old 06-27-2009, 05:37 AM   #6
1337knub
1337knub's Avatar
Alright,
What i have done to check the starter is hook jumper cables to the positive end of my battery then put a screwdriver on both the starter and the solenoid and they both turned over( when i placed it on the solenoid it actually turned the engine instead of just spinning) but it wouldn't start.
I know the battery is fine because it had lights and everything even the dome light.
I tried checking the wires and everything seems to be fine to me as well as all the fuses and such.
Also i did try jump starting it but nothing happened, also no belts turn when i do anything aside from the one time when the engine turned.
Thanks for your help guys.
Old 06-27-2009, 05:50 AM   #7
accord99power
1999 Honda Accord
My Garage
do your alternator belts etc move at all when turning key over 100% of the time? im nto understanding your post.
just becuase the dome lights work dosnt mean it has enough juice to crank over. but usually youll see the belts move for a brief second then here a series of a zapping sound. thats a bad battery.
Old 06-27-2009, 06:06 AM   #8
1337knub
1337knub's Avatar
well before it started to work it would turn everything but i'll go and check the battery again just to be sure.
Old 06-27-2009, 06:12 AM   #9
accord99power
1999 Honda Accord
My Garage
are you sayin before this problem it would turn over? or the belt turnover now? its yes or no answer man.
Old 06-27-2009, 06:17 AM   #10
1337knub
1337knub's Avatar
before the problem everything would turn. Now nothing turns.
Old 06-27-2009, 06:23 AM   #11
accord99power
1999 Honda Accord
My Garage
so the belts do not move at ALL when key is turned every time the key is turned right? Im leaning towards your starter, do u have automatic or manual? get a hammer and hammer on the starter just not the wires. hammer on it while somebody else trys to turn the key over. a bad starter alot of times will crank over still after this trick.
Old 06-27-2009, 06:27 AM   #12
1337knub
1337knub's Avatar
yes, the belts do not move at all while the key is turned every time.
I have an Automatic.
I'll trying beating on it some lol.
Old 06-27-2009, 06:33 AM   #13
1337knub
1337knub's Avatar
no avail man. Still wont turn.
Old 06-27-2009, 07:17 AM   #14
accord99power
1999 Honda Accord
My Garage
get a bigger hammer lol, seriously it will work, have a helper turning the key off and on, while your beating on the starter solenoid. you can also you a big punch or something similar to give you more hammer room.
Old 06-27-2009, 07:19 AM   #15
accord99power
1999 Honda Accord
My Garage
another thing to test is when you turn your key see if your stater cable is getting a signal with a volt meter. if volts present, your starter is the problem. If no volts present you got another problem to diagnosis.
Old 06-27-2009, 08:01 AM   #16
1337knub
1337knub's Avatar
I think its a fuel system problem.
I was trying to ump it again because i wans;t satisfied and i would turn over in natural but not in park. though it still wouldn;t start. So i believe the starter is fine. Interesting thing was when i was trying to start it the rive light would flash rapidly but only in neutral. So maybe a relay switch is bad and possible a fuel pump problem. Any thoughts?
Old 06-27-2009, 08:35 AM   #17
1337knub
1337knub's Avatar
yeah its not getting any fuel from the fuel pump.
All the fuses are good for that although there is some kinda fail safe that doesn't allow it to start in park if something was wrong with the fuel pump. or something like that. Any suggestions on how to fix this?
Old 06-27-2009, 08:56 AM   #18
Targa250R
be professional
Targa250R's Avatar
A problem with the fuel system will not prevent the car from cranking.
At this point I suspect the ignition switch. Try wiggling the key a bit while turning it to position III.
Old 06-27-2009, 09:23 AM   #19
1337knub
1337knub's Avatar
i believe it has something to do with the transmission relay switch or whatever because no lights come on for the park-neutral on in drive do those lights come on. Also if this were so it would inhibit the car from receiving fuel and thus no crank.
Old 06-27-2009, 10:58 AM   #20
accord99power
1999 Honda Accord
My Garage
fuel pump has nothing to do with the problem like mentioned before, to diagnosis your problem you gotta start from the source of what actually cranks your engine over (starter). have you checked for a singal to the starter??? no prolly not because you wanna guess whats wrong and not have us help you diagnosis it. you can either twildle your thumbs or actually make some progress your call. the ingnition switch could very well be the problem like mentioned before to. we can guess all day or just tell us the answers to our question.
Old 06-27-2009, 11:25 AM   #21
Targa250R
be professional
Targa250R's Avatar
The fuel injection system has nothing to do with cranking the engine. Nada. Zip.
Old 06-28-2009, 04:08 AM   #22
1337knub
1337knub's Avatar
Automatic transmission gear position switch. Fail safety that stops the starter from turning in park which also inhibits the fuel pump from engaging. Only in neutral would the starter turn however no gas will pump.
Not the starter. Not the battery. Not some other ****. Certainly not twiddling my thumbs.
Old 06-28-2009, 06:28 AM   #23
Targa250R
be professional
Targa250R's Avatar
I missed the point at which you mentioned that the car would crank in neutral.
Old 06-29-2009, 09:50 PM   #24
accord99power
1999 Honda Accord
My Garage
if the guy actually spoke english natural and neutral are 2 different things, if u cant get that right then how in the world do u expect us to know what you think crankin over means??? Hey glad u figured it out though buddy..
Old 07-01-2009, 08:52 AM   #25
choochoo
1989 Volkswagen GTI
My Garage
Have you tried jump starting it? Something similar happened to me a few months ago. Turned out to be a bad battery, it would hold charge overnight.
choochoo is offline   Reply With Quote
1992, 1998, 1999, 2000, 99, accord, bad, car, diagnosis, honda, jump, start, starter, turn, wont
