Old 06-20-2009, 06:47 AM   #1
GOOCH-JDM-ITR
GOOCH-JDM-ITR's Avatar
Send a message via AIM to GOOCH-JDM-ITR
Default Sinking brake pedal with SPOON clappers
Hi, I have a 1998 Acura INtegra GSR. Been running the stock front calipers for sometime. I tried a Legend caliper upgrade but had this problem with the pedal being firm with the engine off, but as soon as I start the car the pressure dissappears and the pedal starts sinking, slowly. After 2 years (with OEM calipers) I tried out some spoon calipers, and Im having the same issue. I really DONT think its the MC since I replaced it before and still have the old one which was just fine, nor do I think its my bleeding procedure. I can throw the old clappers back on, bleed, and be good with-in minutes. Its just all these damn multi piston units that are giving me a headache. Any suggestions?
Heres what I have
1" OEM GSR -MC (new and replaced after this issue)
http://honda-tech.com/showthread.php?t=1477259
Russell stainless brake lines.
98 ABS Moduator
ITR/ Prelude rotors redrilled to 4x100 (fastbrakes)
Used SPOON twinblock calipers.
SuperBlue brake fluid (dot4) just swapped in.
again brakes seam fine with engine off. Its just once I fire up the car the pedal begins to sink slowly to the floor.
Thanks!
Mike
my b18c LHT-JRSC build thread
GOOCH-JDM-ITR is offline   Reply With Quote
Old 06-20-2009, 09:47 AM   #2
sti grip
sti grip's Avatar
Default Re: Sinking brake pedal with SPOON clappers
sounds like theres some kinda of vac. leak
but sell me you spoones haha
did you chk you lines? could be the calapers need to be reworked and or your porportion valve needs to be upgraded?
00 PY ITR dd build/00 NBP ITR track car build
01 PY ITR- sold\98 CW ITR-sold\96 spec CW DB8R-sold\96 Spec CW itr-sold
Tundra..... the TowTruck.... i cant stop.......
sti grip is offline   Reply With Quote
Old 06-20-2009, 12:45 PM   #3
95 integra
95 integra's Avatar
iTrader Rating: (1)
Could be the brake booster. I had a similar problem w/ a toyota truck and that was the issue.
- After 8 years I have an Integra that isnt making that damn buzzing sound from the abs pump.
- 2003 Berlina Black S2000 w/ OEM Hardtop and some other OEM goodies.
95 integra is offline   Reply With Quote
Old 06-20-2009, 01:26 PM   #4
JDMDALOUIE
1990 Nissan 240SX
JDMDALOUIE's Avatar
Send a message via MSN to JDMDALOUIE
I had this problem a couple weeks ago on my DA I replaced the booster and problem solved.
I <3 My S13
JDMDALOUIE is offline   Reply With Quote
Old 05-04-2010, 04:28 PM   #5
6SPD_EK
6SPD_EK's Avatar
iTrader Rating: (2)
I have the same problem - when the car is off there is a good pedal feel but when the car is running the pedal sinks to the floor.
I thought this shows the booster IS working because of the vacuum assist - how could the booster being bad cause this?
6SPD_EK is offline   Reply With Quote
Old 05-04-2010, 06:14 PM   #6
danthemang3
danthemang3's Avatar
yeah just sounds like you have air in the lines, did you bench bleed the master cylinder?
Vouches: sketch hs, 95 integra, bad-monkey, kidd drastic, raiden571, enigmaEG6, wahabum, type-G, CW-ITR, tegra8, tiNnNy, ieatrice, NMBB6, SMOOTHN, cnsurf929, JDM-James, civteck, crexer
danthemang3 is offline   Reply With Quote
Old 05-04-2010, 06:28 PM   #7
Spawne32
Spawne32's Avatar
iTrader Rating: (3)
Send a message via AIM to Spawne32
sinking brake pedal is usually a good sign of air
DDTECHCAMS.COM - CNCWERX - OSIDETIGER - SPEED TRAPP CONSULTING TURBOS - SKUNK2
Originally Posted by 95LTX
my car hasnt had 02 sensors in.. forever. it roams around in a open loop speed density tune. killing small children and raping helpless mothers at night.
