==== The EG Ferio Squad ==== New & Improved!
#9551
Re: ==== The EG Ferio Squad ==== New & Improved!
None of this "ultra rare" stuff you posted is rare at all..
Your car is quite clean though, I must admit that.
#9552
since I cannot find out how to edit my posts here I will just post it again, this time with working pictures, also i know model kits arent part of the actual car, but it really adds on to the whole overall ferio enthusiast factor
thank you.
jeff (aka jefurii)
BASICS
Year: 1992
Manufacturer: Honda CDM (canadian domestic market)
Type: Civic
Doors: 4
Trim Level: DX
Engine Size: 1.5 Liter
Exterior Color: Black
Misc: 8 years history of receites
ENGINE
aem v2 cold air intake
new aem dryflow air filter
INJEN pre-filter hydro-shield
swapped intake manifold
new PCV valve
new fuel filter
new oem honda high pressure fuel line
swapped oem honda fuel rail
swapped oem honda injectors
new starter
new battery terminals and wires
new oem honda alternator
new oem honda cap and rotor
new oem honda ignition control module
new oem honda ignition coil
new oem honda spark plug wires
NGK iridium Spark Plugs
swapped manual transmission ECU
replaced oem honda water pump
new oem ECT coolent temp sending unit
adjust timing belt
new oem honda alternator belt
fixed and tightened power steering belt
new front cv boots
dc sports 4-2-1 ceramic headers
custom 2.5 inch magnaflow cat-back exhaust
magnaflow catalytic convertor
magnaflow resignator
new oem honda radiator cap
weksos "yowai-ss" radiator black anodized cooling plate
mishimoto aluminum radiator and fan
new black hood latch
new oil oem honda pan gasket
new oem honda oil pan
new oem honda oil drain plug
valve adjustment
new oem honda valve cover gasket
new oem honda valve cover upper o-rings
new oem honda valve cover lower o-rings
new engine fluids
flushed fuel system
flushed oil system
tucked wiring in both fenders
tucked wiring under engine
tucked most hoses
tucked battery wiring
tucked throttle cable
removed windshield washer components
relocated under the hood fuse box to under the dashboard
removed and polished rust off parts
stripped paint off valve cover and aluminum polished
replaced most rusty bolts
always runnin on Shells V-Power premium 92 octane fuel
TRANSMISSION
Automatic to Manual conversion
rebuilt transmission
new exedy clutch kit
swapped clutch and brake pedal
swapped clutch line
swapped clutch master cylinder
new VSS (vehicle speed sensor)
routed new wiring for reverse lights
new clutch slave cylinder
new transmission fluids
SUSPENSION
tein super street coilovers w/o pillow ball mounts
replaced rear upper strut caps
front blox upper control arms camber kit
energy suspension upper control arm bushings
rear camber kit
rear blox lower control arms (gold)
energy suspension rear control arm bushings
energy suspension front lower control arm bushings
energy suspension rear trailing arm bushings
replaced driver side lower front control arm
3-Point passwordjdm front strut tower bar
2-Point passwordjdm rear strut tower bar
2-Point passwordjdm rear lateral trunk bar
JDM DC ITR Front 25mm sway bar
w/ endlinks and bushings (not yet installed)
ASR 24mm rear swaybar
w/ blox endlinks and bushings
ASR Reinforcement Brace
BRAKES
new stoptech front drilled and slotted rotors
painted calipers red
'97 integra LS rear disc brake conversion
92-95 civic sedan brake 40/60 proportional valve for rear disc brake conversion
new oem acura integra sedan e-brake cables left and right for conversion
new oem acura integra banjo fitting brake hoses
custom reflared old brake lines for better hose alignment
new ceramic brake pads all around
re-adjusted e-brake lines (both ends)
new 91 civic si brake master cylinder
new brake fluids
RIMS & TIRES
falken azenis at615k 205/50r15 on 15" CDM dealership (canadian domestic market) Enkei rims
EXTERIOR
new windshield
15% tint (soon to be bronze)
front oem edm honda fog lights (white)
j-spec headlights with clear lenses and smoked housing
amber corner lamps
stanley side markers (not yet installed)
ultra white h4 HID bulbs
SIEBON carbon fiber hood
aerocatch flush hoodpin
replaced front windshield wiper trim and plugs
cut and removed rear bumper hitch off (previous owner)
replaced bumper support with new bumper (damaged)
edm rear dc2 foglight with switch
cut portion of rear bumper for rear foglight fitment
ultra rare jdm honda thin side moldings
BC2 rear lip (not yet installed)
rear jdm SIR II ferio carbon fiber duckfin spoiler
ultra rare jdm rear windshield visor (not yet installed)
ultra rare jdm honda eg9 rear windshield wiper, eg9 bronze glass, and brand new wiper motor (not yet installed)
ultra rare jdm honda black cloth rear dash to fit eg9 rear windshield wiper
spoon style civic sedan mirrors
jdm front license plate relocator
oem honda antenna plate cover
painted windshild wiper rods black
painted fog light housing covers black
painted rear toe hook gold
JDM black rear foglight switch
oem civic si black rugs
black molded carpet
black oem honda center audio console
jdm black long armrest (re-upholstered in recaro fabric not yet installed)
installed RadioShack Pizzo Buzzer for "headlights on" warning in fusebox
Grant steering wheel - trim painted black
honda emblem horn button
horn wiring now spliced with stock horn
2008 civic sedan low-pitch upgrade horn with relay spliced in
NRG steering wheel quick-release
ex gauge cluster
swapped speedometer
custom red gauge lighting (bulbs painted red)
disabled dimmer switch
custom red climate control lighting (bulbs painted red)
front upper jdm civic type r map light
