Old 05-29-2009, 11:26 AM   #1
hammergunner
1989 Honda Civic
hammergunner's Avatar
Default D16 head on D15 Block
The title is pretty much the question at hand
will a d16 vrec head fit on a d15 block with no modification or do i need to run the vtec oil lines like on the B series dohc motors?
any and all info about this will help greatly.
Thanks for helping out.
If you want to rock her use the Shocker!
hammergunner is offline   Reply With Quote
Old 05-29-2009, 11:51 AM   #2
rick_rabies
I'm not Rick!
1994 Honda Civic
rick_rabies's Avatar
Default Re: D16 head on D15 Block
it fits. its called a minime. no oil lines. take out the oiler in the block when you put the head on and you need to use the d16 timing belt, dizzy and all its atachments. you should get a z6 or y8 intake mani for it. iv never heard of vrec....
An armed society is a polite society *2nd amndmnt*
"if you have a cloak, and if you don't have a sword, sell your cloak and buy one. Luke 22:36KING of kings
rick_rabies is offline   Reply With Quote
Old 05-29-2009, 12:02 PM   #3
hammergunner
1989 Honda Civic
vrec?
and whats the oiler (oil dowels?) main oil feed in the oil pan?
Please be more informative
thanks for the other info though. Big help
Old 05-29-2009, 12:13 PM   #4
hammergunner
1989 Honda Civic
new information ---- The guy who i'm buying the motor from missread the code
its a d16 non vtec block
and i have the d16 vtec head
Bolt right up or need modification?
Old 05-29-2009, 12:22 PM   #5
J ROD
i have a d16z6 vtec for sale.100k.no oil leaks.+new altenator,water pump 1k,trans,
axels 10k,ecm fuel rod,ect.....realized i want a gsr?????u r kinda far???anybody
J ROD is offline   Reply With Quote
Old 05-29-2009, 12:23 PM   #6
J ROD
$700
Old 05-29-2009, 12:24 PM   #7
JosephColy
JosephColy's Avatar
i take it its a D16Y7 block and a Y8 head?
JosephColy is offline   Reply With Quote
Old 05-29-2009, 12:27 PM   #8
rick_rabies
I'm not Rick!
1994 Honda Civic
700 can get you a gsr block or ls motor and tranny in some places.
but on the block in the dowel pin areas there is a thingy pressed in a hole. take it out, it gets oil to the top now that you need more oil up there, no need to switch timing belts then. just put it on and wire vtec
Old 05-29-2009, 12:48 PM   #9
hammergunner
1989 Honda Civic
PLEASE STAY ON TOPIC THIS IS NOT A FOR SALE THREAD IF YOU MISS POST AGAIN YOU WILL BE REPORTED
Old 05-29-2009, 04:08 PM   #10
boost and bass
boost and bass's Avatar
I would just buy a d16z6, d15b, or d16y8 there easy to find very cheap and it will be more reliable and much easier to do
boost and bass is offline   Reply With Quote
Old 05-29-2009, 08:23 PM   #11
Jimster480
Jimster480's Avatar
Send a message via ICQ to Jimster480 Send a message via AIM to Jimster480
just get the D16 Block and the head. There is no such thing as a non-vtec block. No Blocks have vtec. vtec is all in the head. So yes it will completely bolt up with no problems, and make a D16 VTEC motor. Now depending on the D16 Block it will yeild different amounts of power. And have a different compression ratio. What is the code on the D16 Block?
AIM/YIM: Jimster480
ICQ: 309990222 (You Prolly dont have this)
MSN: Jimster480@gmail.com
"On the internet the men are men, the women are men, and the little girls are FBI agents." - IRC
Jimster480 is offline   Reply With Quote
Old 05-30-2009, 12:41 AM   #12
sLAg
sLAg's Avatar
would a minime swap pass smog in cali ?
"Straight roads are for fast cars, turns are for fast drivers." -Colin McRae
sLAg is offline   Reply With Quote
block, civic, d15, d15b, d16, dowel, engine, fit, fl, head, leak, miami, oil, pins, swap, y8
