supplemental restraint system indicator
Old 06-05-2009, 05:43 PM
iwantspeed's Avatar
Icon3 supplemental restraint system indicator
has anyone had the light directly under the water temp gauge its a guy sitting in a seat with a big dot infront come on? if so how did u fix the problem?? the light just randomly came on today and wont go away. please dont just say take it to honda because im broke. thanks for your help. in the owners manual its page 52 that talks briefly about it. any suggestions on things i should check before bringing it to honda.
Old 06-05-2009, 05:58 PM
Sanji
toyomatt84's Avatar
Default Re: supplemental restraint system indicator
What model/year car are we talking about?
Old 06-05-2009, 09:14 PM
iwantspeed's Avatar
thanks for the reply. its an 03 civic ex
Old 06-06-2009, 06:23 AM
iwantspeed's Avatar
toyomatt wake up and help me!!!! : )
Old 06-06-2009, 10:24 AM
waaBAAH's Avatar
To retrieve air bag codes, locate the OBD II connector and find the Brown wire in pin #9. Ground that wire and turn on the ignition, then the Supplemental Restraint System (SRS) light will flash out codes.
To clear the SRS light, locate the Yellow 2-cavity connector in the drivers fuse box. The wire colors are Green with a Black stripe and Blue or Black. Jump the connector and turn on the ignition. When the SRS light goes out, remove the jumper wire within 4 seconds and when the light comes on, jump the connector within 4 seconds, and when the light goes out remove the jumper wire within 4 seconds and the SRS light should flash 2 times and reset. This procedure will need to be done after the SRS failure has been repaired or to see if the problem is intermittent.
Old 06-06-2009, 05:19 PM
iwantspeed's Avatar
hey thank u !! i havent tried what u told me to do yet but thanks for your help ill do it tomaro. do u think the heat did it? its been kinda hot lately but i dont understand what the hell set that thing off. car hasnt been wrecked or bumpd or anything.
Old 06-06-2009, 09:39 PM
waaBAAH's Avatar
i dont think heat did anything.
but a low charging altenator could very well set off the code.
Old 06-07-2009, 03:43 PM
iwantspeed's Avatar
that verry well may be it! i have 2 10 inch subs with no capacitor. so im sure my alternators on the verge of crapping out. my headlights dim when i turn the volume up. thanks. im just going to take the subs out. im tired of em.
Old 06-07-2009, 07:52 PM
waaBAAH's Avatar
The Supplemental Restraint System (SRS) light will illuminate when driving the vehicle, as soon as you slow down the light will turn off. There are no stored codes when terminal #9 of the OBD-II connector is grounded.
Tests/Procedures:
1. Check the charging system, if the alternator is overcharging the SRS light will illuminate and not store a code. If the alternator is overcharging and the powers to the alternator are good replace the alternator.
2. If the charging system is operating correctly, then voltage drop the powers and the grounds at the SRS control unit before replacing any components.
i know this doenst follow your "exact" symptoms, but i think it is close enough
vthree
05-06-2006 03:56 PM
Got2HaveSol
08-28-2005 03:59 PM
ih8danoles
08-12-2003 10:13 PM
Mrivera21
05-28-2003 03:03 PM
LSVTEC408
01-02-2003 12:52 AM
Quick Reply: supplemental restraint system indicator
