Old 06-06-2009, 09:11 AM   #1
UnleashedEJ1
1995 Acura Integra
My Garage
UnleashedEJ1's Avatar
Send a message via AIM to UnleashedEJ1
Icon2 Car shakes at 65 and over? help
I Lowered my 1998 Civic DX hatchback about 2 months ago, I used Arospeed coilovers with my oem shocks. Car seemed fine until I hit the highway around 65mph and over the wheel shakes, not crazy but enough to keep me under 65mph. So I took the car in for a 4 wheel alignment. It didnt change a bit. also I noticed when I hit large bumps or holes int the road the wheel also shakes hard and feels loose, but all other driveing conditions seem normal. Please let me know if you have any sugestions. And the wheels and tires are 16"x7" and tires are 205/40/16 and are balanced. Thanks
I ♥ My Honda
"Hella Tired of Stance!"
DC Squad #30
UnleashedEJ1 is offline   Reply With Quote
Old 06-06-2009, 09:16 AM   #2
Fook_me_honda
Fook_me_honda's Avatar
Send a message via AIM to Fook_me_honda
Default Re: Car shakes at 65 and over? help
Have you checked to see if there are any loose bolts? Or bad balljoints somewhere. You can usually tell by leaking grease.
Fook_me_honda is offline   Reply With Quote
Old 06-06-2009, 09:33 AM   #3
UnleashedEJ1
1995 Acura Integra
My Garage
I didnt notice anything out of the ordinary, I will check again. and I would hope the shop would have noticed an issue with the alignment. they didnt say they saw anything.
I ♥ My Honda
DC Squad #30
Old 06-06-2009, 09:57 AM   #4
Stine
How do you know the wheels are properly balanced?
Stine is offline   Reply With Quote
Old 06-06-2009, 10:01 AM   #5
waaBAAH
waaBAAH's Avatar
Send a message via AIM to waaBAAH
+1
and whoever balanced your tires did a bad job.. go take it back. tell them your car shakes at 65 mph
waaBAAH is offline   Reply With Quote
Old 06-06-2009, 10:48 AM   #6
thunee
If it's not your alignment, check the installation of your coilovers again. try to tweak the height adjustment.
thunee is offline   Reply With Quote
Old 06-06-2009, 11:03 AM   #7
yoontim23
yoontim23's Avatar
and check the axles. We had like 3 of these threads in the past week already.
*EK SQUAD!*
yoontim23 is offline   Reply With Quote
Old 06-06-2009, 11:06 AM   #8
809JDM
809JDM's Avatar
Send a message via AIM to 809JDM
Check for loose wheel nuts also
809JDM is offline   Reply With Quote
Old 06-06-2009, 11:34 AM   #9
skodi
skodi's Avatar
Send a message via AIM to skodi
just a wheel balance problem im sure.. start w the easiest first though: tighten lugs, suspension, check balljoints etccc
Phillthy.
skodi is offline   Reply With Quote
Old 06-06-2009, 11:38 AM   #10
philosofy1
philosofy1's Avatar
how many miles do you have? if you are on oem shocks, chances are the shock need replacing. depending on how low you have it, you might have blown them. it doesn't take much to blow shocks.
also, check your tires. there can be a bubble on it. these are all possibilities.
VTEC Cam Identification: http://www.ff-squad.com/tech/temp/VtecCams.htm
philosofy1 is offline   Reply With Quote
Old 06-06-2009, 01:26 PM   #11
green99civic
green99civic's Avatar
Send a message via AIM to green99civic
Probably either need an alignment or your tires need to be re-balanced
Alfred State Auto Tech Grad
ASE Certified
97 DX Civic Coupe (Green)
green99civic is offline   Reply With Quote
Old 06-06-2009, 05:58 PM   #12
UnleashedEJ1
1995 Acura Integra
My Garage
Ok all is great info, thanks. The car has 97,xxx miles, and was completly fine before i lowered it, tires are almost new with very little wear. I lowered the car and put the wheels on at the same time. Some time this week I am going to put the 14" stock steel wheels on and hit the highway, the only reason I dont think it is a tire balance issue is the shaking when I hit large bumps and holes. the shocks seem fine all but the driver rear, it is starting to go bad. all other driving is smooth and responsive. I hope this is one of the minor issues, Ill keep the post informed with any progress, Thanks
I ♥ My Honda
DC Squad #30
Old 06-06-2009, 09:07 PM   #13
Stine
Sounds like you may have 2 problems. Throw on the 14's and let us know what happens. Does the car bounce up and down excessively after the bumps(rear shocks = blown) or explain what you mean by "shaking" further.
