Loud screeching sound when i turn my car on...
Old 06-25-2009, 08:21 PM
_ijayyy's Avatar
Default Loud screeching sound when i turn my car on...
So, every time I turn the car on, it makes this loud screeching sound. I have to keep turning the car off and on until it doesn't make it anymore.
Old 06-25-2009, 08:23 PM
forcefedferio's Avatar
Default Re: Loud screeching sound when i turn my car on...
check your accessory belts sir, they are most likely worn, cracked, and glazed.
Old 06-25-2009, 08:24 PM
_ijayyy's Avatar
How much would it be to replaced ?
Old 06-25-2009, 08:26 PM
are you doing it yourself? do you still have A/C and P/S? aftermarket the belts are around $15 a piece at NAPA, expect labor to be somewhere around 1 hour for all three (off the top of my head) if you are getting it done somewhere. Exact price will depend on the shops labor rate.
Old 06-25-2009, 08:28 PM
_ijayyy's Avatar
I dont even know... Im taking it to the shop. Thanks for the help bro
Old 06-25-2009, 09:11 PM
eg grom's Avatar
bump on the belts...
For all three belts you can expect it to be around 130-150 as long as you don't take it to the dealership garages.
Old 06-25-2009, 09:42 PM
hushypushy's Avatar
Check the tension on your belts. The screeching means it's slipping; you can attempt to fix it by increasing the tension. For the alternator belt, you unbolt the alternator and slide it back. I just did this the other day and it changed it from screeching all the time to only screeching right after startup.
However, this is probably a sign that you need a new belt(s).
Old 06-26-2009, 01:05 AM
Honda-209's Avatar
i agree with this guy. my car had the same problem. it was the alternator belt, it was just loose.
Old 06-26-2009, 09:30 AM
jonrice's Avatar
tighten all your belts, a shop will rape you in labor, just search for a DIY
Old 06-26-2009, 09:54 AM
vtechjunkie's Avatar
"just do it" (yourself). It is easy!
Old 06-26-2009, 06:22 PM
MPH Imports's Avatar
bump on the DIY belts replacement..
Old 06-26-2009, 06:46 PM
thi3v3z's Avatar
Definitely do it yourself, very easy, but somewhat time consuming because to replace the a/c belt, you have to remove a motor mount. But alt belt and a/c super easy.
Old 06-26-2009, 07:08 PM
_ijayyy's Avatar
I need to let this stop doing it at all. 'Im taking my driver's test, and it'll fall me if it makes that sound.
Old 06-26-2009, 08:27 PM
hushypushy's Avatar
Put a new belt on then.
My alternator belt started going crazy today even though it's tightened all the way. Saturday project = me putting a new belt on in hot *** sun
Old 06-26-2009, 08:56 PM
yeah, not to mention if the damn alternator is somehow seized to the bracket and will not let the tension off the belt enough to get it off, i didn't think it could ever happen, until it happened to me. luckily i was already at work and my car was on the rack.
Old 06-26-2009, 10:24 PM
hushypushy's Avatar
Luckily I adjusted my alternator the other day (tightened it) so I know it moves freely. It shouldn't be too hard, I'm just pale as hell and it's 90+ outside.
Old 06-26-2009, 10:32 PM
FlewByU352's Avatar
my car has been making a belt squeak so I bought bekt dressing and it stops it for a bit but it will come back. I think i either need new ones or somthing because it goes away after spraying on the belt dressing
Old 06-26-2009, 10:34 PM
EFinawesomeman's Avatar
They make a belt conditioner and you can purchase it at local auto parts stores. Works pretty good.
Old 06-27-2009, 04:43 AM
MHDesigns's Avatar
Lol over 110 on a daily basis here. The garage is actually hotter cuzz the air stays still. Arizona sucks. To the OP just DIY. You will have to learn how to work on your car at some point, and with the help of this website you'll be building motors in no time...seriously though at least give it a shot.
Old 06-27-2009, 05:57 AM
alphalanos's Avatar
Dont pay anyone to do it. Get a good metric socket set and ratchets, extensions, a breaker bar, etc. Get a Haynes manual. The alt and ps belts are super easy. AC belt just support the oil pan with a block of wood. Remove the bolt on upper driver side motor mount and remove the torque mount underneath the frame. raise motor an inch or so and loosen belt tensioner.
Old 06-27-2009, 06:24 AM
thi3v3z's Avatar
you dont even need to mess with the upper mm, u can just unbolt the lower and slip it through the small gap. I managed to.
Old 06-27-2009, 11:34 AM
hushypushy's Avatar
haha, Arizona is madness, I could never live there. I'm used to San Francisco, where there are only two seasons: cold and sunny, and cold and cloudy. I went to Arizona once, for New Years a few years back, and I was blown away. Walking around at midnight in Tempe on December 31st and it was like 80º
I did mine today in the garage where it was probably mid 80's...still sweated like a pig. But I got my belt on, no more screeching yay!
looopson
05-26-2011 10:26 PM
ugly.
18
01-16-2010 08:47 PM
teamvirus
Honda Civic (2001 - 2005)
06-01-2009 06:49 AM
my4drGSR909
03-21-2005 05:51 AM
808style
07-31-2003 12:37 AM
Quick Reply: Loud screeching sound when i turn my car on...
