| Welcome to Honda-Tech! | ||
#1 |
1994 Honda Civic |
I have a 91 civic hatch and I need to replace the fuel pump. how do i do this because i cant find any fsm anywhere for this. I am putting in a GSR fuel pump cuz i am running a b16a so if you could help that would help thanks a lot.
#2 |
you don't need to put in a gsr pump to run a b16a, we already covered this in the other thread you made about this..
but whatever i guess. its also not that difficult, but here's the steps.. fuel tank removal: 1. Block front wheels, then jack up the rear of the car and support with jackstands. 2. Remove the drain bolt and drain the fuel into an approved container. 2. Remove the rear seat and disconnect the 4P connector. 4. Remove the two-way valve cover and the fuel hose protector. 5. Disconnect all hoses. CAUTION: When disconnecting the hoses, slide the clamps back out of the way, then twist the hoses as you pull them back to avoid damaging them. 6. Place a jack, or other support device, under the tank. 7. Remove the strap nuts and let the straps fall free. 8. Remove the fuel tank. NOTE: The tank may stick to the undercoat applied to its mount. To remove, CAREFULLY pry it off the mount. 10. To install, replace the washer on the drain bolt, then reverse the above procedure. fuel pump removal
00 BMW 323i, black int, sport pkg, 5 speed 95 ej1, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, t3/t4 10psi |
#3 |
1994 Honda Civic |
yeah it's because i lost the other thread sorry
| Tags |
| 91, change, civic, dx, ef, fuel, gas, hatch, honda, pump, pump91, removal, remove, replace, tank |