Old 06-06-2009, 09:19 PM   #14
BigLazy55
2000 Honda Civic
BigLazy55's Avatar
how new are ur tires?
BigLazy55 is offline   Reply With Quote
Old 06-07-2009, 07:47 PM   #15
UnleashedEJ1
1995 Acura Integra
My Garage
I dont have much bouncing, the car drives pretty good for coilover sleeves. when i say shakeing its very sutle shakeing of my steering wheel around 65mph and over. tires on the front have maybe 2-3000 miles and rear tires I bought used with about 75% tread left.
I ♥ My Honda
DC Squad #30
Old 06-08-2009, 11:53 AM   #16
eros18
eros18's Avatar
OMG! not another WHEEL BALANCE suggestion
ok
you can deduct the problem by doing this
you already checked for alignment
check wheel balance like they always suggest
check the axles
Define RICE
"if it doesn't look like my car, it's RICE"
This is why i don't care if my car looks RICE
eros18 is offline   Reply With Quote
Old 06-09-2009, 02:01 AM   #17
mrjdmek98
my 98ek does the same thing but i know i need my driver side axle.
mrjdmek98 is offline   Reply With Quote
Old 06-09-2009, 08:44 AM   #18
waaBAAH
waaBAAH's Avatar
ok
check the axles
i would love to hear your explanation of why it wouldnt be a wheel balancing problem?
Old 06-09-2009, 08:54 AM   #19
Jimster480
Jimster480's Avatar
Send a message via ICQ to Jimster480 Send a message via AIM to Jimster480
could easily be a wheel balancing problem. But u should check ur hxles. And the shaking is only in the steering column? Not the car itself? do you have power steering?
AIM/YIM: Jimster480
ICQ: 309990222 (You Prolly dont have this)
MSN: Jimster480@gmail.com
"On the internet the men are men, the women are men, and the little girls are FBI agents." - IRC
Jimster480 is offline   Reply With Quote
Old 07-11-2009, 02:11 PM   #20
UnleashedEJ1
1995 Acura Integra
My Garage
Sorry it has taken me a few weeks to respond to the thread, I jacked the car up and simply redid the coil over sleeve install, I didnt notice any problems but the spring was loosely just sitting there with lots of play. I took them apart and kinda installated the sleeves and springs with some thick rubber hoseing. after that they were pretty stable. so I put it all back togather and took a test drive to see if anything has changed. The ride quality is 80-90% better with very little movement over 65mph and even felt good at 80-85mph. I think any vibrations if any that are left are probablly the tire and wheels. Im very satisfied with the outcome and I would like to thank everyone how helped with suggestions. Thanks
I ♥ My Honda
DC Squad #30
Old 07-11-2009, 02:57 PM   #21
40mpg_dx00
2000 Honda Civic
I'm glad you got it sorted out. I just wanted to say one thing. There were a boatload of people saying tire balance, tire balance. granted, sometimes people screw up balancing but CHEESE WHIZ if you say they're balanced, they are balanced. I hope none of those people call themselves mechanics cuz that was ridiculous. for those guys that want to be pissed at me, you keep beating that dead horse
40mpg_dx00 is offline   Reply With Quote
Old 07-12-2009, 01:44 AM   #22
waaBAAH
waaBAAH's Avatar
OP should have said this in the very beginning. OP didint and just said his car shakes at highway speeds. he was linking the two shaking highway speeds together as one problem.
,.................. the only reason I dont think it is a tire balance issue is the shaking when I hit large bumps and holes...............
. ..............so I put it all back togather and took a test drive to see if anything has changed. The ride quality is 80-90% better with very little movement over 65mph and even felt good at 80-85mph. I think any vibrations if any that are left are probablly the tire and wheels.............
OP still has a vibration...and more then likely it is from wheels balancing. ANY mechanic would state "wheel balancing" first as the potential cuase due to the fact it is the simpliest and cheapest route to go.
if loose lugnuts was the problem this would be found while balancing. once you rule out balacning 100 percent then you cn move onto other stuff but there really isnt much more that can cause a 60 mph shake/shimmy while cruising.
Old 07-12-2009, 10:40 AM   #23
40mpg_dx00
2000 Honda Civic
I'm not disputing that it is a common issue but the OP DID say they were balanced (right after providing tire and rim size). Yes, people screw up balancing, often from a machine needing calibration, but when you diagnose a problem with second-hand info you have to take what you are given at face value. If you second-guess every piece of information then the problem will take much longer to solve
2006, 65, bumps, car, change, civic, honda, miles, mph, passport, shake, shakes, steering, suv, tire, wheel
