The Official Honda-Tech EP3 Squad
#5076
Re: The Official Honda-Tech EP3 Squad
Sup guys. Getting ready to finally install my Tein coilovers and have a couple of question.
1. I bought new tie rod ends, lockin nuts, and cotter pins. Anything else I should replace while I'm down there?
2. I also have a Progress sway bar/tie bar combo I wanna install while I have the suspension out, what else is needed for this?
3. I am by no means slamming the car but I do plan to lower quite a bit, will I require a camber kit? From what I researched I've decided to run -1F, -.5R and zero toe. Is this possible without aftermarket camber kits?
#5077
The front coilovers should have an adjustment for camber built into the top hats. As for the rear, you'll need an adjustable UCA to make adjustments. I'm pretty low with -1* front/-3.8* rear with 0* toe, so that shouldn't be a problem. As for the sway bar, I've still running 100% stock components but I've heard/read that the stock end links are prone to breaking.
#5078
#5080
Yes, you will need an adjustable UCA to correct rear camber. I just did what was necessary to make 225/50's on my 16x7+40 slips clear an unrolled qp at the time.
#5082
I'm not running that beefy of a tire nor do I plan on running a stupid amount of camber. I'll put an Ingalls rear camber kit next on my list to get.
#5086
^^^not the final tune^^^ she's down again for some more upgrades: sidewinder manifold, painted valve cover, arp wheel studs etc etc...
#5088
Forgot this still existed! Still haven't installed my coilovers Finally ordered a rear camber kit though. New rims and tires are next!
#5090
1 Post
Hey SickSi,
I didn't use the magnaflow catback... I ended up using the Vibrant Stealth Noir 2.75" and had it fitted to my 2.75" mid pipe. It had a nice deep sound loved it!
#5092
1 Post
no problem bud!
Post up a video when you have it done... I miss my EP3
Also miss talking to most of you like Charleso, Cloumep3, aspire, nahonda04 and JoshEP3... man those were the good old day
#5093
I will once I get it installed. Thinking of getting an OBX race header along with the new exhaust. Just got the new clutch installed and its smooth like butter.
#5096
Man I just haven't had time with school and such to work on the car. But graduation is next month which will open the rest of the week to mod!
