??Bad water pump sounds like???
Old 06-18-2009, 04:25 AM
misterknowbody's Avatar
Default ??Bad water pump sounds like???
I think my water pump died on me. Well I hope it's the water pump, the sound is coming from somewhere around there.
What does a bad water pump sound like on a 92 SI 1.6L SOHC?
Old 06-18-2009, 04:28 AM
bronx finest's Avatar
Default Re: ??Bad water pump sounds like???
bad water pump sounds like leaking antifreeze, and overheating.
Old 05-24-2010, 03:44 PM
Cogent Argument Enthusiast
Uncle Ben's's Avatar
Bump. Can a bad water pump lead to coolant evaporation, if none is burned in the CC and is leaking from nowhere; intermittent overheating?
Old 05-24-2010, 05:51 PM
Technical Hero
HondaPartsHero's Avatar
could be a small leak in the weep hole, that or your radiator has a hairline that's causing the leak but is evaporating off
Old 05-24-2010, 06:48 PM
You mean a 96-00 water pump will squirt water out if they're bad? Where would it go, if it's inside the timing cover?
I never thought about the radiator having a crack, but that might explain why the top of the radiator is dry, and it only takes like 1/8 a gallon to fill it back up. Either that or the water pump is doing nothing and coolant just sits in the bottom of the radiator/engine block lol.
DumaDA
06-25-2011 12:50 PM
Champs32
02-13-2009 11:32 AM
tominos
09-10-2004 08:38 PM
dclub01
04-05-2003 01:50 PM
1 2 NV
05-12-2002 09:16 AM
Quick Reply: ??Bad water pump sounds like???
