> Suspension & Brakes
Old 05-27-2009, 04:07 PM   #1
phikshin
Default Squeak coming from rear of car
I have a squeaking noise coming from the rear of the car. Usually happens when I go over bumps but does not happen every time I go over bumps. Sounds like its coming from the rear doors / Rear tires. I have a 1997 civic lx.
Any idea of what it could be? How to fix it? Any help would be appreciated.
phikshin is offline   Reply With Quote
Old 05-27-2009, 07:47 PM   #2
xd69
1999 Honda Civic
xd69's Avatar
iTrader Rating: (1)
Default Re: Squeak coming from rear of car
Welcome to the club of random squeaks coming from who knows where. Ive tried to diagnose squeaks but the place they sound like they are coming from have NO moving parts, so i gave up and just turn up the radio
F*** thives...
xd69 is offline   Reply With Quote
Old 05-28-2009, 12:37 PM   #3
alphalanos
2000 Honda S2000
alphalanos's Avatar
Send a message via AIM to alphalanos
Any modifications? Check all the bushings in the rear suspension arms. Bounce the car while its parked and see if you can hear the noise. You could try loosening the suspension bolts, then compressing the suspension with a floor jack and retightening, this reduces binding of the suspension bushings.
2000 Honda S2000
alphalanos is offline   Reply With Quote
Old 05-30-2009, 07:00 PM   #4
CG6Accord8o1
could be endlinks, joints or bushings.
CG6Accord8o1 is offline   Reply With Quote
Old 05-30-2009, 10:25 PM   #5
batallic
batallic's Avatar
could be blown shocks, torn bushings,
PSN : Ingram10
batallic is offline   Reply With Quote
Old 05-30-2009, 10:53 PM   #6
wannaBjdmca6
wannaBjdmca6's Avatar
is ur car lowered? check top hats ( the can separate metal and rubber part and move as there is suspension flex)
also trailing arm bushings, sway bar bushing.
good luck
wannaBjdmca6 is offline   Reply With Quote
Old 06-03-2009, 05:33 PM   #7
2000BlueEm1
2000BlueEm1's Avatar
Send a message via AIM to 2000BlueEm1
could be your trailing arm the bushings might need to be changed, thats the problem with mine,cause my suspencion is new and it sqeeks
2000BlueEm1 is offline   Reply With Quote
Old 06-07-2009, 07:46 AM   #8
phikshin
Its a little hard to tell by the picture but thats the bushing in there correct? Because if so they all seem pretty worn out to me. Some of them look cracked / torn.
Old 06-09-2009, 04:51 PM   #9
vtecb20gsr
vtecb20gsr's Avatar
Send a message via AIM to vtecb20gsr
trailing arm bushings squeak the most
team-integra.net
vtecb20gsr is offline   Reply With Quote
Old 06-11-2009, 12:03 AM   #10
dannyboi_86
Send a message via MSN to dannyboi_86
i replaced my suspension and had squeaks , i replaced the lcas and no more squeaks! , 2 weeks later another small squeak it was now the rear trailing arm bushes and now all good , but it may not be the case all the time but usually after lowering a car and being as old as our cars are its going to happen...
dannyboi_86 is offline   Reply With Quote
2001, 2009, accord, bumps, car, civic, crx, honda, noise, odyssey, prelude, rear, s2000, spring, squeak, squeaky, squeek
