> Honda Accord (1990 - 2002)
Old 06-05-2009, 11:19 AM   #1
Paulie10
Default Bleeding the cooling system
When I bleed the cooling system on my 93 accord are these the steps I should follow.
1. fill radiator to top with fluid
2. replace rad cap and start engine
3. open (or totally take out not sure which) bleed screw
4. wait until a steady stream of coolant seeps out of bleed opening
5. tighten screw and fill radiator when cool
Paulie10 is offline   Reply With Quote
Old 06-05-2009, 04:13 PM   #2
92civlude
Default Re: Bleeding the cooling system
Dont have the car running with the bleeder loose. If the thermostat is closed and the car is cold, air will get sucked in at the bleeder.
92 Civic Hatch G23 DOHC VTEC turbo
92civlude is offline   Reply With Quote
Old 06-05-2009, 04:41 PM   #3
nysdriver
You are also supposed to run the engine with the radiator cap off until the cooling fan comes on at least twice. Makes a lot of mess, but you will see tons of air coming out.
Don't forget to set the heater temp dial to max before you start, too.
nysdriver is offline   Reply With Quote
Old 06-05-2009, 09:37 PM   #4
jonesdesign
jonesdesign's Avatar
anyone know if this applies to all 90-93 accord models?
jonesdesign is offline   Reply With Quote
Old 11-08-2009, 04:34 AM   #5
madracer
madracer's Avatar
Where is the bleed screw????
Boosting on a B16A2.
Tuned on: Hondata S300
Tuned by: HPC Derf.
madracer is offline   Reply With Quote
Old 11-08-2009, 07:19 AM   #6
redbull-1
redbull-1's Avatar
It is usually shown in your owner's manual. But if you don't have it, post the year of the car and model (e.g. 19XX Accord, Civic) or google.
redbull-1 is offline   Reply With Quote
Old 08-11-2010, 09:22 PM   #7
Bad_dude
Send a message via AIM to Bad_dude
Icon2 Re: Bleeding the cooling system
What is the torque spec for the bleeder screw?
Thanks.
Bad_dude is offline   Reply With Quote
Old 08-11-2010, 09:25 PM   #8
holmesnmanny
Doesn't need to be tight, you'll know when it's tight enough 'cause it'll stop spewing coolant. When you do bleed, make sure you to turn your heater blower on full blast.
I'm gonna find my service manual and get the right specs.
91 Accord w/ H22A swap: Newest update on CARB cert...... Passed smog at the REF...Offically CARB certified !!!
holmesnmanny is offline   Reply With Quote
Old 08-11-2010, 09:27 PM   #9
holmesnmanny
7lb-ft dude
Old 08-11-2010, 09:29 PM   #10
holmesnmanny
I just found the drain bolt for draining the block it's just to the left of the oil filter, 36lb-ft
Old 08-11-2010, 10:03 PM   #11
Bad_dude
Is it under with the oil filter or on top in the engine bay? And when do you need to drain the block?
Thanks.
Old 08-11-2010, 11:37 PM   #12
holmesnmanny
Thanks.
to the left of it, you would need to if you remove the thermostat housing when doing the intake manifold as we're talking about in that other thread and when taking out the water pump, head off, stuff like that.
1992, 2002, 93, accord, air, bleed, bleeding, blleding, capacity, coolant, cooling, fit, honda, prelude, radiator, system
