Old 06-23-2009, 06:22 AM   #1
ninjarico
ninjarico's Avatar
Default blower motor wiring 94 LX
So while tracing down the weird A/C problem I ended up taking off the wiring for the blower motor (which for whatever reason was spliced in oddly). Anyways I thought I recalled the wiring properly but now when you turn on the A/C it blows nearly nothing out the vents. You can hear the motor working, is there a possibility I wired it backwards?
I've got a blue wire and black wire coming off the motor. From the car I have a blue w/ red stripe and yellow with black stripe. I have it wired BLCK > BLUE/R BLUE > YLLW/B
Does that sound right? The wiring diagram only shows me the blue/r and yellow/b wire.
when did everyone become an *** and stop respecting one another?
ninjarico is offline   Reply With Quote
Old 06-23-2009, 06:45 AM   #2
billyrusa
billyrusa's Avatar
Default Re: blower motor wiring 94 LX
Disconnect the motor wires from the car. Directly connect one of the motor wires to ground and another wire to 12V. If the motor runs backwards, reverse the 12v and ground connections. When motor runs right, connect the wire with 12V to YEL/BLK and the wire with ground to BLU/RED.
billyrusa is offline   Reply With Quote
Old 06-23-2009, 07:02 AM   #3
ninjarico
ninjarico's Avatar
Will try that at lunch, I just assumed that if it was wired backwards that the motor wouldn't kick on at all.
12v, 2005, 94, accord, backwards, blower, civic, connection, control, diagram, disconnecting, fan, heater, honda, motor, runs, wiring
