> Honda Civic (2001- 2005)
Old 06-19-2009, 06:14 PM   #1
Jstans84
2002 Honda Civic
Jstans84's Avatar
Send a message via AIM to Jstans84
Default Aftermarket Radio Removal DIY
Alright well this is going to be my first DIY so don't bash it too bad.
Tools Needed:
Phillips Screwdriver x1 (I recommend using a short one and a long one)
Small Flat Head Screwdriver x1
10mm Socket (to remove battery connectors)
8mm Socket (might be needed)
Panel Puller (optional)
Ok the first step is going to be to remove the battery terminal connectors.
For 01/02 models start here for 03-05 look below the pics for the instructions for both a Manual and Automatic follow those steps starting at step 3.
After that you are going to pull off the 12v Plug Panel, to do that simply pull it out and up.
Once you have it out you are going to remove the connector that hooks to the 12v socket and if you have OEM fogs the connector that goes to the fog switch.
Once you have that out just set it aside.
Next you are going to look up under the radio where you removed the 12v Panel, you should see either 2 8mm screws or 2 Philips head screws remove them and set them aside.
Alright now it is time to pull out the Radio Panel. Simply slide any flat object be it a screw driver or a panel puller into the edge of it and use that to gently pry the panel out.
Once that is out you can pull the radio panel out a little ways. Once you have it out you need to disconnect the wires that are hooked to the radio. First remove the connector that goes to the emergency lights(my fingers are covering it up), Next remove the antenna connector on the top right(may be in a different place depending on your radio), than disconnect the two green plugs that go to the climate control panel, finally the connector that hooks to the back of your radio. DO NOT TRY AND PULL IT OUT NOW THERE IS STILL ONE MORE CONNECTOR TO REMOVE.
Lean the radio panel forward a little and you will see another green connector disconnect that and you can remove the radio panel completely.
(The next two steps are somewhat optional but they make it easier in the long run)
On the front of the panel you are going to need to pull off the climate control knobs. To do this simply grasp them and pull they come right off.
Once those are off turn the panel around and unscrew the 3 screws that connect the climate control unit and simply remove it and set it aside.
You might have screws connecting your radio to the harness you might not. If you do they will be located here (why you needed to remove the climate control panel) and on the other side in the same spot.
After those are out look under the A/C vents and press down on the tabs with a screw driver or your fingers if you can reach them while pushing forward at the same time. The radio harness will slide out of the panel from the front.
After it is out it is easy to get the radio out simply push down on the tabs that are sticking up on the top, sides, and bottom.
Once they are down simply slide the radio out from the front and slide your new radio in.
For the purpose of wiring simply read the instructions in the back of the instillation manual that came with your radio. Once you have the wires connected simply follow the steps in reverse and slide every thing back in.
For all you 03-05 people follow these steps first than go back to step 3 up top.
Manual
1.Open cup holder.
2. Pull down chrome collar under gear shift knob.
3. Unscrew gear shift knob and remove.
4. Pry up all edges of gear shift trimpanel to release and remove.
5. Remove two (2) phillips screws exposed by removal of gear shift trimpanel.
6. Push out rear clips securing sides of console trim with a flat blade screwdriver.
7. Lift rear console trim and pry front of trim toward rear of vehicle to release clips. Disconnect harnesses and remove trim.
Automatic
1. Carefully pry up gear shift trim ring.
2. Pry up gear shift trim from three points on each side and remove trim.
3. Remove two (2) phillips screws from console trim exposed by removal of gear shift trim.
4. Push out rear of clips securing sides of console trim using a flat blade screwdriver.
5. Lift rear of console trim and pry front of trim toward rear of vehicle to release clips. Disconnect harnesses and remove trim.
Hope this helps.
From the previous DIY thread:
http://www.megaupload.com/?d=2F1IYZ9Y
http://www.jigglz.com/images/FRINSTALL.pdf
Download the FRINSTALL file for a guide on:
- How to install an aftermarket headunit
- How to remove door panels
- How to install front/rear speakers for both coupe/sedan.
Speaker sizes:
Coupes have 6.5" front and 6x9" rear.
Sedans have 6.5" both front and rear.
Jstans84 is offline Report Post   Reply With Quote
Old 06-19-2009, 06:20 PM   #2
ALLxMOTOR EG
Vietnamese!
ALLxMOTOR EG's Avatar
Default Re: Aftermarket Radio Removal DIY
Good enough
ALLxMOTOR EG is offline Report Post   Reply With Quote
Old 06-19-2009, 06:51 PM   #3
toyomatt84
Sanji
toyomatt84's Avatar
Send a message via AIM to toyomatt84
Edited to be the new link in the FAQ thread.
*free hugs*
IA '09: Midwest Caravan (Click to join us!)
toyomatt84 is offline Report Post   Reply With Quote
Old 06-19-2009, 06:58 PM   #4
TDS_LeGenD
Wow thanks a million man. I really appreciate it.
-2001 Honda Civic EX 5 speed-
TDS_LeGenD is offline Report Post   Reply With Quote
Old 06-19-2009, 07:31 PM   #5
Gibson5469
Gibson5469's Avatar
I did this about 5 times today troubleshooting a blitzsafe alpine/honda changer adapter.
instead of prying the HVAC/RADIO unit out from the dash and possibly denting/damaging the soft dash material, I just pushed from the back and it started to pop out.
I did manage to lose one of the metal clips from the top left tab on the HVAC unit, heard it fall into the dash
Gibson5469 is offline Report Post   Reply With Quote
Old 06-19-2009, 10:02 PM   #6
Jstans84
2002 Honda Civic
Jstans84's Avatar
Yeah I was really careful to not dent it up at all. It honestly would have worked better had I used one of those panel remover tools. But the flat head did the trick just fine.
Old 06-22-2009, 09:22 PM   #7
cityhunt3r911
cityhunt3r911's Avatar
I did this my dimmer doesnt work anymore its always on bright i cant adjust the lights anymore..
can anyone help theres a illuminater white orange wire and a solide dimmer orange wire where does that wire go?
cityhunt3r911 is offline Report Post   Reply With Quote
Old 08-05-2009, 06:20 AM   #8
Jstans84
2002 Honda Civic
Jstans84's Avatar
Hey let me check for you, sorry for not noticing this earlier. Are you using a wiring harness or are you just splicing lines?
Bookmarks
2007, 2009, accord, aftermarket, civic, control, diy, head, honda, install, knob, radio, removal, remove, removeing, slide, temperature, unit