Spawne32 is offline   Reply With Quote
Old 05-05-2010, 05:52 AM   #8
morgan@synapse motorsport
H-T Basic Sponsor
morgan@synapse motorsport's Avatar
Send a message via AIM to morgan@synapse motorsport
(w/regards to 6spd_ek) We have properly bled the system over 100 times... seriously
the MC was bench bled as well... pedal feels very stiff & hard (like it should) when the car is NOT running. start the car & the pedal sinks to the floor. when running a couple of pumps of the pedal & pressure is there (for a second) then pedal sinks to the floor
morgan@synapse motorsport is offline   Reply With Quote
Old 05-05-2010, 06:30 AM   #9
PatrickGSR94
1994 Acura Integra
PatrickGSR94's Avatar
iTrader Rating: (1)
Send a message via AIM to PatrickGSR94
When the car is off, you should be able to pump the brakes a couple of times, and then the brake pedal gets rock hard after that.
I had a problem where my brake pedal was hard immediately after turning off my car and all the time when off. The problem turned out to be the MC piston seal between the MC and booster, which I attributed to getting trashed because of the MC brace I used to have on the shock tower.
I replaced the MC piston seal and all has been good ever since. No need to unbolt any brake lines, just unbolt the MC from the booster and slide it off the studs (hard lines can flex a bit), replace seal, bolt MC back on.
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline   Reply With Quote
Old 05-05-2010, 07:27 AM   #10
Spawne32
Spawne32's Avatar
iTrader Rating: (3)
well the brake system isnt THAT complicated that if you are certain that there is no air and that the calipers are good, that you wouldnt be able to narrow down the problem, theres only two other parts in the system, and thats the master cylinder and the brake booster, so obviously your problem lies in either one of those areas.
Old 05-05-2010, 11:08 AM   #11
94VTECoupe
94VTECoupe's Avatar
Send a message via AIM to 94VTECoupe
The booster wouldn't cause your pedal to sink to the floor... And if you've ruled out the brake master cylinder and the bleeding, then I'm going to go on a limb...
It really sounds like you're not building pressure fast enough, and that said, I would think maybe since you're running huge calipers on the front now which require more fluid to get to them more rapidly, you might be having some sort of strange braking proportion issue... aka your prop valve doesn't give the big brakes the pressure they need when they need it, which would give you a slow pedal response and would make the pedal go down slowly...
again, doesn't seem too logical to me, but you seem to have ruled everything else out... sooo...
94VTECoupe is offline   Reply With Quote
Old 05-05-2010, 11:30 AM   #12
Spawne32
Spawne32's Avatar
iTrader Rating: (3)
spoon calipers shouldnt be too big for the cars master cylinder at all, if he isnt building pressure fast enough, i would still attribute it to a master cylinder or brake booster
Old 05-05-2010, 11:38 AM   #13
logg_frogg
logg_frogg's Avatar
you have air in your lines... bleed your brakes, then bleed them again.
The reason the pedal sinks when you have the vehicle running is becasue the brake booster reduces the amout of pedal pressure you need to activate your brakes... making it far easier to compress air in the lines.
If you bleed the system properly you wont have a problem!
Rice? I ferment mine and make it into rocket fuel. Why? What are you supposed to do with it?
My Cardomain Page : http://www.cardomain.com/ride/2496279
logg_frogg is offline   Reply With Quote
Old 07-06-2010, 01:03 PM   #14
H-T Basic Sponsor
6spd_ek has since replaced the MC with a new OEM ITR one. I then pressure bled the system running 4qt thru each corner. the problem remains
Old 07-08-2010, 08:48 PM   #15
fergs96integra
fergs96integra's Avatar
Send a message via AIM to fergs96integra
how are the rear brakes? Pull the calipers off and check the seals and make sure they are all good. Also i hate to ask but i have seen it before. Do you have the calipers on the right sides?
"Still trying to finish your k swap......New and improved hybridracing site <-----check it out!!!
fergs96integra is offline   Reply With Quote
1996, abs, acura, bleed, brake, calipers, clappers, integra, pedal, pedals, pump, sinking, sinks, spoon, tl