swapped black civic SI dashboard - swapped VIN
jdm dashboard coin pocket/tray
re-configured dash buttons for clean look (hide gauge dimmer for coin pocket
jdm honda civic eg9 sir black interior door panels w/ grey suade (will re-upholster with recaro fabric and red recaro embroidering)
high density insulated strips for metal rods inside door panels to prevent vibration
type r style black shift ****
OBX polished aluminum spec-r pedal covers
oem dead pedal added
civic si black e-brake handle
recaro srd black suede with red stich front seats
black 4-point racing harness
black seat pillows
jdm DB8 integra type r sedan black suede with red stitch rear seats
Indash double din DNX5140 kenwood touchscreen navigation and Audio
oem honda cassett player temporary cover up
KCA-BT200 kenwood bluetooth unit w/ microphone hidden in steering column
routed gps wiring antenna into center dash vent
metra am/fm antenna hidden under headliner
3.5mm audio jack routed into center armrest for MP3 devices
USB hidden in center coin tray
infinity 5.25"speakers/tweeters in front
pioneer premier 5.25" speakers/tweeters in back
two JL audio W1V2 10" subwoofers (not yet installed)
14 gauge monster wire to all 4 speakers
insulated trunk compartment floor (sound deadener)
un-installed spare tire
insulated passanger compartment floor (sound deadener)
new tough false trunk floor
new carpet on false trunk floor
new oem rear trunk latch trimming
new stock carpet to re-uphulster trunk liner
new oem rear trunk/cargo light added
painted dash trimmings black
painted interior garnishes black
painted door sills black
painted lower pillars black
EXTRAS
extremely rare civic models
super rare 10/10 mint condition civic ferio dealership catalog
thank you.
jeff (aka jefurii)
BASICS
Year: 1992
Type: Civic
Doors: 4
Trim Level: DX
ENGINE
new PCV valve
new fuel filter
new starter
adjust timing belt
new front cv boots
valve adjustment
new engine fluids
flushed fuel system
flushed oil system
tucked most hoses
TRANSMISSION
swapped clutch line
SUSPENSION
rear camber kit
BRAKES
new brake fluids
RIMS & TIRES
EXTERIOR
new windshield
amber corner lamps
black molded carpet
ex gauge cluster
swapped speedometer
black seat pillows
EXTRAS
#9553
haha yeah i know, but to the ferio noobs its "ultra rare" haha, alright, the post has been edited since it does sound kinda stupid, lol, but international shipping costs have gone up 20% in the last year so it wont be long till its true! even my buddy in the philippines is giving me heads up about it and even he is having a hard time finding stuff mint, i only go mint or fixable
#9554
here's better pics...they are older so a lot of mods have been made since then. New pics will come soon. Am i part of the squad now? :D
#9557
im new to posting on forums here, but i am definitely not new to keeping myself informed on this thread! as you can see ive been a member on this darn thing since 06 so when i get some newer pictures up i want some votes peeps! this is not usdm, or even jdm, its cdm! canadian!
#9558
#9559
#9560
#9561
someone beat me to sir2 interior dammit but i found a guy in texas that is letting eg9 ferio seats the grey center instead of purple checkers for 650 n they fresh *** hell just that shipping gonna be alot
#9563
#9564
how come the starter of this thread hasnt given anymore voted members than #30?? or am i mising something, i havent read all pages
#9566
the models not only took me a decade to find, but they also cost me a fortune when i found them, it truely isnt worth the purchase if you dont value the ferio enough, but none of us here have that problem
#9567
some goodies ill be getting next month :D
all black plastics for interior, eg9 tweeter, rear gathers, eg9 seatbelts, rear antenna with half pole switch (not pictured) uuughhh can't wait
#9568
#9570
hey squad got a few little teaser pics for u until i give her a proper claybar polish and wax treatment with the DA. Recently got a love tap on the freeway to my rear bumper so had that replaced by insurance with a HOP bumper and while they did that the body shop prepped and paint matched my EG9 flush spoiler. Came out great couldnt be happier!!
real photo shoot on its way tryin to be a part of this squad!
#9572
looks good, wish i took advantage of that when i got rearended, too bad it worked against me since I was one day away from putting insurance on it at the time so they gave me a ticket instead
#9573
i found some decent pictures from last year, this is when i didnt have the spoiler on yet and it has snow tires, lol
P.S. if anyones interested a guy on ebay is selling brand new oem sir eg9 front lips by the handful, just bought mine today! a late christmas present for myself :D
#9574
thanks pls thats one vote down and how many to go??
Thanks yeah it turned out great, but that sucks they gave you a ticket and you had to pay for the damages?? thats harsh. I got very lucky, ended up taking the car to a BMW certified shop, made sure they ordered an OEM Honda bumper and got to sell my old bumper =D
btw your car looks great, black is always hard to keep clean! sounds like you have alot of gooodies keep us updated
#9575
actually the damage wasnt too bad since a the time i had a hitch on the back from the previous owner, can you believe that? a hitch on a civic.. maybe for a bike rack cause that **** was small, lol, anyways, it barely scratched the bumper but it somehow ripped it off all the bolts on top and the sides, so for now I just have the bumper on it with pressure from the washer bolts, lol
