dashboard lights, clock, radio not working! help
Old 06-06-2009, 07:17 PM
hellraiser7492's Avatar
Default dashboard lights, clock, radio not working! help
So my Dashboard Lights, clock, and radio are not running right now.
I realize it could be a fuse or a ****ed up wire, but is there anything special i should look at? i find it really odd that all three are out at once, i checked all the fuses and they all came up how they were supposed to.
im stumped:-/
(89 CRX SI 1.6L SOHC ZC)
also if anyone has any websites that show how the fuses go in exactly that would help
Old 06-06-2009, 07:40 PM
Default Re: dashboard lights, clock, radio not working! help
im stumped:-/
i just went and checked and according to the diagram under the fuse box, some of the amps were in the wrong place, i fixed them(like some had where 7 and 9 were supposed to be empty and 7 had a 30 amp in it..
hmm wtf?)
Old 06-07-2009, 06:28 AM
EFB055
~sp33~'s Avatar
Often the accessories will share a fuse, so if one goes, they all go.
It could have been a short somewhere, so if you replace it, and it blows again, start looking for exposed wires.
Old 06-08-2009, 01:30 AM
sorry i took so long to reply
the weird thing is,
all the fuses are correct and working, and i dont wanna like take it apart and whatnot without looking for more things rather then just taking off the dash
Old 06-08-2009, 06:40 AM
88whitehatchidaho's Avatar
does it have an aftermarket cd player? almost every time i see problems like this it is usually in the wiring for the cd player i could be wrong but its some where to start i have fix about four or five that were like that(tape comming off connections and shorting out each other, because it seems like around here nobody has ever heard of butt connectors lol)
Old 06-08-2009, 07:12 AM
dr_latino999's Avatar
How are your turn signals? I have a weird feeling this could be an ICU related issue.
Old 06-09-2009, 08:10 AM
its sort of aftermarket but not like a new *** one it's fairly old. and the cd player before it actually shorted wires but we cut them and rewired them.
my turn signals are fine, the only thing that is odd with the signals is when i press my hazard lights they click and take a sec or two to start and make a buzzing sound like crazy before they start.
any ideas?]=
Old 06-09-2009, 08:35 AM
Cnile1's Avatar
Seems like you have a short somewhere...
The best thing to do is run through the wires.
You should find the answer if you do that.
Your dash doesn't have the fuse diagram on it?
Old 06-09-2009, 08:37 AM
its hard to run thru dash wires tho]=
but yeah it does have a fuse diagram but the fuses aren't shorted
Old 06-09-2009, 06:59 PM
sepheroth's Avatar
it will only take a few hours to pull your dash out and look at the wires...my dash harness caught fire. So i have the whole thing ripped out right now.
Old 06-09-2009, 07:01 PM
sepheroth's Avatar
pull the glove box, center console, steering wheel, turnsingnal/wiper, gauge cluster, and there is around 5 main bolts and the whole dash comes out
Old 06-09-2009, 09:55 PM
Cnile1's Avatar
You don't even need to take out your whole dash.
Try putting on all the switches to your lights that are out and stick a circuit tester through every wire. The wires that are short won't light up the circuit tester. You'll have to replace the section of the wire that is short. Then it should work. You gotta troubleshoot the problem bro. I think all the wires run through the fuse box. You can reach them all right there by the fuse box.
velocity66
08-04-2011 03:17 PM
jdmyo21
Honda S2000
09-21-2009 01:15 PM
blackakkord
01-31-2008 05:46 PM
ilovemydc5
05-20-2007 07:30 PM
4DooRGiSzer
03-31-2005 06:44 PM
Quick Reply: dashboard lights, clock, radio not working! help
