Old 06-18-2009, 02:49 PM   #1
eglude
eglude's Avatar
Default fast idle valve
so i have a 95 civic hatch with a d15b, i picked up a p32 intake manifold (d16z6 manifold) i go to hook everything up and the hose that goes from the bottom of the fast idle valve has no where to hook up on the intake manifold. this **** sucks. how do i go about fixing this problem? thanks in advance
95 hatch, 00 prelude, 05 benz, 68 cutlass 442, 69 camaro
eglude is offline   Reply With Quote
Old 06-18-2009, 03:45 PM   #2
eglude
eglude's Avatar
Default Re: fast idle valve
bump for help
Old 06-18-2009, 04:08 PM   #3
D16SiHatch
D16SiHatch's Avatar
Send a message via AIM to D16SiHatch
it starts at a L shaped hose at the intake manifold, and from there it moves through a metal tube to another hose which then goes to the inlet of the fitv. after leaving the fitv it goes to the iacv. once leaving the iacv it drops down and connects to the coolant pipe on the back of the block.
00 BMW 323i, black int, sport pkg, 5 speed
95 ej1, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, t3/t4 10psi
D16SiHatch is offline   Reply With Quote
Old 06-18-2009, 04:35 PM   #4
DjGuamstyles
DjGuamstyles's Avatar
Send a message via AIM to DjGuamstyles
Nice diagram above. I heard, some drag racers bypass the FIT-V so the intake manifold temperature is lowered.
DjGuamstyles is offline   Reply With Quote
Old 06-18-2009, 04:44 PM   #5
apexi_rsx
Send a message via AIM to apexi_rsx
yes thats what i would do because its pointless if u live in warm climates. just by pass the tb and run the lines to ur iacv. ebay acually makes block off plates b/d/f/h all fit
06 Rsx Type S I/H/E ...14.0@101
97 civic 4dr turbo
apexi_rsx is offline   Reply With Quote
Old 06-18-2009, 04:58 PM   #6
eglude
eglude's Avatar
thanks, this is going to help a lot! where did you get this diagram from?
Old 06-18-2009, 05:44 PM   #7
civic_driver
civic_driver's Avatar
probably from the service manual
For Sale Thread
civic_driver is offline   Reply With Quote
Old 06-18-2009, 09:34 PM   #8
D16SiHatch
D16SiHatch's Avatar
i cropped out a picture i retrieved from AllData. I have a dealership login :D
then with the help of mspaint i added the awesome red lines and numbers lol
Old 09-14-2012, 11:53 AM   #9
GSRicky37
Az Cannon602
This is so helpful I just did the exact same thing but my throttle cable doesn't mount right so it either to tight or too loose. Why?
GSRicky37 is offline   Reply With Quote
1992, b18b1, back, block, civic, coolant, d16y7, diagram, fast, fixing, honda, hose, idle, intake, manifold, si, tube, valve
