| Welcome to Honda-Tech! | ||
#1 |
Whats going on members,
I have a power steering leak and it is boggeling my mind, the boot that goes at the end of the tie rod end and the steering gearbox on the passanger side seems to have some power steering fluid that drips from the bottom of the boot, I have checked all the power steering hoses and the boot on the end the the tie rod end and there are no holes or rips on the boot and the steering gearbox has no wet fluid on it either, so I know my steering gearbox seems to be fine, I don't know where the leaks are coming from, there are no leaks under the hood either. any help would be appreciated Thank you
CL9 Squad Member #91 !! 2004 CGPM CL9(Current)~1989 ED6(Sold)~1992 DA9(Sold)~1994 DC4(Sold)~1985 Carb CRX (Sold) |
#2 |
This problem has been a problem of mine as well. Mine started leaking about 3 months ago. I had a whining noise when the car is on and noticed it was the power steering pump trying to suck in fluid.
I brought it to a shop and they told me it was leaking from the rack and pinion. I've been going to that shop for a while and i trust them. They told me I would have to change the whole rack and pinion. But they also told me to try using Lucas Power Steering Stop Leak. I put in about 12 oz but it is still leaking but whenever my PS reservoir is low, it doesnt make a whining noise anymore. The bottle says a second bottle might be needed to completely stop the leak, so I will add another bottle if it still continues to leak. Right now, my fluid is still leaking after a bottle of the Lucas fluid. |
#3 |
it is deff a leak, from a seal in your rack. as turismo stated, you will have to replace the entire steering rack.
#4 | |
I spoke with an Acura Dealership in Minnesota, Bloomington Acura and told the service dept what my issue was and he told me its very uncommin for the rack and pinion to go out in the TSX, but he maybe just telling me a line of BS, I think I am going to put the car on some jack stands and start the car and turn the wheel back and fourth and see if I can see where its leaking from, or just fill it and leave it as it is, from what I have been looking at for price on rack and pinion its a nice chunk of change for the part.
#5 |
when you do that, try to remove the boot where the rack and the tie rod meet. im willing to bet thats where the fluid is coming from. it is uncommon for the rack to go back in our cars, but it can happen.
#6 | |
#7 | |
#8 | |
#9 |
Well I checked it over and over, felt the boot and there is no fluid in the boot, and no holes or cracks, I didnt want to take the boot off to check, this is a picture of where the PS fluid is coming from, it was taken with my cell phone so where the fluid is, is the bottom of the boot, hope this helps
![]() Thanks
CL9 Squad Member #91 !! 2004 CGPM CL9(Current)~1989 ED6(Sold)~1992 DA9(Sold)~1994 DC4(Sold)~1985 Carb CRX (Sold) Last edited by 94DCTeg; 06-04-2009 at 07:59 PM. |
#10 |
the boot is just a dust cover. if you can, pull the boot off from the part where it meets the rack, the inside part. there is a seal right where the inner tie rod ends meets the rack, i will bet that is where the leak is. im 100% sure of it, so if you can pull back the boot, it wont hurt anything, there is prob a snap clip or something on it, holding it in place.
#11 | |
#12 |
interesting thread....
i have an 04 and my P.S. pump wines like a m*th%er fuc%er. at first i thought it was the tensioner and belt, but that wasn't the problem so that was a waste of $160 bucks. now i'm thinking to either rebuild it or look for a reman. it's a really annoying sound! by the looks of this thread i should take a look at my rack also and see if there are any leaks. thanks...
*EF LEGENDS* you will be forever missed.... Vince Pascua "JDMEFSEDAN" 1976-2006 Randy Gagan "QUESTOYZ" 1980-2006 Last edited by BlUeDC2nEr; 06-05-2009 at 03:40 PM. |
#13 | |
#14 | |
#15 | |
i knew that was the leak. hopefully you can just get the seal and install it. ive never done that, but have replaced quite a few racks. |
#16 | |
P/N - 06531-SEA-E02 - SEAL KIT A, POWER STEERING (ROTARY VALVE) 1 2004 TSX Hope the info helps, and yes when I do decide to do it I will deff do a DYI Thanks again members !!! I greatly appreciate it
| Tags |
| acura, civic, drip, honda, integra, leak, pinion, power, prelude, problem, pump, rack, steering, tl, tsx |
